29651 Discussions
SYSTEM command causes a segmentation fault
Kate_Johnson
I recently switched to a new Intel compiler and subsequently changed from this command:
I1 = SYSTEM("./Simulation < simu.dat")
to this:
CALL SYSTEM("./Simulation < simu.dat", I1).
It compiles fine now but I get this error
 MPI: bl0.psc.teragrid.org: 0x24ec000052496c5b: forrtl: severe (174): SIGSEGV, segmentation fault occurred.
Any thoughts on what I'm doing wrong?
Why did you make that change? It is incorrect. In particular, what you did was make the SYSTEM routine think that the address of variable I1 was the length of the command string. Go back to what you had before. As an aid to correctness, add:
USE IFPORT
to the program unit that calls SYSTEM or other portability routines.
