29647 Discussions
Restricting screen output while RUNQQ
Anonymous42
I'm calling one applicationby RUNQQ. The application would provide some output to the console window.
Is there a way to restrict such output while the application is running?
Thank you.
Jugoslav_Dujic
Valued Contributor II
Notusing RUNQQ, but you can control it using CreateProcess. See this Steve's article on CreateProcess -- pay attention to DETACHED_PROCESS and/or CREATE_NEW_CONSOLE flags, as well as wShowWindow -> SW_HIDE (if you want to hide the other console completely).
Jugoslav
milan77
Say that I have a QuickWin application andopen two windows (unit 1 and 2). The program that is run by RUNQQ provides an output. The output is automatically directed into a standard console window. Is there a way to direct the output to one of the two QuickWin windows?
Thank you for your advice on this,
Milan
Not with RUNQQ. You could do it with CreateProcess by sending the output to a "pipe" which you then read in a thread in the QuickWin application and wrote to the "terminal". Not difficult, but not trivial either.
milan77
Can I askyou to write mea short code that would do this:
Say there is a standard fortran console .exelocated in a C directory. When run, it writes "hello world" to the screen.
I want to use theQuickWin application to run this .exe and write the output to the QuickWin window, say unit 1.
In my case, I can't determine exactly the length of lines and the number of lines that the .exe reports, butI want all output directed to the QuickWin window.
I very appreciateyour help,
Thank you,
Milan
No, sorry, I won't be able to write you such code. Perhaps someone else is willing to offer.
