Is it possible to change (further specialize), on-the-fly, the type of a variable to one of its extended (children) types, without resorting to a copy ?
MODULE M IMPLICIT NONE TYPE :: T_BOOK CHARACTER(LEN=:),ALLOCATABLE :: TITLE END TYPE T_BOOK TYPE,EXTENDS(T_BOOK) :: T_ENCYCLOPEDIA INTEGER :: N_VOLUMES END TYPE T_ENCYCLOPEDIA CLASS(T_BOOK),ALLOCATABLE :: MY_BOOK END MODULE M
Using the example above... would it be possible to have a code that allocates first MY_BOOK to type T_BOOK; and then later on specializes MY_BOOK as actually being of type T_ENCYCLOPEDIA (while keeping its T_BOOK component values)?
This can be achieved with a temporary variable and tediously copying the values of the components of the parent type into the components of the child type... Not sure if there is another way.
No, it isn't possible. A copy is required. It doesn't have to be tedious - there is already a single component for the parent type, or you can use defined assignment.
You can, sort of, go the other way by passing something allocated as T_ENCYCLOPEDIA to an actual argument declared as CLASS_T_BOOK, but that's not what you're looking for.
OP wrote:..
With the example in the original post, yes. Note Fortran standard stipulates the parent type is essentially a component of the extension type with the same name as the type. So you can use this fact along with the default structure constructor available for the types and also with intrinsic assignment facility for polymorphic objects to do the following:
program p use m, only : T_BOOK, T_ENCYCLOPEDIA, MY_BOOK implicit none MY_BOOK = T_BOOK( TITLE="Encyclopaedia Americana" ) call out() print "(/,g0)", "Following 'MY_BOOK = T_ENCYCLOPEDIA(T_BOOK=MY_BOOK, M_VOLUMES=13)' assignment" ! Reconstruct the object as type T_ENCYCLOPEDIA using the values in the existing object MY_BOOK = T_ENCYCLOPEDIA(T_BOOK=MY_BOOK, N_VOLUMES=13) call out() contains subroutine out() select type ( MY_BOOK ) type is ( T_BOOK ) print *, "MY_BOOK is of type T_BOOK and has the title:" print *, MY_BOOK%TITLE type is ( T_ENCYCLOPEDIA ) print *, "MY_BOOK is now of type T_ENCYCLOPEDIA and has the title:" print *, MY_BOOK%TITLE print *, "with", MY_BOOK%N_VOLUMES, " volumes" class default print *, "Unknown type pf MY_BOOK" end select return end subroutine end program p
With Intel Fortran 19.0 Update 4, the program output is:
MY_BOOK is of type T_BOOK and has the title: Encyclopaedia Americana Following 'MY_BOOK = T_ENCYCLOPEDIA(T_BOOK=MY_BOOK, M_VOLUMES=13)' assignment MY_BOOK is now of type T_ENCYCLOPEDIA and has the title: Encyclopaedia Americana with 13 volumes
Thank you Steve and FortranFan. I had forgotten about the feature that says that a parent type is a component of its extended types; line 11 of FortranFan's code is a great reminder. There is still a temporary copy made during that assignment, but at least I don't have to code it explicitly, ha ha.
