29487 Discussions
The name of the module procedure conflicts with a name in the encompassing scoping unit.
milenko1976
nf.f90(4): error #6645: The name of the module procedure conflicts with a name in the encompassing scoping unit. [GETVALUE]
function getvalue(PP)
This makes me crazy.
module nf
use definitions
contains
total = 0d0
do k = 1, n_data
row_sum = 0d0
do i = 1, c
dist_ik = vv(i,:)-x(k,:)
write(*,*)dot_product(dist_ik, dist_ik)
row_sum = 1.0/dot_product(dist_ik, dist_ik) + row_sum
end do
total = 1d0/row_sum + total
end do
getvalue= total
end function
end module
How it comes I can not compile module?Do I need interface?
Does module DEFINITIONS declare something named getvalue? If it does, you'll get this error. One way to work around this is to rename the conflicting declaration to something else, for example:
use definitions, dummy1 => getvalue
milenko1976
Ok,nut I made with pointer mistake again.
module definitions
implicit non
integer :: i,k,c,n_data
real,dimension(8,2) :: x
real,dimension(2,2) :: vv
real,dimension(2) :: dist_ik
real(kind(1d0)) row_sum, total
real,pointer :: dummy1(:)
Compile it end then where to put dummy1 => getvalue
module nf
use definitions
dummy1 => getvalue
Like this doesn't work.
milenko@milenkons:~/d$ ifort -c nf.f90
nf.f90(4): error #6218: This statement is positioned incorrectly and/or has syntax errors.
nf.f90(5): error #6274: This statement must not appear in the specification part of a module
dummy1 => getvalue
mecej4
Replace
module nf
use definitions
contains
by
module nf
use definitions, dummy1=>getvalue
contains
Read the Fortran reference to understand what the bold text means.
