Tab Control
John4
Valued Contributor I
This question is more about the VS2005 IDE than IVF, but...
I'm trying to use the tab control from a dialog box, and I want to know if it's possible to add the controls for each tab strip during design (as opposed to adding them at run-time). I tried with a VC++ application as well, with no success. With VB, on the other hand, it works. Is it a ".NET Framework only" feature? If no, what should I do to make it work from a dialog-based application (IVF)?
John.
Jugoslav_Dujic
Valued Contributor II
The normal way to do it is to
  • for each tab page, create a separate dialog which is borderless and has WS_CHILD and DS_CONTROL styles
  • in run-time, create those dialogs as modeless and attach the dialogs to the tab control
There is "Using Tab Controls" page in IVF compiler documentation, which gives a good overview. There is/used to be sample called SHOWFONT, which you can also take a look at.
John4
Yeah, that's the CVF way. I just wanted know if there was another way to do it.
Thanks for the reply, anyway.
John.
