I want to set the focus of an edit box on a simple dialog project.
I can't see anything to do with this in the SetDlg function.
How do you do it?
David
How do you do it?
David
There's no DlgSet equivalent, but you can use SetFocus(GetDlgItem(Dlg%hWnd), idControl), or, better, WM_NEXTDLGCTL.
Jugoslav
Jugoslav
Thanks, I have used the SetFocus function.
If the ID is a button then the button is highlighted - but the ID is an edit box - I expect the cursor to be placed at the first character of the edit box ready for typing but nothing appears to happen. Is there something more I have to do?
David
David
From where are you calling SetFocus? This will work only when called from a callback routine (if the dialog is modal) or after DlgModeless (if it's modeless).
Jugoslav
Jugoslav
It is being called from a callback routine from a modal dialog box - I think I have the termonology right.
SUBROUTINE IsoCheck(dlg,id,callbacktype ) !----------------------------------------- !Dialog box callback for Iso Check use dfwin use dflogm use Vol99Globals include 'resource.fd' type (dialog) dlg integer*4 id,callbacktype,iret logical*4 lret if (callbacktype == dlg_clicked) then lret = DlgGet(dlg, id, iso) lret = DlgSet(dlg,IDC_JOB3,iso,dlg_enable) if (iso) then iret=SetFocus(GetDlgItem(dlg%hwnd,IDC_JOB3)) end if endif END SUBROUTINE IsoCheck
Hmph... don't have time to try this at the moment, but that IMO should have worked.
Still, try Send/PostMessage(Dlg%hWnd, WM_NEXTDLGCTL, 1, GetDlgItem(Dlg%hWnd, IDC_JOB3)) instead. If I recall correctly, that will also select the text within the control, if any.
Jugoslav
Jugoslav
That didn't work either.
Looking back over all the work I have done, SetFocus has never worked for a Edit Box in a simple dialog application, but is OK on a API application.
There must be something missing in my initialisation.
David
David
Topic Options
