29382 Discussions
Switch from GNU to Ifort both under Linux
Sandra_M_
Hi there,
I actually run simulations with ABAQUS Standard 6.14-1.
Thereby I use some subroutines written in a combination of Fortran 77 and free-format (unlimited length of lines). In general Subroutines should be written in Fortran 77, but on the actual machine it works good.
Because of performance limit I’d like to change the machine.
The actual machine is a Debian Version 4.6.3-14 – Compiling with GNU Version 4.7.2-5.
The new one is called RedHat5 – Compiling with Intel Fortran 64 XE Version 12.0.
Both use Linux as operating system.
The “simple” task is now to switch the environment in that way, that it works the same way using the Intel Fortran Compiler instead of GNU Fortran.
Details of the actual/old system
excerpt of the environment-file
compile_fortran = [fortCmd,
'-c', '-fPIC', '-extend_source', '-O2', '-I%I', '-ffixed-line-length-none', '-fno-align-commons',
'-std=f2008', '-frecursive']
excerpt of one Subroutine (subroutine.f)
(this is the third one of 9, but the first that makes trouble) --> Uploaded 1 & 2:
Line 140 is the first one that makes troube on the “new machine” using the environment-file below.
I tried a word-wrap by using & at the end or beginning of a line (column 5 and further), $ or 1 but it doesn’t work at all. Further I tried to shift the whole subroutine in that way, that the first word starts at column 6 as prescribed in Fortran 77… but that works less.
Details of the new system
                  '-V',
                  '-c', '-fPIC', '-auto', '-mP2OPT_hpo_vec_divbyzero=F', '-extend_source',
                   '-WB', '-I%I']
Via trial and error I migth exclude “-free” , “-frecursive” (isn’t supported), “assume cc_omp”,
Typical error-massages:
/tmp/2198878.1.abax18/U_Data_Calculate.f(140): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT> <INTEGER_CONSTANT> ...
          IF ( NR .EQ. PHASE_FERRITE)     Data_Density_Jablonka   = (rhoF0  +  rhoF1*TEMP +  rhoF2*TEMP*TEMP) *
/tmp/2198878.1.abax18/U_Data_Calculate.f(141): error #5082: Syntax error, found '(' when expecting one of: BLOCK BLOCKDATA PROGRAM MODULE TYPE BYTE CHARACTER CLASS DOUBLE DOUBLECOMPLEX ...
    1     (1.0 - rhoFC*cC)
/tmp/2198878.1.abax18/U_Data_Calculate.f(142): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT> <INTEGER_CONSTANT> ...
          IF ( NR .EQ. PHASE_CARBIDE)     Data_Density_Jablonka   = (rhoK0  +  rhoK1*TEMP +  rhoK2*TEMP*TEMP) *
/tmp/2198878.1.abax18/U_Data_Calculate.f(143): error #5082: Syntax error, found '(' when expecting one of: BLOCK BLOCKDATA PROGRAM MODULE TYPE BYTE CHARACTER CLASS DOUBLE DOUBLECOMPLEX ...
    1      (1.0 - rhoKC*cC - rhoKCr*cCr - rhoKMn*cMn)
Furthermore a colleague who works with Damask gave me an environment that might help
compile_fortran = (fortCmd + " -c -fPIC -auto " +
                   "-I%I -free -O1 -fpp -openmp " +
                   "-ftz -diag-disable 5268 " +
                   "-implicitnone -assume byterecl " +
                   "-real-size 64 -integer-size 32 -DFLOAT=8 -DINT=4")
…  but I can’t transfer it because he uses another Fortran style… excerpt of his routine:
!*** input/output variables
type(p_vec), dimension(1,mesh_maxNips,mesh_NcpElems), intent(inout) :: &
                               state                           !
microstructural state
!*** local variables
integer(pInt)            ipc, &
                               el, &
                               ip, &
                               e, &
                               i, &
                               ns, &
! short notation for total number of active slip systems
                               f, &
! index of lattice family
Up to the present or a few weeks ago – I work on it since 3 weeks - I never mind about details in the environment and the compiling process.  Thus or nevertheless I’m no specialist in this kind of stuff.
Since I work on it for a certain time, but without having achieving the switch, I hope someone might help me.
Kind regards
Sandra
Sandra_M_
Second try to upload excerpts of a Subroutine.
mecej4
Extracting text from image files (such as .PNG) is time-consuming and error-prone. Do not use image files for program text.
Please post the source code again. Zip up the files and attach the zip file, or use the "{...}" code button for short segments of source code.
Sandra_M_
Ok.
I append as well the environment of the new and old machine as an excerpt of the subroutine.
Lorri_M_Intel
With ifort, the -extend-source switch extends the line out to 132 characters.
At least two of your lines are much longer than that.
I converted the lines to look like this instead, and while I can't compile the program (it's missing a .mod file) it doesn't give the syntax error you saw.    Note: even here, the lines wrap, at least in my browser.
          IF ( NR .EQ. PHASE_FERRITE)     then
                Data_Density_Jablonka   = (rhoF0  +  rhoF1*TEMP +  rhoF2*TEMP*TEMP) * (1.0 - rhoFC*cC)
          endif
          IF ( NR .EQ. PHASE_CARBIDE)     then
                Data_Density_Jablonka   = (rhoK0  +  rhoK1*TEMP +  rhoK2*TEMP*TEMP) * (1.0 - rhoKC*cC - rhoKCr*cCr - rhoKMn*cMn)
          endif
          IF ( NR .EQ. PHASE_AUSTENITE)  then
                 Data_Density_Jablonka   = (rhoA0  +  rhoA1*TEMP +  rhoA2*TEMP*TEMP) * (1.0 - rhoAC*cC - rhoACr*cCr - rhoAMn*cMn)
          endif
Sandra_M_
Hi Lorri,
Thanks a lot! I guess I just needed someone who helps me "thinking outside the box". :)
'll try to change this routine either by inserting "then" or by changing the name of some long variables temporarily.
Report about result follows.
Sandra_M_
Sry for the late answer.
It didn't succeed because there are some blocks that cannot be splitted.
As for instance :
           CALL CALC_YIELDING( E_IN_PL, DE_IN_PL, TEMP, DTEMP, DTIME, NDI, NSHR, NTENS, STRESS, STRAN_EL0, DSTRAN, DSDE, DEDT, STATEV, NSTATEV)
Therefore I'm still looking for a linux machine with an GNU Compiler (V 4.4.x)...
If there is anybody who had solved a similar problem, please let me know!
Best regards
Lorri_M_Intel
Hi Sandra -
Again, yes, this can be broken up; you need to use a continuation character, which is a non-blank character in column 6 (for fixed form source, such as you have)
You statement above can be rewritten as:
     & NDI, NSHR, NTENS, STRESS, STRAN_EL0, DSTRAN, DSDE, DEDT,
     & STATEV, NSTATEV)
It is hard to see here, but the "&" is in column 6.  It's important that you actually put it there, because that's how it works with fixed form source.
               --Lorri
