29649 Discussions
Stack overflow prevention using -heap_arrays
johntylor
Will optimization parameters like: -O3 -no-prec-div -ipo -axP
disable the -heap_arrays parameter?
- JT
Ron_Green
Just to make sure, use "-heap-arrays" with a dash and not an underscore.
Those other arguments will have no affect on -heap-arrays. However, they may have other effects that cause unrelated anomalies. You can add
-g -traceback
along with optimizations. This to give you the location of any aborts.
ron
johntylor
Thank you Ronald.
- JT
