Unfortunately, there was quite some regression in the beta release of ifort v19 which lets ca. 10 of our unit tests and ca. 20 of our functional tests fail with segmentation faults. We think/hope that this is only one bug/regression. I reported this as support item 03384851 to the Intel Support. Unfortunately, the regression was not yet fixed within the Update 1 of the beta version. Hopefully (fingers crossed) this gets fixed for the official release. In v17 there were many regressions at the beginning so we had to special case our build environment to veto v17.0.0/1/2/3 and only allow v17.0.4 onwards. v18 came with some regression (IIRC) that was fixed, however, before the official release came out. We hope very much that this will happen for v19 as well. Here is the code leading to the problem:
module resonances
implicit none
private
public :: t2
public :: t3
public :: t4
type, public :: string_t
private
character(LEN=1), dimension(:), allocatable :: chars
end type string_t
type :: t1
integer, dimension(:), allocatable :: c
contains
procedure, private :: t1_assign
generic :: assignment(=) => t1_assign
end type t1
type :: t2
type(t1) :: contributors
contains
procedure :: copy => resonance_info_copy
procedure :: init => resonance_info_init
end type t2
type :: t3
type(t2), dimension(:), allocatable :: resonances
integer :: n_resonances = 0
contains
procedure :: copy => resonance_history_copy
procedure :: add_resonance => resonance_history_add_resonance
end type t3
type :: t4
private
type(t3), dimension(:), allocatable :: history
integer :: last = 0
contains
procedure :: init => t4_init
procedure :: enter => t4_enter
end type t4
contains
pure subroutine t1_assign (contributors_out, contributors_in)
class(t1), intent(inout) :: contributors_out
class(t1), intent(in) :: contributors_in
if (allocated (contributors_out%c)) deallocate (contributors_out%c)
if (allocated (contributors_in%c)) then
contributors_out%c = contributors_in%c
end if
end subroutine t1_assign
subroutine resonance_info_copy (resonance_in, resonance_out)
class(t2), intent(in) :: resonance_in
type(t2), intent(out) :: resonance_out
if (allocated (resonance_in%contributors%c)) then
associate (c => resonance_in%contributors%c)
resonance_out%contributors%c = c
end associate
end if
end subroutine resonance_info_copy
subroutine resonance_info_init (resonance, mom_id, pdg, n_out)
class(t2), intent(out) :: resonance
integer, intent(in) :: mom_id
integer, intent(in) :: pdg, n_out
type(string_t) :: head_footer
integer :: i
integer, dimension(n_out) :: tmp
logical, dimension(n_out) :: contrib
!!!! Commenting out this one makes it go away
head_footer = var_str_("******************************************************************************")
do i = 1, n_out
tmp(i) = i
end do
contrib = btest (mom_id, tmp - 1)
allocate (resonance%contributors%c (count (contrib)))
resonance%contributors%c = pack (tmp, contrib)
end subroutine resonance_info_init
subroutine resonance_history_copy (res_hist_in, res_hist_out)
class(t3), intent(in) :: res_hist_in
type(t3), intent(out) :: res_hist_out
integer :: i
res_hist_out%n_resonances = res_hist_in%n_resonances
res_hist_out%resonances = res_hist_in%resonances
end subroutine resonance_history_copy
subroutine resonance_history_add_resonance (res_hist, resonance)
class(t3), intent(inout) :: res_hist
type(t2), intent(in) :: resonance
type(t2), dimension(:), allocatable :: tmp
integer :: n, i
if (.not. allocated (res_hist%resonances)) then
n = 0
allocate (res_hist%resonances (1))
else
n = res_hist%n_resonances
allocate (tmp (n))
do i = 1, n
call res_hist%resonances(i)%copy (tmp(i))
end do
deallocate (res_hist%resonances)
allocate (res_hist%resonances (n+1))
do i = 1, n
call tmp(i)%copy (res_hist%resonances(i))
end do
deallocate (tmp)
end if
call resonance%copy (res_hist%resonances(n+1))
res_hist%n_resonances = n + 1
end subroutine resonance_history_add_resonance
subroutine t4_init (res_set, initial_size)
class(t4), intent(out) :: res_set
integer, intent(in) :: initial_size
allocate (res_set%history (initial_size))
end subroutine t4_init
subroutine t4_enter (res_set, res_history, trivial)
class(t4), intent(inout) :: res_set
type(t3), intent(in) :: res_history
logical, intent(in), optional :: trivial
integer :: i, new
new = res_set%last + 1
res_set%history(new) = res_history
end subroutine t4_enter
elemental function var_str_ (char) result (string)
character(LEN=*), intent(in) :: char
type(string_t) :: string
integer :: length
integer :: i_char
length = LEN(char)
ALLOCATE(string%chars(length))
forall(i_char = 1:length)
string%chars(i_char) = char(i_char:i_char)
end forall
end function var_str_
end module resonances
program main_ut
use resonances
implicit none
call resonances_3 ()
contains
subroutine resonances_3 ()
type(t2) :: res_info
type(t3) :: res_history
type(t3), dimension(:), allocatable :: res_histories
type(t4) :: res_set
integer :: i
call res_set%init (initial_size = 2)
call res_set%enter (res_history)
call res_info%init (3, -24, 5)
call res_history%add_resonance (res_info)
end subroutine resonances_3
end program main_ut
Intel support informed me that this issue has been fixed by the developers, and the fix will be available for the official release of the v19 of the compiler. So that is great news, I am eager to test the official version.
