Rounding issue with output formats
Arjen_Markus
we ran into a small but annoying problem with formatted output. Here is
an illustration of the issue (note that all numbers are exactly representable):
PROGRAM checkrounding
write (*,'(4x,f8.1)') 0.25
write (*,'(4x,f8.2)') 0.125
write (*,'(4x,f8.3)') 0.0625
write (*,'(4x,f8.4)') 0.03125
end
This program produces:
0.2
0.12
0.062
0.0312
Apparently this is "round to even".
If I compile this program with gfortran I get:
0.3
0.13
0.063
0.0313
And this rounding mode is more in line with theoriginal program (we do not know
with what compiler it was compiled).
The question is: howcan we getthis round-up mode? Should I use ieee_arithmetic for this?
Or is there a compile option?
Arjen
mecej4
I don't think so. Rather, it is the "round to nearest or even" rule that I learned in school in the 1950s. The second part of the prescription comes into play when the part being rounded off is 5 X 10^{-n}.
Arjen_Markus
Right, sothat is the proper name?
I tried the following variation to see if the Fortran 2003 IEEE modules could solve this:
use, intrinsic :: ieee_arithmetic
call ieee_set_rounding_mode( ieee_nearest )
end
(By the way: The online documentation mentions ieee_exceptions as the module for this,
but that leads to an unresolved external!)
The result is slightly "better", but also more confusing:
0.2
0.12
0.063
0.0313
Arjen
What usage led to an unresolved external?
The default is "round to nearest". A good explanation of this can be found here.
Arjen_Markus
I used the statement:
use, intrinsic :: ieee_exceptions
in accordance with the online help (the following copied from there):
IEEE_SET_ROUNDING_MODE
Intrinsic Module Subroutine (Generic): Sets the IEEE rounding mode.
Module
USE, INTRINSIC :: IEEE_EXCEPTIONS
Syntax
CALL IEEE_SET_ROUNDING_MODE (round_value)
round_value
(Output) Must be scalar and of type TYPE (IEEE_ROUND_TYPE). It specifies one of the following IEEE floating-point rounding values:
IEEE_DOWN, IEEE_NEAREST, IEEE_TO_ZERO, IEEE_UP, or IEEE_OTHER.
Now that I looked at it again, the example uses "use ieee_arithmetic".
Arjen
Arjen_Markus
Oh dear, I have been confusing myself:
- The version where the last digit is always 2 was produced on Linux, using Intel Fortran 12.0.3
- The version that produces both 2's and 3's was produced on Windows, using Intel Fortran 11.1.065
There is NO influence of the rounding mode on the result. I have tried all five- on Windows - and the result
remains the same.
Arjen
Thanks for pointing this out. I have alerted our writers to the error. Other routines with the wrong module mentioned are IEEE_GET_FLAG and IEEE_GET_UNDERFLOW_MODE.
