Setting the value to CLASS(*)
ScottBoyce
Hi All,
I am trying to create a derived data type that can at run time take on different values. The follow is a snipit of code:
[fortran]
PROGRAM TEST
TYPE FLEXIBLE
  CLASS(*),         ALLOCATABLE:: VAL
END TYPE
TYPE(FLEXIBLE)::A
CLASS(*),         ALLOCATABLE:: B
INTEGER:: I
!IT SEEMS LIKE TH FOLLOWING SHOULD WORK:
I=5
ALLOCATE(A%VAL,SOURCE=I)
ALLOCATE(B,SOURCE=I)
A%VAL=10
B=50
END PROGRAM
[/fortran]
When I try to set the value to a new value, I get a compiler error. Even if I remove the A%VAL= and B= they do not seem to hold the value of I.
On a side note, what does MOLD do within an ALLOCATE statement.
Thanks as always for your help.
You need a SELECT TYPE construct - for an unlimited polymorphic item, you can access it as a typed variable only inside a SELECT TYPE (with appropriate TYPE IS block.)
PROGRAM TEST
TYPE FLEXIBLE
END TYPE
TYPE(FLEXIBLE)::A
INTEGER:: I
I=5
SELECT TYPE (AVAL=>A%VAL)
TYPE IS (INTEGER)
PRINT *, AVAL
AVAL = 10
PRINT *, AVAL
END SELECT
SELECT TYPE (B)
TYPE IS (INTEGER)
PRINT *, B
B = 50
PRINT *, B
END SELECT
END PROGRAM
MOLD= specifies the type, type parameters and shape but not the value. SOURCE= does all that plus copies the value.
ScottBoyce
Thank you so much, it is a shame you can not directly access it, but it clears up a lot of the problems I have been having.
My only question is what would be the keyword for DOUBLE PRECISION or be distinguish between different REAL precision and how would they be applied with a MOLD= statement.
[fortran]
PROGRAM TEST
ALLOCATE(B,MOLD=REAL)
SELECT TYPE (B)
TYPE IS(REAL)
B=50.
WRITE(*,*) B
END SELECT
END PROGRAM
[/fortran]
You would use:
TYPE IS (REAL(8))
Your use of MOLD= is not correct - you put another variable there. You can do this instead:
ALLOCATE (REAL(8)::B)
