Syntax highlighting anomally
andrew_4619
I very minor issue that confused me for a short while. The red number in the attachment should not be red it is triggered by a "!" comment after and "&" on the previous line,
The Versions are:
Microsoft Visual Studio 2010 Version 10.0.40219.1 SP1Rel
Intel(R) Visual Fortran     Package ID: w_fcompxe_2013_sp1.1.139Intel(R) Visual Fortran Composer XE 2013 SP1 Update 1 Integration for Microsoft Visual Studio* 2010, 14.0.0074.2010, Copyright (C) 2002-2013 Intel Corporation
Martyn_C_Intel
 I'm escalating that to the development team as a low priority bug. (As you say, it's quite minor).
Thanks for reporting; if we don't hear about the little blemishes, we can't fix them.
Martyn_C_Intel
A fix for this issue is planned for a future compiler version.
andrew_4619
IanH
On the topic of syntax highlighting anomalies, character strings split over multiple lines using line continuation get muddled up.
Martyn_C_Intel
I can reproduce that.  The highlighting is correct if the second continuation character is in column 1, but not if, as above, there are leading blanks. I'll forward this case to the developers, also.
Thanks for reporting it.
DavidWhite
Valued Contributor II
Martyn,
Highlighting is also incorrect if the first character is a tab (and not converted to blanks).
David
Martyn_C_Intel
The highlighting issue for strings that are split between continuation lines is expected to be fixed in the next major compiler version.
I've informed engineering of the variant with a leading tab instead of leading blanks, but I expect that the fix that takes care of one should also take care of the other.
