Rebuild .vfproj for MSBuild
Kipling__Michael
I am trying to build a .sln which has a top level C++ project, and a C .vcproj creating a DLL and a Fortran .vfproj creating another DLL. I have been working with VS2005 and IVF 11.1 . I am trying to convert to VS2010 and Composer XE 12.0.
The C & Fortran projects build without errors, but when I try to build the solution I get the following error message.
Error 76 error MSB4075: The project file "Path\\ProjectName.vfproj" must be opened in the Visual Studio IDE and converted to the latest version before it can be built by MSBuild.
Suggestions?
Mike
This is explained in the release notes for the Fortran compiler. Please read the section on VS2010..
Adrian_F_1
Same problem in Fortran 13 / VS2012.  Nothing in the release notes though.
IanH
I see material for VS2010/VS2012 migration in the 13.1.1 release notes under section 3.6.  It makes specific reference to the error in the original post in section 3.6.2.
Adrian_F_1
Is this the link you are refering to?  http://software.intel.com/sites/default/files/article/251098/release-notes-f-2013-w-en-u3.pdf
3.6.2 talks about C++ projects referencing Fortran projects.  My problem is with Fortran not C++.
IanH
The error in the original post here is reported by the build system for a C++ or whatever language project (an MSBuild built project) not understanding the project file for the Fortran project - Fortran projects are not built by MSBuild.  If you don't have this situation then you need to describe in more detail your situation and the error that you are seeing.
