28872 Discussions
Segmentation fault when calling a subroutine
Kate_Johnson
I am calling the lapack subroutine DLAPMT in the following snippet of my code:
c    Permute matrix c_all according to IPERM1
    do i=1, n_sources
        do k=1,g_layers
            do l=1,n_layers
            call DLAPMT (.TRUE., nsim, ndim, c_all(:,:,i,k,l), nsim, IPERM1)
            enddo
        enddo
    enddo
In this case n_sources is 2, g_layers is 1 and n_layers is 1.  Therefore it should call DLAPMT twice.  The first time it works fine.  The second time it reaches DLAPMT, it kills the process due to a segmentation error. I've checked and all the inputs are exactly the same the second time around.  What could be causing this problem?
Is the LAPACK library you're calling the one from Intel MKL or something else? You say "segmentation fault", which is a Linux term - are you using Windows (this forum) or Linux? What happens if you add /heap-arrays (-heap-arrays) to the compile options?
Kate_Johnson
I'm using Linux, sorry about that.  It is from the Intel MKL library.  I'll try the heap-arrays option
Kate_Johnson
That worked, thanks!
Ok - looks as if you're getting a stack overflow and the compiler is creating a stack temp and not removing it, but I don't think it should need a temp here. Can you provide me with a small but complete source that shows the problem?
