The Copyright Symbol
Ilie__Daniel
Hello!
Is there a way to print the "copyright simbol" (ALT+0169) from within a FORTRAN program?
I tried to use the char() intrinsic, but I could not find the symbol.
Thank you for your help.
Daniel.
Les_Neilson
Valued Contributor II
character :: c
open(11,file='copyright.txt')
c = char(169)
write(11,'(a)') c
Les
Ilie__Daniel
Thank you Les!
That worked fine. However, I wanted to print the symbol to the screen.
I added the following line of code:
print
("(a)"),c
but all I saw was this symbol
Could the regional setting of my computer have any effect?
Daniel.
Les_Neilson
Possibly.
When I did print instead of write, in my console windowI got the "Registered" symbol - like copyright but with "R" in place of "c" in the circle.
Les
When you say "the screen", do you mean a console window? Whether this works depends on what "codeset" your console window uses - the copyright symbol is not included in all such codesets. You can use the text "Copyright" instead. "(C)" is often used but has no legal meaning.
Ilie__Daniel
Steve,
Yes, I meant the console window.
My codeset is 437, so that is why I did not get the symbol.
The symbol displays correctly in codeset 850.
Daniel.
