Reading file of length zero
Diehl__Martin
I have a general reading routine that crashes for empty files (ASCII).
The following minimal example shows this behavior (compile; touch empty.txt; ./out) when compiled with ifort version 19.0.2.187. Is that the expected behavior, i.e. would I need to check for fileLength/=0 or is ifort suppost to figure this out.
program test
 character(len=:), allocatable :: a
 a = IO_read('empty.txt')
 print*, len(a)
 print*, '#'//a//'#'
contains
function IO_read(fileName) result(fileContent)
  character(len=*),  intent(in) :: fileName
  character(len=:), allocatable :: fileContent
  integer ::  &
    fileLength, &
    fileUnit, &
    myStat
  inquire(file = fileName, size=fileLength)
  open(newunit=fileUnit, file=fileName, access='stream',&
       status='old', position='rewind', action='read',iostat=myStat)
  if(myStat /= 0) stop 1
  allocate(character(len=fileLength)::fileContent)
  read(fileUnit) fileContent
  close(fileUnit)
end function IO_read
end program test
Steve_Lionel
Here's my analysis of the situation...
The READ is attempting to read zero bytes from an empty file connected for unformatted stream access. The standard says that an end-of-file condition occurs when "an attempt is made to read beyond the end of a stream file." Since the READ is not trying to read beyond the end of the file, the file position should remain unchanged and the READ should succeed.
Therefore, I believe this is an error on the part of ifort and should be reported to Intel using the Online Service Center.
Arjen_Markus
Honored Contributor I
I tried your program with gfortran and that worked fine. I am not sure what should be expected acorrding to the standard. The simplest way around this problem is of course to always check for an error. It may be one of those corner cases that are not covered.
andrew_4619
The problem is the read, it should have an iostat and you should then manage the eof status and other errors, that covers the bases. Opening an empty file is not and error. Reading one is.
Diehl__Martin
thanks for the quick reply. Adding iostat indeed works. Its value is -1, but I don't need to `manage` anything.
Might be a corner case, but to me this behavior is unexpected. Why should the use of an optional, intent(out) variable change the behavior of read()?
Diehl__Martin
One more thing I have noticed:
iostat is 0 if I read a file of length>0 into a string of matching len
iostat is -1 if I read file of length 0 into a string of len 0
gfortran's iostat is 0 in both cases, I find this more consistent
andrew_4619
I believe implicit allocation of a string by a read is not standard Fortran.
Diehl__Martin
I'm not doing that, fileContent is allocated to size 0:
Arjen_Markus
There is some ambiguity here:
allocate( character(len=0) :: string )
do
     read(10, iostat =ierr)  string
     if ( ierr /= 0 ) then
          exit
     endif
enddo
This program would never stop with gfortran, because it never encounters an end-of-file, whereas with Intel Fortran it does.
Of course, this is a trifle contrived, but it does illustrate that there are more sides to the problem!
andrew_4619
Conceptually:
1) Is a null file by default at EOF?
2) Is a "null" read a read?
3) does a read check for "eof status" before or after a null read?
I haven't read the standard but I expect some of these are probably undefined and/or OS dependant. A null read is conceptually pointless and I would suggest it is the coders responsibility to avoid/manage such events.
Diehl__Martin
@andrew_4619: Interesting questions.
I just want to emphasize that I am using the "stream" access mode which might be reason for the strange behavior
When reading a file of length N into a string of length N, EOF is not reached. Therefore, it would be consistent if opening a zero length file would not default to EOF. However, the most consistent situation would be immediate EOF for zero-length files and EOF after reading N characters (or bytes) from an file of length N (in bytes or characters).
Does not matter, as long as a null read does not change the status
The general question would be whether EOF status is reached when the last bit of information is read or when one tries to go beyond this limit.
The actual read is pointless, but taking care of it is annoying. Reading a file containing N characters results in a string of length N, I dont' see a reason why N > 0 is required since strings of size 0 are totally valid.
Steve_Lionel
andrew_4619
Maybe one could also say that an attempt to read nothing is in fact not attempt at all.....
Steve_Lionel
I wouldn't say that. There are side-effects of a READ that have nothing to do with the actual reading, such as connecting to a file if not already connected.
cryptogram
One side effect of accessing a zero length file, is that you may run into contention with your anti-malware scanner.
We were using a model that would open an error log file prior to starting a lengthy calculation, and close it at the end of the calculation.
If there were no errors to log, this results in a file with 0 length.  The calculations were being performed inside a loop, so the model would
repeatedly open and close this file.
The malware scanner saw these zero length files as suspicious, because a zero length file still reserves a cluster of disk space, which is a good place to
hide malware.  Eventually, the model would crash because the malware scanner was scanning the file at just the wrong time.
jimdempseyatthecove
That is a crappy way to implement a malware scanner. It is not unusual for a program to pre-open an output file, thus reducing filesystem latency, for use later. Or, open a log file (as you did), only to not log errors. Or, to use the existence or or absence of a file for use in inter-process signaling. All of these uses are completely reasonable. Flagging as potential malware is not correct.
Jim Dempsey
JohnNichols
Valued Contributor III
I open many hundreds of files at a time, some are zero length and they have been zero length for years if I store the directory for later use
No malware scanner has ever complained about such files, although now I use the Windows 10 program and it has (fingers crossed) no problems for many years.
The biggest malware I see is the IT dept who put controls on everything so that you can do nothing.  The tendency to hide email addresses so you cannot find someone --
Steve_Lionel
Martin, will you please submit a bug report to Intel via https://supporttickets.intel.com/?lang=en-US ? They may not pick up on it from here.
Diehl__Martin
I did that, but the request was closed because I could not provide any license information. I have an educational license and don't know exactly how to figure out who is the officially responsible:
Nikky from Intel Support responded Yesterday 06:29 PM
Martin, our records indicate that you do not have a supported product associated with your account.
You need a supported product in order to qualify for Priority Support. As such, this ticket is being closed.
Steve_Lionel
Sigh. Ok, I will file it for you.
Steve_Lionel
Filed as request number 04669455. As a workaround, skip the READ if the length is zero.
Diehl__Martin
Thanks. Actually, adding iostat already resolves the issue of a segmentation fault. The only small inconsistency is that
iostat /= 0
does not work for zero length files, but
iostat > 0
is also fine for the code I'm using
