29285 Discussions
Release date for Intel Parallel Studio XE - version 2021, Initial Release ?
jirina
I wonder whether the release date for IPS XE, version 2021, is known and can be found somewhere.
I am currently using version 2020, Update 4, built on Oct 15, 2020, so it's been already 4 months since this release.
Previous releases were built on Jul 2, 2020 and Apr 1, 2020, and on Dec 3, 2019.
Thank you.
Ron_Green
There will be no more Parallel Studio releases.  Intel has moved to packaging compilers in the oneAPI Base Toolkit and oneAPI HPC Toolkit.  SEE THIS WEBINAR
Ron_Green
jimdempseyatthecove
Ronald,
For those of use with Parallel Studio subscriptions, with the Intel new update notifications inform us of a new update being available (with the oneAPI naming convention)?
I've been waiting for an update from Parallel Studio XE 2020 update4 which has a broken integration with MS VS 2019 for the Intel C++. My (cumbersome) work around is
1) open the IDE for edits
2) use a command line window for builds
3) to debug, launch the app from the command line (with program containing equivalent of PAUSE)
4) In MS VS use Debug | Attach to process
5) then debug as usual
Jim Dempsey
jirina
Thank you, I know about oneAPI, but I had no idea that it is a replacement for Parallel Studio.
