29642 Discussions
Structure constructor with pointer component silliness
IanH
The compiler complains that the component spec in the structure constructor is not of the same type and kind as the component.  But it is... isn't it?
MODULE m
  IMPLICIT NONE
  TYPE, PUBLIC :: NodeRef
    TYPE(Node), POINTER :: item => NULL()
  END TYPE NodeRef
    TYPE(NodeRef), ALLOCATABLE :: upstream(:)
  END TYPE Node
CONTAINS
  SUBROUTINE s(self)
    TYPE(Node), INTENT(INOUT), TARGET :: self
    self%upstream = [NodeRef(self)]
  END SUBROUTINE s
END MODULE m
>ifort /c /check:all /warn:all /standard-semantics "2015-09-24 nodes.f90"
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0 Build 20150815
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
2015-09-24 nodes.f90(17): error #6795: The target must be of the same type and kind type parameters as the pointer.   [SELF]
compilation aborted for 2015-09-24 nodes.f90 (code 1)
Yuan_C_Intel
Hi, IanH
Yes, you are correct. This is a known issue in compiler. You may find a similar discussion before:
http://software.intel.com/en-us/forums/topic/375845
I have added your case in our existing record DPD200248768. We will let you know if any update.
