29425 Discussions
The procedure entry point could not be located in DLL
yisehak
Hello Intel Community,
I received an error from a program I use by linking a dynamic link library, which is compiled using VS 2019 and Intel Fortran Compiler (latest version). The error message is posted below.
What could be the reason, and how can I fix this?
Thank you in advance.
Arjen_Markus
You should check whether there is an older/different version of the Intel Fortran runtime DLLs somewhere in the path. We have seen such problems as well and it invariably turned out that from some unexpected location a DLL with the same name (from an older version) was picked instead of the right one.
