SIGILL
jansson
Hi
One of our customers get SIGILL when they run our program. Not immediately on starting the program but after a while when they start to do some actual calculations.
Its a Mac OSX
OS architecture: x86_64
OS version: 10.11.6
sysctl -a | grep machdep.cpu
Gives among other things:
machdep.cpu.brand_string: Intel(R) Xeon(R) CPU           E5462  @ 2.80GHz
machdep.cpu.features: FPU VME DE PSE TSC MSR PAE MCE CX8 APIC SEP MTRR PGE MCA CMOV PAT PSE36 CLFSH DS ACPI MMX FXSR SSE SSE2 SS HTT TM PBE SSE3 DTES64 MON DSCPL VMX EST TM2 SSSE3 CX16 TPR PDCM SSE4.1
machdep.cpu.extfeatures: SYSCALL XD EM64T LAHF
Program is compiled with:
-march=corei7 -axSSSE3
Ifort 16.0.4
I am a bit surprised by the crash since CPU supports SSSE3 and is an Intel CPU.
Any idea of what to try or investigate to get it working?
Cheers,
Magnus
jimdempseyatthecove
-axSSSE3 specifies the compiler is to generate multiple (additional) code paths including SSSE3.
-march=corei7 Specifies the compiler is to generate code for all corei7, which includes SSE4
Try:
    -xSSSE3       (no march and not "ax")
You could also have an issue with data alignment.
Jim Dempsey
jimdempseyatthecove
Try:
Jim Dempsey
jansson
Thank you Jim,
"-xSSSE3       (no march and not "ax")" worked.
I also found that "-march=core2 -axSSSE3" work.
Cheers,
Magnus
