29286 Discussions
The INTERFACE/CONTAINS stack is full, Superclass and Subclass pointing to each other
Julian_H_
Hey
I have a circular dependencie. Is there any way to solve this in fortran?
MODULE mElement
	USE mProject
	IMPLICIT NONE
	PRIVATE
	PUBLIC :: tElement
	TYPE :: tElement
		INTEGER(4) :: element_property = 1234
		TYPE(tProject), POINTER	:: project
	CONTAINS
		PROCEDURE, PUBLIC ::  routine_using_project_data	=>  routine_using_project_data
	END TYPE tElement
CONTAINS
	SUBROUTINE routine_using_project_data(this)
		IMPLICIT NONE
		CLASS(tElement)	:: this
		REAL(8)			:: project_property(10)
		project_property = this%project%project_property
	END SUBROUTINE routine_using_project_data
END MODULE mElement
MODULE mProject
	USE mElement
	TYPE :: tProject
		TYPE(tElement), ALLOCATABLE   :: elements(:)
	END TYPE tProject
END MODULE mProject
PROGRAM TEST
	USE mElement
	USE mProject
	IMPLICIT NONE
	TYPE(tProject) :: project
        CALL project%elements(1)%routine_using_project_data()
END PROGRAM TEST
I have Superclass which is containing Subclass Objects. The Subclass should point back to its Superclass
Arjen_Markus
Ian is right - I misread the error message I got with an adjusted version of the program.
Here is the version that is accepted (it does not do anything useful of course :)):
        MODULE mElement
            IMPLICIT NONE
            PRIVATE
            PUBLIC :: tElement, tProject
            TYPE :: tElement
            END TYPE tElement
            TYPE :: tProject
            END TYPE tProject
        END MODULE mElement
        PROGRAM TEST
            USE mElement
            IMPLICIT NONE
        END PROGRAM TEST
Arjen_Markus
I thought the problem could be solved by merging the two modules, but no, you have a sort of forward use of tProject - it is not yet defined when you use it.
Solutions might be:
  • Define a dummy type of which you let tProject be an extension
  • Avoid the circularity altogether. As I am not sure what you are trying to achieve, that may or may not be simple
Fortran does allow types to be defined recursively, but that is no solution here.
IanH
If the types were in the same module, then the forward reference is fine.  What I think Arjen is referring to by recursive definition is just a specific case of the general rule - you can forward reference a type that is defined in the same scope in a pointer or allocatable component.
Arjen_Markus
        MODULE mElement
            IMPLICIT NONE
            PRIVATE
            TYPE :: tElement
            END TYPE tElement
            TYPE :: tProject
            END TYPE tProject
        END MODULE mElement
        PROGRAM TEST
            USE mElement
            IMPLICIT NONE
        END PROGRAM TEST
Julian_H_
        MODULE mElement
            IMPLICIT NONE
            PRIVATE
            TYPE :: tElement
            END TYPE tElement
            TYPE :: tProject
            END TYPE tProject
        END MODULE mElement
        PROGRAM TEST
            USE mElement
            IMPLICIT NONE
        END PROGRAM TEST
Thanks a lot. I will add some usefull routines :)
Julian_H_
Unfortunately I have to combine now a lot of different module and type in one big module with several thousand lines, which is not that handy. I discovered that I can also use submodules. This article from Dr. Fortran explains the basics and also this articel. But they do not explain how to handle type bounded subroutine and functions in submodules or how I can go around the circumference problem. How can I  use tElement in tProject If I am not allowed in mElement to declare tElement public? Visa versa it is working. tElement is allowed to have a pointer to tProject.
mElement.f90
SUBMODULE (mProject) mElement
	TYPE :: tElement
	CONTAINS
		PROCEDURE :: test1 => test_element
	END TYPE tElement
CONTAINS
	MODULE SUBROUTINE routine_using_project_data(elements_property)
		IMPLICIT NONE
		REAL(8), INTENT(IN)		:: elements_property
		project_property = elements_property
	SUBROUTINE test_element(this)
		IMPLICIT NONE
	END SUBROUTINE test_element
END SUBMODULE mElement
Test.f90
MODULE mProject
	IMPLICIT NONE
	PRIVATE
	! TYPES
	PUBLIC :: tProject
	! SUBROUTINES
	INTERFACE
		END SUBROUTINE
	END INTERFACE
	TYPE :: tProject
		REAL(8)						:: project_property(10) = 10
	END TYPE tProject
CONTAINS
END MODULE mProject
PROGRAM TEST
	USE mProject
	IMPLICIT NONE
	TYPE(tProject), TARGET	:: project
	REAL(8)					:: elements_property
	elements_property = 5
	CALL routine_using_project_data(elements_property)
END PROGRAM TEST
IanH
Put the type definitions in the scope of the module along with procedure interface definitions, put the procedure bodies in submodules.
MODULE mProject
  IMPLICIT NONE
  PRIVATE
  ! TYPES
  PUBLIC :: tProject
  ! SUBROUTINES
  INTEGER, PARAMETER, PUBLIC :: rk = KIND(1.0D0)
  INTEGER, PARAMETER :: ik = KIND(1)
  TYPE :: tProject
    REAL(rk) :: project_property(10) = 10
  END TYPE tProject
  TYPE :: tElement
    INTEGER(ik) :: element_property = 1234
  CONTAINS
  END TYPE tElement
  INTERFACE
      IMPLICIT NONE
      REAL(rk), INTENT(IN)	:: elements_property
    END SUBROUTINE
    MODULE SUBROUTINE test_element(this)
      IMPLICIT NONE
	END INTERFACE
END MODULE mProject
  IMPLICIT NONE
CONTAINS
PROGRAM TEST
  USE mProject
  IMPLICIT NONE
  REAL(rk)					:: elements_property
END PROGRAM TEST
Julian_H_
perfect thanks a lot. Thats exactly what I need.
