29651 Discussions
Thread safe c# service using fortran dll
Fernando_Cosso
Hi all,
I have a c# windows service that starts a couple of threads and then each thread executes the same fortran function.
When that happen, the first function keeps running just fine, while the other one triggers a c# exception.
Is there any compiler option to fix that? I googled a lot and only find recursive and save. I have to test them in the office tomorrow, but I am not optimistic.
PS: The fortran code has modules
TimP
Declaring the Fortran function or subroutine as RECURSIVE would be an important step, which avoids the need to use one of the ifort options /Qauto or the like. SAVEd variables are incompatible with allowing each thread to have its own copy. It would also be important to clean up any undefined variables (often referred to as un-initialized, although technically I've been told that's not correct Fortran terminology).
