There is no matching specific subroutine for this type bound generic subroutine call
Jauch
I have a type with two bound procedures (GetAsScalar & GetAsList) under a generic procedure (GetValue):
type, extends(TObject)  ::  TKeyword
    character(len=:), allocatable               ::  fValue
contains
    procedure, private                          ::  GetAsScalar
    procedure, private                          ::  GetAsList
    generic                                     ::  GetValue    =>  &
                                                    GetAsScalar,    &
                                                    GetAsList
end type TKeyword
The routines signatures are these:
subroutine GetAsScalar (this, value, status)
    !Arguments-------------------------------------------------------------
    class(TKeyword)                                 ::  this
    class(*), target                                ::  value
    logical, optional                               ::  status
end subroutine GetAsScalar
subroutine GetAsList (this, value, status)
    class(*), pointer                               ::  value(:)
end subroutine GetAsList
Internally, the TKeyword object stores a string.
If I try to use it in the following way (bellow), I get a compilation error: "There is no matching specific subroutine for this type bound generic subroutine call"
class(TKeyword), pointer :: key
class(*), pointer :: p(:)
allocate (integer::p(3))
!Code to read instantiate the TKeyword object
call key%GetValue(p, status)
select type (p)
type is (integer)
    write (*,*) p
end select
If I remove the GetAsScalar from the generic association and make it public, the following code works as expected:
call key%GetAsList(p, status)
select type (p)
type is (integer)
    write (*,*) p
end select
When passing a scalar (integer, real, character, etc), the GetAsScalar routine is called without problems.
I would like to know why this is happening. What am I missing in this "generic thing" that makes the compiler unable to recognize my subroutine under the generic? There is a way to make this work? Would be something related with the routine signature?
I'm using Intel Fortran 15.0.1.148
IanH
Looks like a compiler bug associated with resolution of procedures with CLASS(*) dummy arguments.
MODULE m
  IMPLICIT NONE
  TYPE :: TKeyword
  CONTAINS
    PROCEDURE :: GetAsList
    GENERIC :: GetValue => GetAsList
  END TYPE TKeyword
  INTERFACE StandaloneGeneric
    MODULE PROCEDURE GetAsList
  END INTERFACE StandaloneGeneric
CONTAINS
  SUBROUTINE GetAsList (this, value)
    CLASS(TKeyword) ::  this
    CLASS(*), POINTER ::  value(:)
  END SUBROUTINE GetAsList
END MODULE m
PROGRAM program
  USE m
  IMPLICIT NONE
  TYPE(TKeyword) :: key
  CLASS(*), POINTER :: p(:)
  ALLOCATE (INTEGER::p(3))
  CALL key%GetAsList(p)           ! Type bound specific - ok.
  CALL key%GetValue(p)            ! Type bound generic - not ok.
  CALL GetAsList(key, p)          ! Stand-alone specific - ok.
  CALL StandaloneGeneric(key, p)  ! Stand-alone generic - not ok.
END PROGRAM program
>ifort /check:all /warn:all /standard-semantics /stand "2014-12-31 TObject.f90"
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 15.0.1.148 Build 20141023
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
2014-12-31 TObject.f90(13): remark #7712: This variable has not been used.   [VALUE]
2014-12-31 TObject.f90(13): remark #7712: This variable has not been used.   [THIS]
2014-12-31 TObject.f90(28): error #8486: There is no matching specific subroutine for this type bound generic subroutine call.   [GETVALUE]
2014-12-31 TObject.f90(30): error #6285: There is no matching specific subroutine for this generic subroutine call.   [STANDALONEGENERIC]
compilation aborted for 2014-12-31 TObject.f90 (code 1)
Steven_L_Intel1
Thanks, we'll look into it.
Steven_L_Intel1
Escalated as issue DPD200364904. I have this vague memory of having looked at this issue before, but my research suggests it was a somewhat different problem. I will let you know what we find.
Jauch
Hello Steve,
I have just a question. So, in fact, there is nothing wrong from the point of view of the "language standard", right?
I'm assuming the code simply should compile whithout the message error, and that is a problem with the compiler?
Cheers,
Eduardo
Steven_L_Intel1
I believe that the code is valid and should compile without error. I'll let you know what we find.
Jauch
Thanks Steve :)
Steven_L_Intel1
I expect the fix for this to appear in Update 2, scheduled for February.
Jauch
I don't know if this will be useful, but I get the same errors on any type bound generic that includes a procedure with one or more arguments of type polymorphic pointer to an array.
So, while the compiler compiles without problems the module where there is a type bound generic with one or more procedures that have one or more arguments like this: "class(*), pointer  ::  array(:)" (where array can be 2D, 3D, etc), when you try to use it in the same or another module, the error shows up.
This seems to happen only for procedures with polymorphic arrays arguments.
Cheers,
Eduardo
Steven_L_Intel1
Examples of problems would be most useful.
Jauch
I attached an example (GenericError.zip) that causes the following errors:
Error    1     error #8485: There is no matching specific function for this type bound generic function reference.   [COPY]    Console.f90    21
Error    2     error #8497: Illegal use of a procedure name in an expression, possibly a function call missing parenthesis.   [COPY]    console.f90    21
If I remove the generic "Copy" from ModuleArrayTools and make the Copy1D, Copy2D and Copy3D procedures public, calling Copy1D instead of Copy in the main program compiles as expected.
Even if I change the types and number of arguments in the type routines (Copy1D, Copy2D and Copy3D), the presence of a dummy argument that is an array of type "class(*), pointer" makes the compiler unable to identify the right routine.
If no binding routine for the generics have a dummy argument that is an array of type "class(*), pointer", or if the routine that have it is not necessary, the code compiles without errors.
(Virus scan in progress ...)
Steven_L_Intel1
Thanks - that's the same bug as Ian's and should be fixed in update 2.
