29422 Discussions
Strange result with Bessel functions
Arjen_Markus
in response to this post in comp.lang.fortran (http://groups.google.nl/group/comp.lang.fortran/browse_frm/thread/451dd609b24f2585?hl=nl#), I tried the following program using Intel Fortran 11.0:
! bessel.f90 --
! Posting by "steve" on clf
program testjn
integer, parameter :: dp = kind(1.d0)
real(dp) z
z = 2.4048255576957729_dp
print *, besjn(3,z)
do i = 1,10
z = 2.1 + i/10.0
print *, z, besjn(1,z), besjn(2,z), besjn(3,z)
enddo
end program testjn
The results were astonishing (this is the result on Linux):
6.7595576E-33
2.19999980926514 0.0000000E+00 0.0000000E+00 0.0000000E+00
2.29999995231628 -9.7165255E-11 -8.8399815E-11 9.7165255E-11
2.39999985694885 5.4210109E-20 0.0000000E+00 0.0000000E+00
2.50000000000000 0.0000000E+00 0.0000000E+00 0.0000000E+00
2.59999990463257 -0.5767248 0.3528340 -0.1289432
2.69999980926514 0.0000000E+00 0.0000000E+00 0.0000000E+00
2.79999995231628 -9.7165255E-11 -8.8399815E-11 9.7165255E-11
2.89999985694885 5.4210109E-20 0.0000000E+00 0.0000000E+00
3.00000000000000 0.0000000E+00 0.0000000E+00 0.0000000E+00
3.09999990463257 -0.5767248 0.3528340 -0.1289432
As the Bessel functions are smooth, oscillating functions, it is clear
this is incorrect.
If this problem has been solved in Intel Fortran 11.1, then I apologise for the noise.
Arjen
IDZ_A_Intel
Arjen,
On Windows Vista I changed your code to fix compiler errors :
program testjn
use ifport
real(dp) z
integer i
print *, dbesjn(3,z)
do i = 1,10
z = 2.1 + i/10.0
print *, z, dbesjn(1,z), dbesjn(2,z), dbesjn(3,z)
enddo
end program testjn
and got the following using V11.1.060
-Infinity
2.19999980926514 0.555963076969823
0.395058649918586 0.162325439701542
2.29999995231628 0.539872541148635
0.413914583151530 0.179978922734544
2.39999985694885 0.520185298828659
0.430980017151422 0.198114772571065
2.50000000000000 0.497094102464274
0.446059058439617 0.216600391039114
2.59999990463257 0.470818293019128
0.458972840487571 0.235293795169479
2.69999980926514 0.441601437484153
0.469561484839453 0.254045255864694
2.79999995231628 0.409709262652801
0.477685492135148 0.272698594875890
2.89999985694885 0.375427532420198
0.483227044458551 0.291092561780032
3.00000000000000 0.339058958525937
0.486091260585891 0.309062722255251
3.09999990463257 0.300921170211927
0.486207015384473 0.326442739906775
Les
Arjen_Markus
Hi Les,
I thought besjnwas the generic name. I tried your changes with Intel Fortran 11.0 and got all the results I expected to see - including the correct value for besjn(3,2.4048...).
I have seen the -Infinity value you get with an old version of gfortran under Linux. So there is something funny going on.
Arjen
The Bessel functions are not generic - at least not in the current version. Please read the Intel documentation.
Melvin_Robinson
How can we set the compiler options or modify the program to get the above program to give the correct values? Just wanted to know because I'm just learning about Bessel functions in an emag class that I am taking.
Reply 1 has the corrected code.
Arjen_Markus
Yes, they are not part of the Fortran 95 or 2003 standard, so that figures.
I have grown so used to such functions being generic, that I did not even think about that ;)
Arjen
Fortran 2008 has Bessel functions (with different names from what C uses.)
