29655 Discussions
Stack overflow when calling a subroutine
turkeydodo
I got error message below when calling a subroutine
CALL COMPPR(MODEL,NUMEL,NUMNOD,MAP,AREA,C3,INDPER)
forrtl: severe (170): Program Exception - stack overflow
The subroutine is below
MODULE Interface_COMPPR
    INTERFACE
        SUBROUTINECOMPPR(MODEL,NE,NQ,NodeIndex,AREA,C,INDPER)
            IMPLICIT NONE
            !input variables
            INTEGERNE,NQ
            CHARACTER*1 MODEL
            INTEGER, POINTER:: NodeIndex(:,:)
            INTEGER, POINTER:: INDPER(:)
            REAL, POINTER:: AREA(:)
            !output variables
            REAL, POINTER:: C(:,:)
        END SUBROUTINE
    END INTERFACE
END MODULE
This issue is occured only when using x64 compiler. No error message when using win32 compiler.
Could you provide any clue on this issue? Thanks!
turkeydodo
Appendix to this issue:
This error is only occured when using x64 complier. It passes when uing win32 compiler.
Please provide a small but complete program that demonstrates the problem. You haven't shown the actual routine, by the way, just an interface block for it. Typically, if you have an interface block for a Fortran subroutine, other than what's needed for a generic declaration, you're doing it wrong.
TimP
Does /check:arg_temp_created show anything?  If so, you would expect the point where you need to set stack higher (if not using /heap-arrays) to be different for Intel64 than for ia32.
If you already set stack parameters, you can expect to need larger ones for X64.
turkeydodo
I got the reason. I forget add the link option of "/STACK:10000000" in x64. Thanks!
