The reuse pointer derived type causes free(): double free error (simple application of linkedlists)
silva__gabriel
Hello!
I'm trying to reuse a linked list. The module used to construct the linked list is this: https://jblevins.org/research/generic-list.pdf
module linkedlist
  implicit none
  private
  public :: list_t
  public :: list_data
  public :: list_init
  public :: list_free
  public :: list_remove
  public :: list_insert
  public :: list_put
  public :: list_get
  public :: list_next
  public :: list_change
  ! A public variable to use as a MOLD for transfer()
  integer, dimension(:), allocatable :: list_data
  ! Linked list node data type
  type :: list_t
     private
     integer, dimension(:), pointer :: data => null()
     type(list_t), pointer :: next => null()
  end type list_t
contains
  ! Initialize a head node SELF and optionally store the provided DATA.
  subroutine list_init(self, data)
    type(list_t), pointer :: self
    integer, dimension(:), intent(in), optional :: data
    allocate(self)
    nullify(self%next)
    if (present(data)) then
       allocate(self%data(size(data)))
       self%data = data
    else
       nullify(self%data)
    end if
  end subroutine list_init
  ! Free the entire list and all data, beginning at SELF
  subroutine list_free(self)
    type(list_t), pointer :: current
    current => self
    do while (associated(current))
       next => current%next
       if (associated(current%data)) then
          deallocate(current%data)
          nullify(current%data)
       end if
       deallocate(current)
       nullify(current)
       current => next
    end do
  end subroutine list_free
    ! Remove element AFTER SELF
  subroutine list_remove(self)
    current => self
    current%next = next%next
  end subroutine list_remove
  ! Return the next node after SELF
  function list_next(self) result(next)
    next => self%next
  end function list_next
  ! Insert a list node after SELF containing DATA (optional)
  subroutine list_insert(self, data)
    allocate(next)
       allocate(next%data(size(data)))
       next%data = data
    else
       nullify(next%data)
    end if
    next%next => self%next
    self%next => next
  end subroutine list_insert
! Change the NEXT node after a element CURRENT to after anOTHER (in other list for example).
  subroutine list_change(current,other)
    type(list_t), pointer :: other
    if (associated(next%next)) then
        current%next =>  next%next
    else
        current%next => null()
    end if
    next%next => other%next
    other%next => next
  end subroutine list_change
  ! Store the encoded DATA in list node SELF
  subroutine list_put(self, data)
    integer, dimension(:), intent(in) :: data
    if (associated(self%data)) then
       deallocate(self%data)
       nullify(self%data)
    end if
    self%data = data
  end subroutine list_put
  ! Return the DATA stored in the node SELF
  function list_get(self) result(data)
    data => self%data
  end function list_get
!   function list_isnull(self) result(a)
!     type(list_t), pointer :: self = .false.
!     logical :: a
!     if
end module linkedlist
The main program is
! A derived type for storing data.
module data
  implicit none
  private
  public :: data_t
  public :: data_ptr
  ! Data is stored in data_t
  type :: data_t
     real :: x
  end type data_t
  ! A trick to allow us to store pointers in the list
  type :: data_ptr
     type(data_t), pointer :: p
  end type data_ptr
end module data
! A simple generic linked list test program
program list_test
  use linkedlist
  use data
  implicit none
  type(list_t), pointer :: ll => null(), node
  type(data_t), target :: dat_a
  type(data_t), target :: dat_b
  type(data_ptr) :: ptr
!    integer, pointer :: p1
!    integer, target :: t1, t2
!    p1=>t1
!    p1 = 1
!    Print *, p1
!    Print *, t1
!    print*, "A"
!    deallocate(p1)
!    print*, "B"
!    t2 = 2
!    p1 => t2
!    print*, p1
!    deallocate(p1)
!    print*, "C"
  ! Initialize two data objects
  dat_a%x = 17.5
  dat_b%x = 3.0
  ! Initialize the list with dat_a
  ptr%p => dat_a
  call list_init(ll, DATA=transfer(ptr, list_data))
  print *, 'Initializing list with data:', ptr%p
  ! Insert dat_b into the list
  ptr%p => dat_b
  call list_insert(ll, DATA=transfer(ptr, list_data))
  print *, 'Inserting node with data:', ptr%p
  ! Get the head node
  ptr = transfer(list_get(ll), ptr)
  print *, 'Head node data:', ptr%p
  ! Get the next node
  ptr = transfer(list_get(list_next(ll)), ptr)
  print *, 'Second node data:', ptr%p
  print*, associated(node)
  node => list_next(ll)
  ! Free the list starting on the secound node (after ll)
  call list_free(node)
  print*, associated(node) ! It prints True, but it should be false since I deallocated the next node
  ptr%p => dat_a
  ptr%p => dat_b
  ! Get the head node
  ! Get the next node
  ! try to free it again
  print*, associated(node), "capivara"
  call list_free(node) !The code breaks with double free here
  print*, "lalala"
end program list_test
When I try to free the list a second time, it crashes and I get double free error. For some reason, even after I deallocate the first time, if I test it, I get that the node still associated. But if I try to require the data that the node stores it  crashes.
Juergen_R_R
Valued Contributor I
Checked a bit closer: list_data has really never been allocated. No wonder that you cannot transfer it. Next programming error:
Node has never been associated before. So the program stops with a runtime error.
Juergen_R_R
This is for sure a programming error:
Runtime Error: main.f90, line 62: ALLOCATABLE LIST_DATA is not currently allocated
Juergen_R_R
silva__gabriel
I don't know why it had to be allocated. It is just the mold of the transfer function.
jimdempseyatthecove
list_data is an (unallocated) array. The mold requires the shape of this array. I suppose for some peculiar reason you might wish to have transfer to construct an unallocated array out of the input arg, but I suspect this was not your intention.
Also, I didn't review your code in depth. But on the surface, it appears that you are attempting to use transfer to convert a data_ptr object into an integer array object. This doesn't make sense. Did you intend to convert ptr%p (the scalar real) into an integer array?
Jim Dempsey
