29649 Discussions
Scratch file error at runtime - Mac OS X
roktengr
Hi.
I just bought Intel Fortran to port some old code to OS X, and I am pretty rusty with Fortran. I am using it in the Xcode GUI. After a few bug fixes, the program works fine as long as "generate debug information" is selected in the build settings.
If I deselect it, and keep optimization at "O0" or any other setting, I get this error:
forrtl: No such file or directory
forrtl: severe (29): file not found, unit 1, file /build/Release/fort.1
Unit 1 is a scratch file (~17MB), which has no problem with the debug info setting. It also originally was a named, unknown, unformatted file, and the same error occurs (it was never named fort.1).
I had buffered IO set on and off, no difference.
OS X 10.5.2, Xcode 3, ifc 10.1.014, Mac Pro Jan 2008, 10GB
Thanks in advance for any help.
Jim
Ron_Green
Jim,
Hard to say what is happening here. It appears your OPEN(UNIT=1....) statement was not in the code execution path and your code hit a READ(1, ....) statement.
Can you replicate this behavior outside of Xcode? Fortran Xcode integration is a "Preview Feature" - this means that it may have a few glitches.
From the command line, compile with:
-warn all -check all -g -traceback
This will give maximum compile-time warnings plus maximum runtime messages and give a stack trace if it aborts.
ron
Bonnie_A_Intel
A small correction to the recommended build command -- you must add the "-savetemps" option to ensure the symbol information is generated for access by the debugger:
-warn all -check all -g -savetemps -traceback
roktengr
Thank you both! After using the suggested commands in terminal, I found that a couple of REAL arrays used in the scratch file were not initialized large enough - 9000 given, 40000 needed. It is amazing the code worked at all before.
I am really new at using debugging tools. I learned Fortran back in the CIBER days. Thanks much. :-)
Jim
roktengr
MAD wgreen:
Jim,
Ron,
I obtained the same file error outside of Xcode as well, for the record. The "-check all" caught the error on the array bounds.
I do hope that Intel Fortran code folding makes it into Xcode GUI in the future. The build settings in Xcode also made it easy to discover many of the compile options.
Jim
