Hi!
I can run my FORTRAN code using the FFTW libraries from www.fftw.org in the Debug configuration with multithreading. I am using the following lines of code to invoke the multithreading,
call dfftw_init_threads(ier)
call dfftw_plan_with_nthreads(Nthread)
When I try to run in the Release configuration, I get the following error,
"The procedure entry point dfftw_plan_with_threads__ could not be found in the dynamic link library libfftw3-3.dll"
Why can the subroutine be found in the Debug configuration but not the Release Configuration? Do I need to specify something else in my Fortran code? Both the Debug and Release folders have the same libfftw3-3.dll in them.
Thank you very much for your help.
Sincerely,
David
Sincerely,
David
You have options that are not the same between the two configurations that relate to external name decoration. Look at /assume:underscore.
