29640 Discussions
Scoping issue with integer type-spec in implied do
Harald1
New Contributor II
Ifort rejects the following code, although it should be valid F2018:
program foo
  use iso_fortran_env, only : k => real_kinds
  implicit none
! integer(8) :: i ! OK
  real(8)    :: i ! not OK
  integer, parameter :: n = size(k)
  integer, parameter :: q(n) = [(kind(i), integer(2) :: i = 1, n)]
  print *, q
end program foo
I get:
ifort_implied_do_index.f90(7): error #6325: An integer data type is required in this context.   [I]
compilation aborted for ifort_implied_do_index.f90 (code 1)
Commenting the declaration of i, or activating the integer variant, make the code compile and execute correctly.
The Cray compiler 14.0 accepts the code as expected.
Harald
Barbara_P_Intel
Can't argue with the Fortran experts on this Forum! I filed a bug report, CMPLRLLVM-42129. I'll let you know when it's fixed.
Steve_Lionel
I agree that ifort has a bug here. I even helped write this part of the standard.
FortranFan
@Harald1 ,
Re: "Commenting the declaration of i, or activating the integer variant, make the code compile and execute correctly," are you sure about the "execute correctly" part?  I have several support requests open with Intel for a while now about the resulting named constant array, "q" in your case, having unexpected values.
Harald1
New Contributor II
The above testcase appears to execute correctly, but it doesn't test much.
I believe you thought about code like:
program foo
  implicit none
  print *, [(precision(real(1,kind=k(i))), integer :: i = 1, n)]
end program foo
This erroneously prints:
           6           6           6
You will likely expect e.g. "6 15 31", which I can get with a small modification from NAG.
FortranFan
@Harald1 ,
Yes,  I didn't read your code carefully enough, I simply presumed it was similar to
   use iso_fortran_env, only : ik => integer_kinds
   integer, parameter :: q(*) = [( kind(int(1,kind=ik(i))), i = 1, size(ik) )]
   print *, q
end
and for which the Intel Fortran compiler output is unexpected:
C:\temp>ifx /standard-semantics p.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2022.2.0 Build 20220730
Copyright (C) 1985-2022 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.33.31630.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
p.obj
C:\temp>p.exe
 1 1 1 1
C:\temp>
I suspect the output of the program with NAG compiler of the same code will be different? and perhaps along the lines of "1 2 3 4"?
But of course with a Fortran 2018 processor, I would have the same line as follows but it appears from the NAG website, that compiler doesn't yet support the topic of your title, the type-spec in the implied-do so you may not be able to test that aspect with NAG yet.
   integer, parameter :: q(*) = [( kind(int(1,kind=ik(i))), integer :: i = 1, size(ik) )]
Harald1
New Contributor II
Well, it depends...
With default options I get your expected "1 2 3 4", but with -kind=byte I obtain "1 2 4 8".
Barbara_P_Intel
Barbara_P_Intel
The invalid error message is gone! Try the new ifort and ifx that are part of oneAPI HPC Toolkit 2023.1. It was released this week.
Harald1
New Contributor II
The scoping issue is indeed resolved.
The other issues referred to by @FortranFan seem to be still open; likely tracked elsewhere.
Harald
