29367 Discussions
Quickwin program freezes on Windows 7 x64
Reinaldo_Garcia
When the program ends and displays the message "...Exit window?", if you click No, the window freezes.
The same program works just fine in Vista x64/XP.
I have Windows 7 Ultimate x64 and compiler 11.1.035.
Any suggestion?
R//G
[Edit by Steve Lionel (Intel) - for information on this problem and to obtain a fix, please readIntel Visual Fortran QuickWin applications freezing]
Neels
New Contributor II
I presume that this library is not yet in Update 2 as the library in Update 2 is dated 14/1 while this one is 20/1?
Neels
Steven_L_Intel1
Correct. This fix, assuming no further problems are found, will be in Update 3.
hkausl
it seems, that I have the same problem with update 3 too. I have to kill taskhost.exe then all works. As described before, I'm using 32 bit W/.
Is this fix in Update 3 or not. If not, is it in 4. Thanks.
Steven_L_Intel1
No, this fix is not in Update 4. It was deemed too risky without enough evidence that it did not create further problems. If you want the fix, please follow the instructions here.
hkausl
I wrot a email to quadsupport@mailbox.intel.com with topic Request QuickWin library fix DPD200149113. Is this correct to get the fix?
Steven_L_Intel1
No. You must log in through Intel Premier Support and request the fix.
hkausl
My company bought a license for me. I got an email with a download link and serial number and one year support. The link works. But I can't regsiter the license, because it's already regsitered and so, I can' use premier supoort. Any idea what I can do to?
Steven_L_Intel1
We've found a problem with the Intel 64 (x64) version of the fixed library - a new one is being built and we should have it in a day or two. Sorry for the inconvenience.
hkausl
I tried the w32 ifqwinlib in my qwin application under xp. It slows donw the application. All scrren actions are slow. Then I rechanged to the old one and all works fine again.
hkausl
Any news about the lib patch and the speed I wrote in my last post?
Steven_L_Intel1
I have passed your comment on to the developers but have not heard from them. I expect they'll want to see a buildable and runnable copy of your application. Others we have given the library to have not reported speed problems.
Do you have a test case we can look at?
hkausl
Hello Steve,
sorry for the delay, I did some tests. It's not possible to make a small buildable example. I retried linking with the new ifqwin.lib once more, it works on W7 32bit , program freeses no more. But the speed slows down. My program handles the complete video output and is based on the ifqwin rotuines. So I will includes something, that when the program starts, taskhost.exe will be killed automaticall.
Steven_L_Intel1
Which aspects of the program slow down? The change we made related to input events. We'll take the full application if you're willing to provide it. Please use Intel Premier Support for that.
hkausl
I'm filling the whole screen with text-information, therefore I usefunctionouttext. Then I wait for keyboard or mouse events withsleppqq of 25 ms. I handle the total keyboard event.So there are input events. I attached some of the specific routines and a readme too.
The writing on screnn is slower than with the normal ifqin.lib. The reasaon may be the input handler, becaus I'm always waiting for inputs
Steven_L_Intel1
I need a buildable and runnable application. The ZIP you attached is missing many routines, as well as the main program.
hkausl
Sorry, thats not possible. So I go on with killiing taskhost.exe.
Neels
New Contributor II
Hi Steve
Is this fix in update 5?
Neels
hkausl
Hello Steve,
any news about the fix and update 5?
Steven_L_Intel1
Sorry for the delay in answering.
The fix for the freezing issue is in Update 6, scheduled for September.
hkausl
Hello Steve,
is this fix in the updae 6?
Steven_L_Intel1
Yes, it is in update 6.
