29651 Discussions
Returning chars from static C libraries
Robin_C_
 Hello there,
Sorry if my post is a little basic and/or makes no sense. I have only just started working with Fortran. I'm trying to call a C function which populates resultValue with the return value. This is how it looked:
extern "C" void sqlSelect(char*resultValue,intlength,char*dataBase,char*query,intreturnValue)
I was able to get data from this with the following:
cSelectReturn=SQLSELECT(cFile//CHAR(0), TRIM(cSelectQuery))
Now, I since I probably should use an interface I've changed it a bit:
void sqlSelect(char*resultValue,char*dataBase,char*query,intreturnValue)
INTERFACE
SUBROUTINESQLSELECT(resultValue, dataBase, query, returnValue) BIND(C, NAME="sqlSelect")
USE iso_c_binding,ONLY: c_char, c_int
CHARACTER(kind=c_char) :: resultValue(*)
CHARACTER(kind=c_char) :: dataBase(*)
CHARACTER(kind=c_char) :: query(*)
INTEGER(kind=c_int) :: returnValue
END SUBROUTINESQLSELECT
END INTERFACE
CALL SQLSELECT(cSelectReturn, cFile//CHAR(0), TRIM(cSelectQuery),iReturnValue)
Now I get an unhandled exception returning from the call.
Using an INTERFACE, how does one return one (and more) parameters, without it blowing up in one's face?
I will be the first to admit that I am not a C expert, but something seems wrong in your problem description.  The C declaration of the procedure doesn't match how you're calling it from C, and what you typed would not even compile, I think. What is the real C declaration of that routine?
Robin_C_
Ah, sorry. I was ctrl-z'ing my way back and didn't go far enough. The working example, from memory as I'm on the bus, would have been:
extern "C" void sqlSelect(char* resultValue, int vLength, char* dataBase, char* query)
It worked fine without using an interface. From what I understand, the first 2 parameters are handled automatically as the return for the function. So if you so "something = CALL(....)", the "something" can be automatically added as the first parameter with it's length as the second.
The problem I have is that I want to have multiple return values from the function, so I can't do the above.
Robin_C_
It turns out, I was managing to return more data than expected, causing a problem between the two.
For reference:
.cpp:
extern "C"
void sqlExec(char*dataBase,char*query,intreturnValue)
<code>
.FOR
INTERFACE
SUBROUTINESQLEXEC(dataBase, query, returnValue)BIND(C, NAME="sqlExec")
END SUBROUTINE SQLEXEC
END INTERFACE
INTERFACE
Works a treat. Just need to get some decent safeguards for the variable sizing and so on.
