Support for .NET?
Olaf_Meding
Does the Intel Fortran compiler support .NET programing, ie generate managed code that can be called from C#?
Thank you for your help.
Olaf
Intel Visual Fortran supports calling and being called by managed code applications. It does not generate managed code itself.
When calling Fortran from managed code, you can call a native DLL using standard methods for doing so. Another option is to use the COM Server Wizard to create a COM server DLL which will then appear in the managed code space - this requires advanced coding.
.NET assemblies can be called from Fortran using the "Intel Module Wizard" which generates interfaces and wrapper procedures for calling into managed code.
Olaf_Meding
Yes this answers my question. Thank you.
Olaf
