29648 Discussions
Reference for windows graphical interface
h_amini
I am going to create a windows graphical user interface for my program to select directories and files, and to initialize variables. In addition I am interested in drawing 2D geometries, 2D contours and 3D surfaces if they are not very time consuming.
I use Visual Fortran Compiler11.0.072on IA-32 and am novice at creating such interfaces. So I just wonder if you could tell the best way to do that. Please advise any book, website, subroutine, utility and software can be helpful.
Many thanks
Hamid
Les_Neilson
Valued Contributor II
As a GUI starting pointlook at Jugoslav's xeffort library www.xeffort.com
Click on Xeffort Home and look at the samples.
Les
h_amini
Many thanks, seems very interesting to start. But what do you advise for more complex applications?
Hamid
Quoting - Les Neilson
Les
Hamid
Les_Neilson
Quoting - h.amini
Hamid
Mmmm having worked for the last 30 years on applications that do 2d/3d geometry,geological modelling, contouring etc. there is no easy answer. It depends on what data you are trying to model. In many ways data management is the hard part, drawing it on a sceeen / plotter is "easy" after that.
You could look at dislin (free for non-commercial use) or gnuplot (free) to see if they help.
Les
tropfen
the book is old (2002) but still usefull.
Norman Lawrence: Compaq Visual Fortran. A Guide to Creating Windows Applications.: A Guide to Creating Windows Applications
# ISBN-10: 1555582494
# ISBN-13: 978-1555582494
i have not fund big differences in the part of windows graphical interfaces between CVF and IVF.
the book also has an open gl part.
Frank
h_amini
Les
I will go through the websites with due appreciation. I am attaching a simple of the data file and also the figures I need to draw.
I have also got the book Frank says (thank you Frank!) but I thoughtthat wasnot compatible with IVF!
Hamid
Most of what is in the Lawrence book is applicable to IVF.
