Too many parameters in subroutine
Merik_G_
Is there a way around the following error 6319 "The number of arguments in the parenthesized list is incorrect." when there are too many parameters?
Greg_T_
Valued Contributor I
How many arguments do you have? If you have many scalars in the argument list, could you group the scalar values into a custom type or array?  I have had success either way.  For example, group all the logical scalars together in an array to just pass the array.  Or group all the integer scalars into a type, and just pass one instance of that custom type.  Or use a module to hold the needed data and avoid needing to pass many arguments.  Would any of these approaches help?
Regards, Greg T.
Steve_Lionel
I am skeptical that this error results from “too many parameters”. Please show us a small but complete source that demonstrates the problem. I’m not familiar with that particular diagnostic, but I am dubious it relates to subroutine arguments.
Lorri_M_Intel
I found two places in the code where we generate this message; one is when parsing COMPLEX constants, and other is in a helper-routine called from numerous places in the compiler.
I agree with Steve; we need to see the actual source code to understand the problem and propose a solution.
                     --Lorri
Merik_G_
The call is like this:
call MAP$ZC02( Z_WTE,      Z_PTE,      Z_HTE,
     *              Z_BSTE,     Z_BATE,
     *    Z_BHTE,     Z_XATE,     Z_XATB,     Z_WTE2,
     *    Z_PTE2,     Z_HTE2,
     *        Z_BSTE2,    Z_BATE2,    Z_BHTE2,
     *    Z_WTB,      Z_PTB,      Z_HTB,
     *              Z_BSTB,     Z_BATB,
     *    Z_BHTB,     Z_WTB2,     Z_PTB2,     Z_HTB2,
     *               Z_BSTB2,
     *    Z_BATB2,    Z_BHTB2,    Z_WTB3,     Z_PTB3,
     *    Z_HTB3,
     *    Z_BSTB3,    Z_BATB3,    Z_BHTB3,    Z_WTB4,
     *    Z_PTB4,     Z_HTB4,
     *       Z_BSTB4,    Z_BATB4,    Z_BHTB4,
     *    Z_WTB5,     Z_PTB5,     Z_HTB5,
     *           Z_BSTB5,    Z_BATB5,
     *    Z_BHTB5,    Z_WSI,      Z_HSI,
     *    Z_BSSI,     Z_BASI,
     *    Z_BHSI,     Z_WDI1,     Z_WDI2,     Z_HDI1,
     *    Z_HDI2,
     *    Z_BSDI1,
     *    Z_BADI1,    Z_BHDI1,
     *    Z_WWO1,     Z_WWO2,     Z_WSO,
     *    Z_WA1,      Z_WA2,      Z_WC1,      Z_WC2,
     *    Z_TCI1,     Z_TCI2,     Z_PEQL,     Z_HEQL,
     *    Z_XEQL,     Z_WAEQL,    Z_WSEQL,    Z_PEQR,
     *    Z_HEQR,     Z_XEQR,     Z_MEQR,     Z_LEAK,
     *    ZFOUL1,     ZFOUL2,     TAZ_VAC,    Z_BA,
     *    Z_BS,       Z_BH,       Z_BO1,      Z_BO2,
     *    Z_BS1,      Z_BS2,      Z_BA1,      Z_BA2,
     *    Z_BH1,      Z_BH2,      Z_DL1,      Z_DL2,
     *    Z_DSTM,     Z_HL1,      Z_HL2,      Z_HFD,
     *    Z_HGD,      Z_HGPT,     Z_CPGPT,    Z_HSTM,
     *    Z_L1,       Z_L2,       Z_MAIR,     Z_ML1,
     *    Z_ML2,      Z_MSTM,     Z_PAIR,     Z_PTOT,
     *    Z_PTOTB1,   Z_PTOTB2,   Z_PSTM,     Z_Q1,
     *    Z_Q2,       Z_QLS1,     Z_QLS2,     Z_QW1,
     *    Z_QW2,      Z_R1,       Z_R2,
     *    Z_TCO1,     Z_TCO2,     Z_TL1,      Z_TL2,
     *    Z_TM1,      Z_TM2,      Z_TSAT,     Z_TSTM,
     *    Z_TTOT,     Z_TWM1,     Z_TWM2,     Z_VL1,
     *    Z_VL2,      Z_VSTM,     Z_WAN,      Z_WAI,
     *    Z_WAO,      Z_WCN1,     Z_WCN2,     Z_WEVP1,
     *    Z_WEVP2,    Z_WRN,      Z_WAEQR,    Z_WSEQR,
     *    Z_X1,       Z_X2,       Z_XAIR,     Z_XQ,
     *    Z_CEQUAL,   Z_CWRL,     Z_CWRM,     Z_CWRC,
     *    Z_CWBS,     Z_CWBH,     Z_CWBA,     Z_C1,
     *    Z_C2,       Z_CA,       Z_COX,      Z_CCPM,
     *    Z_CDEVP,    Z_CDRN,     Z_CERN,     Z_CHOTW,
     *    Z_CKLS,     XCUAMB_H,   XCUAMB_S,   Z_CKS,
     *    Z_CKW,      Z_CK2,      XCUAMB_T,   Z_CKL1,
     *    Z_CKAIR,    Z_CKHOT,    Z_CLBB,     Z_CLBT,
     *    Z_CLDIV,    Z_CLKA,     Z_CLTU,     Z_CI1,
     *    Z_CM1,      Z_CM2,      Z_CMM,      Z_CMW,
     *    Z_CV,       X_CVINC11,  Z_CLHW,     Z_CVMIN,
     *    Z_CX,       Z_CPLAG,    Z_CMMIN,    Z_CMH,
     *    Z_CSTMTL,   Z_CDTDH,    Z_CWTMIN,   TAFLO,
     *    TAFMD,      XTENVI,     XPENVI,     YITIM,
     *    YIFRE,      Z_IH1,      Z_IH2,      Z_IP,
     *    Z_IHL1,     Z_IHL2,     Z_IPL1,     Z_IPL2,
     *    Z_IDG,      Z_CKLMAX,   ZCCALD1,    ZCCALD2,
     *    ZCCPWTR,    ZCRAIR,     ZCTABS,     ZCPHEL,
     *    ZCCPAIR,    Z_XL1,      Z_XL2,      Z_HA1,
     *    Z_HA2,      X_CVINC21,  ZCTSR,      Z_CVSWT,
     *    X_CVINC12,  X_CVINC22,  ZCWSMIN,    ZCWLMIN,
     *    Z_BHYDTE,   Z_BHYDTE2,  Z_BHYDTB,   Z_BHYDTB2,
     *    Z_BHYDTB3,  Z_BHYDTB4,  Z_BHYDTB5,  Z_BHYD,
     *    Z_BHYDSI,   Z_BN2TE,    Z_BN2TE2,   Z_BN2TB,
     *    Z_BN2TB2,   Z_BN2TB3,   Z_BN2TB4,   Z_BN2TB5,
     *    Z_BN2,      Z_BN2SI,    TAFLO,      TAFMD,
     *    TAFRC,      Z_BHYDL,    Z_BN2L,     Z_CI1H2,
     *    Z_CM1H2,    Z_CM2H2,    Z_CXH2,     Z_CBUND,
     *    Z_BOXYTE,   Z_BOXYTE2,  Z_BOXYTB,   Z_BOXYTB2,
     *    Z_BOXYTB3,  Z_BOXYTB4,  Z_BOXYTB5,  Z_BOXYSI,
     *    Z_BOXY,     Z_BOXYL,    Z_CX_2,     XC02WEQR,
     *    Z_CPAIR,    Z_CEQFL,    Z_XATE2,    X_HLIN1,
     *    X_HLIN2,
     *    Z_RG131IDI1,    Z_RG132IDI1,    Z_RG132TEDI1,   Z_RG133IDI1,
     *    Z_RG133XEDI1,   Z_RG134CSDI1,   Z_RG134IDI1,    Z_RG135IDI1,
     *    Z_RG135XEDI1,   Z_RG136CSDI1,   Z_RG137CSDI1,   Z_RG138CSDI1,
     *    Z_RG138XEDI1,   Z_RG140BADI1,   Z_RG140LADI1,   Z_RG144CEDI1,
     *    Z_RG144CSDI1,   Z_RG144PRDI1,   Z_RG16NDI1,     Z_RG41ARDI1,
     *    Z_RG60CODI1,    Z_RG85KRDI1,    Z_RG87KRDI1,    Z_RG88KRDI1,
     *    Z_RG88RBDI1,    Z_RG89SRDI1,    Z_RG90SRDI1,    Z_RG90YDI1,
     *    Z_RG91SRDI1,    Z_RG91YDI1,     Z_RG92SRDI1,    Z_RG92YDI1,
     *    Z_RGM133XEDI1,  Z_RGM135XEDI1,  Z_RGM144PRDI1,  Z_RGM85KRDI1,
     *    Z_RG131ISI,     Z_RG132ISI,     Z_RG132TESI,    Z_RG133ISI,
     *    Z_RG133XESI,    Z_RG134CSSI,    Z_RG134ISI,     Z_RG135ISI,
     *    Z_RG135XESI,    Z_RG136CSSI,    Z_RG137CSSI,    Z_RG138CSSI,
     *    Z_RG138XESI,    Z_RG140BASI,    Z_RG140LASI,    Z_RG144CESI,
     *    Z_RG144CSSI,    Z_RG144PRSI,    Z_RG16NSI,      Z_RG41ARSI,
     *    Z_RG60COSI,     Z_RG85KRSI,     Z_RG87KRSI,     Z_RG88KRSI,
     *    Z_RG88RBSI,     Z_RG89SRSI,     Z_RG90SRSI,     Z_RG90YSI,
     *    Z_RG91SRSI,     Z_RG91YSI,      Z_RG92SRSI,     Z_RG92YSI,
     *    Z_RGM133XESI,   Z_RGM135XESI,   Z_RGM144PRSI,   Z_RGM85KRSI,
     *    Z_RG131IHW1,    Z_RG132IHW1,    Z_RG132TEHW1,   Z_RG133IHW1,
     *    Z_RG133XEHW1,   Z_RG134CSHW1,   Z_RG134IHW1,    Z_RG135IHW1,
     *    Z_RG135XEHW1,   Z_RG136CSHW1,   Z_RG137CSHW1,   Z_RG138CSHW1,
     *    Z_RG138XEHW1,   Z_RG140BAHW1,   Z_RG140LAHW1,   Z_RG144CEHW1,
     *    Z_RG144CSHW1,   Z_RG144PRHW1,   Z_RG16NHW1,     Z_RG41ARHW1,
     *    Z_RG60COHW1,    Z_RG85KRHW1,    Z_RG87KRHW1,    Z_RG88KRHW1,
     *    Z_RG88RBHW1,    Z_RG89SRHW1,    Z_RG90SRHW1,    Z_RG90YHW1,
     *    Z_RG91SRHW1,    Z_RG91YHW1,     Z_RG92SRHW1,    Z_RG92YHW1,
     *    Z_RGM133XEHW1,  Z_RGM135XEHW1,  Z_RGM144PRHW1,  Z_RGM85KRHW1,
     *    Z_RG131ITB,     Z_RG132ITB,     Z_RG132TETB,    Z_RG133ITB,
     *    Z_RG133XETB,    Z_RG134CSTB,    Z_RG134ITB,     Z_RG135ITB,
     *    Z_RG135XETB,    Z_RG136CSTB,    Z_RG137CSTB,    Z_RG138CSTB,
     *    Z_RG138XETB,    Z_RG140BATB,    Z_RG140LATB,    Z_RG144CETB,
     *    Z_RG144CSTB,    Z_RG144PRTB,    Z_RG16NTB,      Z_RG41ARTB,
     *    Z_RG60COTB,     Z_RG85KRTB,     Z_RG87KRTB,     Z_RG88KRTB,
     *    Z_RG88RBTB,     Z_RG89SRTB,     Z_RG90SRTB,     Z_RG90YTB,
     *    Z_RG91SRTB,     Z_RG91YTB,      Z_RG92SRTB,     Z_RG92YTB,
     *    Z_RGM133XETB,   Z_RGM135XETB,   Z_RGM144PRTB,   Z_RGM85KRTB,
     *    Z_RG131ITB2,    Z_RG132ITB2,    Z_RG132TETB2,   Z_RG133ITB2,
     *    Z_RG133XETB2,   Z_RG134CSTB2,   Z_RG134ITB2,    Z_RG135ITB2,
     *    Z_RG135XETB2,   Z_RG136CSTB2,   Z_RG137CSTB2,   Z_RG138CSTB2,
     *    Z_RG138XETB2,   Z_RG140BATB2,   Z_RG140LATB2,   Z_RG144CETB2,
     *    Z_RG144CSTB2,   Z_RG144PRTB2,   Z_RG16NTB2,     Z_RG41ARTB2,
     *    Z_RG60COTB2,    Z_RG85KRTB2,    Z_RG87KRTB2,    Z_RG88KRTB2,
     *    Z_RG88RBTB2,    Z_RG89SRTB2,    Z_RG90SRTB2,    Z_RG90YTB2,
     *    Z_RG91SRTB2,    Z_RG91YTB2,     Z_RG92SRTB2,    Z_RG92YTB2,
     *    Z_RGM133XETB2,  Z_RGM135XETB2,  Z_RGM144PRTB2,  Z_RGM85KRTB2,
     *    Z_RG131ITB3,    Z_RG132ITB3,    Z_RG132TETB3,   Z_RG133ITB3,
     *    Z_RG133XETB3,   Z_RG134CSTB3,   Z_RG134ITB3,    Z_RG135ITB3,
     *    Z_RG135XETB3,   Z_RG136CSTB3,   Z_RG137CSTB3,   Z_RG138CSTB3,
     *    Z_RG138XETB3,   Z_RG140BATB3,   Z_RG140LATB3,   Z_RG144CETB3,
     *    Z_RG144CSTB3,   Z_RG144PRTB3,   Z_RG16NTB3,     Z_RG41ARTB3,
     *    Z_RG60COTB3,    Z_RG85KRTB3,    Z_RG87KRTB3,    Z_RG88KRTB3,
     *    Z_RG88RBTB3,    Z_RG89SRTB3,    Z_RG90SRTB3,    Z_RG90YTB3,
     *    Z_RG91SRTB3,    Z_RG91YTB3,     Z_RG92SRTB3,    Z_RG92YTB3,
     *    Z_RGM133XETB3,  Z_RGM135XETB3,  Z_RGM144PRTB3,  Z_RGM85KRTB3,
     *    Z_RG131ITB4,    Z_RG132ITB4,    Z_RG132TETB4,   Z_RG133ITB4,
     *    Z_RG133XETB4,   Z_RG134CSTB4,   Z_RG134ITB4,    Z_RG135ITB4,
     *    Z_RG135XETB4,   Z_RG136CSTB4,   Z_RG137CSTB4,   Z_RG138CSTB4,
     *    Z_RG138XETB4,   Z_RG140BATB4,   Z_RG140LATB4,   Z_RG144CETB4,
     *    Z_RG144CSTB4,   Z_RG144PRTB4,   Z_RG16NTB4,     Z_RG41ARTB4,
     *    Z_RG60COTB4,    Z_RG85KRTB4,    Z_RG87KRTB4,    Z_RG88KRTB4,
     *    Z_RG88RBTB4,    Z_RG89SRTB4,    Z_RG90SRTB4,    Z_RG90YTB4,
     *    Z_RG91SRTB4,    Z_RG91YTB4,     Z_RG92SRTB4,    Z_RG92YTB4,
     *    Z_RGM133XETB4,  Z_RGM135XETB4,  Z_RGM144PRTB4,  Z_RGM85KRTB4,
     *    Z_RG131ITB5,    Z_RG132ITB5,    Z_RG132TETB5,   Z_RG133ITB5,
     *    Z_RG133XETB5,   Z_RG134CSTB5,   Z_RG134ITB5,    Z_RG135ITB5,
     *    Z_RG135XETB5,   Z_RG136CSTB5,   Z_RG137CSTB5,   Z_RG138CSTB5,
     *    Z_RG138XETB5,   Z_RG140BATB5,   Z_RG140LATB5,   Z_RG144CETB5,
     *    Z_RG144CSTB5,   Z_RG144PRTB5,   Z_RG16NTB5,     Z_RG41ARTB5,
     *    Z_RG60COTB5,    Z_RG85KRTB5,    Z_RG87KRTB5,    Z_RG88KRTB5,
     *    Z_RG88RBTB5,    Z_RG89SRTB5,    Z_RG90SRTB5,    Z_RG90YTB5,
     *    Z_RG91SRTB5,    Z_RG91YTB5,     Z_RG92SRTB5,    Z_RG92YTB5,
     *    Z_RGM133XETB5,  Z_RGM135XETB5,  Z_RGM144PRTB5,  Z_RGM85KRTB5,
     *    Z_RG131ITE,     Z_RG132ITE,     Z_RG132TETE,    Z_RG133ITE,
     *    Z_RG133XETE,    Z_RG134CSTE,    Z_RG134ITE,     Z_RG135ITE,
     *    Z_RG135XETE,    Z_RG136CSTE,    Z_RG137CSTE,    Z_RG138CSTE,
     *    Z_RG138XETE,    Z_RG140BATE,    Z_RG140LATE,    Z_RG144CETE,
     *    Z_RG144CSTE,    Z_RG144PRTE,    Z_RG16NTE,      Z_RG41ARTE,
     *    Z_RG60COTE,     Z_RG85KRTE,     Z_RG87KRTE,     Z_RG88KRTE,
     *    Z_RG88RBTE,     Z_RG89SRTE,     Z_RG90SRTE,     Z_RG90YTE,
     *    Z_RG91SRTE,     Z_RG91YTE,      Z_RG92SRTE,     Z_RG92YTE,
     *    Z_RGM133XETE,   Z_RGM135XETE,   Z_RGM144PRTE,   Z_RGM85KRTE,
     *    Z_RG131ITE2,    Z_RG132ITE2,    Z_RG132TETE2,   Z_RG133ITE2,
     *    Z_RG133XETE2,   Z_RG134CSTE2,   Z_RG134ITE2,    Z_RG135ITE2,
     *    Z_RG135XETE2,   Z_RG136CSTE2,   Z_RG137CSTE2,   Z_RG138CSTE2,
     *    Z_RG138XETE2,   Z_RG140BATE2,   Z_RG140LATE2,   Z_RG144CETE2,
     *    Z_RG144CSTE2,   Z_RG144PRTE2,   Z_RG16NTE2,     Z_RG41ARTE2,
     *    Z_RG60COTE2,    Z_RG85KRTE2,    Z_RG87KRTE2,    Z_RG88KRTE2,
     *    Z_RG88RBTE2,    Z_RG89SRTE2,    Z_RG90SRTE2,    Z_RG90YTE2,
     *    Z_RG91SRTE2,    Z_RG91YTE2,     Z_RG92SRTE2,    Z_RG92YTE2,
     *    Z_RGM133XETE2,  Z_RGM135XETE2,  Z_RGM144PRTE2,  Z_RGM85KRTE2,
     *    Z_G131I,        Z_G132I,        Z_G132TE,       Z_G133I,
     *    Z_G133XE,       Z_G134CS,       Z_G134I,        Z_G135I,
     *    Z_G135XE,       Z_G136CS,       Z_G137CS,       Z_G138CS,
     *    Z_G138XE,       Z_G140BA,       Z_G140LA,       Z_G144CE,
     *    Z_G144CS,       Z_G144PR,       Z_G16N,         Z_G41AR,
     *    Z_G60CO,        Z_G85KR,        Z_G87KR,        Z_G88KR,
     *    Z_G88RB,        Z_G89SR,        Z_G90SR,        Z_G90Y,
     *    Z_G91SR,        Z_G91Y,         Z_G92SR,        Z_G92Y,
     *    Z_GM133XE,      Z_GM135XE,      Z_GM144PR,      Z_GM85KR,
     *    Z_CWG131I,      Z_CWG132I,      Z_CWG132TE,     Z_CWG133I,
     *    Z_CWG133XE,     Z_CWG134CS,     Z_CWG134I,      Z_CWG135I,
     *    Z_CWG135XE,     Z_CWG136CS,     Z_CWG137CS,     Z_CWG138CS,
     *    Z_CWG138XE,     Z_CWG140BA,     Z_CWG140LA,     Z_CWG144CE,
     *    Z_CWG144CS,     Z_CWG144PR,     Z_CWG16N,       Z_CWG41AR,
     *    Z_CWG60CO,      Z_CWG85KR,      Z_CWG87KR,      Z_CWG88KR,
     *    Z_CWG88RB,      Z_CWG89SR,      Z_CWG90SR,      Z_CWG90Y,
     *    Z_CWG91SR,      Z_CWG91Y,       Z_CWG92SR,      Z_CWG92Y,
     *    Z_CWGM133XE,    Z_CWGM135XE,    Z_CWGM144PR,    Z_CWGM85KR,
     *    Z_RG131ID,      Z_RG132ID,      Z_RG132TED,     Z_RG133ID,
     *    Z_RG133XED,     Z_RG134CSD,     Z_RG134ID,      Z_RG135ID,
     *    Z_RG135XED,     Z_RG136CSD,     Z_RG137CSD,     Z_RG138CSD,
     *    Z_RG138XED,     Z_RG140BAD,     Z_RG140LAD,     Z_RG144CED,
     *    Z_RG144CSD,     Z_RG144PRD,     Z_RG16ND,       Z_RG41ARD,
     *    Z_RG60COD,      Z_RG85KRD,      Z_RG87KRD,      Z_RG88KRD,
     *    Z_RG88RBD,      Z_RG89SRD,      Z_RG90SRD,      Z_RG90YD,
     *    Z_RG91SRD,      Z_RG91YD,       Z_RG92SRD,      Z_RG92YD,
     *    Z_RGM133XED,    Z_RGM135XED,    Z_RGM144PRD,    Z_RGM85KRD,
     *    ZNDFRAC131I,    ZNDFRAC132I,    ZNDFRAC132TE,   ZNDFRAC133I,
     *    ZNDFRAC133XE,   ZNDFRAC134CS,   ZNDFRAC134I,    ZNDFRAC135I,
     *    ZNDFRAC135XE,   ZNDFRAC136CS,   ZNDFRAC137CS,   ZNDFRAC138CS,
     *    ZNDFRAC138XE,   ZNDFRAC140BA,   ZNDFRAC140LA,   ZNDFRAC144CE,
     *    ZNDFRAC144CS,   ZNDFRAC144PR,   ZNDFRAC16N,     ZNDFRAC41AR,
     *    ZNDFRAC60CO,    ZNDFRAC85KR,    ZNDFRAC87KR,    ZNDFRAC88KR,
     *    ZNDFRAC88RB,    ZNDFRAC89SR,    ZNDFRAC90SR,    ZNDFRAC90Y,
     *    ZNDFRAC91SR,    ZNDFRAC91Y,     ZNDFRAC92SR,    ZNDFRAC92Y,
     *    ZNDFRACM133XE,  ZNDFRACM135XE,  ZNDFRACM144PR,  ZNDFRACM85KR,
     *    Z_RG131ITB6,    Z_RG132ITB6,    Z_RG132TETB6,   Z_RG133ITB6,
     *    Z_RG133XETB6,   Z_RG134CSTB6,   Z_RG134ITB6,    Z_RG135ITB6,
     *    Z_RG135XETB6,   Z_RG136CSTB6,   Z_RG137CSTB6,   Z_RG138CSTB6,
     *    Z_RG138XETB6,   Z_RG140BATB6,   Z_RG140LATB6,   Z_RG144CETB6,
     *    Z_RG144CSTB6,   Z_RG144PRTB6,   Z_RG16NTB6,     Z_RG41ARTB6,
     *    Z_RG60COTB6,    Z_RG85KRTB6,    Z_RG87KRTB6,    Z_RG88KRTB6,
     *    Z_RG88RBTB6,    Z_RG89SRTB6,    Z_RG90SRTB6,    Z_RG90YTB6,
     *    Z_RG91SRTB6,    Z_RG91YTB6,     Z_RG92SRTB6,    Z_RG92YTB6,
     *    Z_RGM133XETB6,  Z_RGM135XETB6,  Z_RGM144PRTB6,  Z_RGM85KRTB6,
     *    Z_HTB6,         Z_WTB6,         Z_PTB6,         Z_BN2TB6,
     *    Z_BHYDTB6,     Z_BOXYTB6,      Z_BSTB6,        Z_BATB6,
     *    Z_BHTB6,        Z_XATB2,        Z_XATB3,        Z_XATB4,
     *    Z_XATB5,        Z_XATB6,
     *    Z_BSHW1A, Z_BSHW1B,
     *    Z_BAHW1A, Z_BAHW1B,
     *    Z_BHHW1A, Z_BHHW1B,
     *    Z_WWO1A,  Z_WWO1B,  Z_WWO2A,  Z_WWO2B,
     *    Z_HLIN1A, Z_HLIN1B, Z_HLIN2A, Z_HLIN2B,
     *    Z_CKSUB,
     *    Z_WN2I, Z_WN2O, Z_WO2I, Z_WO2O,
     *    Z_BOXYDI1, Z_BOXYDI2, Z_BN2DI1, Z_BN2DI2,
     *    Z_MO2,  Z_MN2,
     *    Z_BN2LEFT, Z_BO2LEFT, Z_BN2RIGHT, Z_BO2RIGHT,
     *    Z_MGAS, Z_XH2O, ZH2OGAS, Z_HGAS, Z_HGASL, Z_HAIR, Z_TTOTL,
     *    Z_CPMIX,
     *    Z_MG131I,   Z_MG132I,   Z_MG132TE,   Z_MG133I,    Z_MG133XE,
     *    Z_MG134CS,  Z_MG134I,   Z_MG135I,    Z_MG135XE,   Z_MG136CS,
     *    Z_MG137CS,  Z_MG138CS,  Z_MG138XE,   Z_MG140BA,   Z_MG140LA,
     *    Z_MG144CE,  Z_MG144CS,  Z_MG144PR,   Z_MG16N,     Z_MG41AR,
     *    Z_MG60CO,   Z_MG85KR,   Z_MG87KR,    Z_MG88KR,    Z_MG88RB,
     *    Z_MG89SR,   Z_MG90SR,   Z_MG90Y,     Z_MG91SR,    Z_MG91Y,
     *    Z_MG92SR,   Z_MG92Y,    Z_MGM133XE,  Z_MGM135XE,  Z_MGM144PR,
     *    Z_MGM85KR,
     *    Z_MHW131I,  Z_MHW132I,  Z_MHW132TE,  Z_MHW133I,   Z_MHW133XE,
     *    Z_MHW134CS, Z_MHW134I,  Z_MHW135I,   Z_MHW135XE,  Z_MHW136CS,
     *    Z_MHW137CS, Z_MHW138CS, Z_MHW138XE,  Z_MHW140BA,  Z_MHW140LA,
     *    Z_MHW144CE, Z_MHW144CS, Z_MHW144PR,  Z_MHW16N,    Z_MHW41AR,
     *    Z_MHW60CO,  Z_MHW85KR,  Z_MHW87KR,   Z_MHW88KR,   Z_MHW88RB,
     *    Z_MHW89SR,  Z_MHW90SR,  Z_MHW90Y,    Z_MHW91SR,   Z_MHW91Y,
     *    Z_MHW92SR,  Z_MHW92Y,   Z_MHWM133XE, Z_MHWM135XE, Z_MHWM144PR,
     *    Z_MHWM85KR,
     *    Z_131IAR1,    Z_132IAR1,    Z_132TEAR1,   Z_133IAR1,  Z_133XEAR1,   Z_134CSAR1,   Z_134IAR1,    Z_135IAR1,
     *    Z_135XEAR1,   Z_136CSAR1,   Z_137CSAR1,   Z_138CSAR1, Z_138XEAR1,   Z_140BAAR1,   Z_140LAAR1,   Z_144CEAR1,
     *    Z_144CSAR1,   Z_144PRAR1,   Z_16NAR1,     Z_41ARAR1,  Z_60COAR1,    Z_85KRAR1,    Z_87KRAR1,    Z_88KRAR1,
     *    Z_88RBAR1,    Z_89SRAR1,    Z_90SRAR1,    Z_90YAR1,   Z_91SRAR1,    Z_91YAR1,     Z_92SRAR1,    Z_92YAR1,
     *    Z_M133XEAR1,  Z_M135XEAR1,  Z_M144PRAR1,  Z_M85KRAR1,
     *    Z_HAR1,       Z_WAR1,       Z_BGASAR1,   Z_BN2AR1,   Z_BHYDAR1, Z_BOXYAR1,    Z_XAAR1,     Z_XH2OAR1,
     *    Z_131IAR2,    Z_132IAR2,    Z_132TEAR2,   Z_133IAR2,  Z_133XEAR2,   Z_134CSAR2,   Z_134IAR2,    Z_135IAR2,
     *    Z_135XEAR2,   Z_136CSAR2,   Z_137CSAR2,   Z_138CSAR2, Z_138XEAR2,   Z_140BAAR2,   Z_140LAAR2,   Z_144CEAR2,
     *    Z_144CSAR2,   Z_144PRAR2,   Z_16NAR2,     Z_41ARAR2,  Z_60COAR2,    Z_85KRAR2,    Z_87KRAR2,    Z_88KRAR2,
     *    Z_88RBAR2,    Z_89SRAR2,    Z_90SRAR2,    Z_90YAR2,   Z_91SRAR2,    Z_91YAR2,     Z_92SRAR2,    Z_92YAR2,
     *    Z_M133XEAR2,  Z_M135XEAR2,  Z_M144PRAR2,  Z_M85KRAR2,
     *    Z_HAR2,       Z_WAR2,       Z_BGASAR2,    Z_BN2AR2,   Z_BHYDAR2,    Z_BOXYAR2,    Z_XAAR2,      Z_XH2OAR2,
     *    Z_BOXYL2,     Z_BN2L2,      Z_BHYDL2,     Z_HGASL2,   Z_TTOTL2,     Z_XH2O2)
The subroutine is like this:
      SUBROUTINE MAP$ZC02 ( Z_WTE    , Z_PTE    , Z_HTE    ,
     &     Z_BSTE   , Z_BATE   ,
     &     Z_BHTE   , Z_XATE   , Z_XATB   ,
     &     Z_WTE2   , Z_PTE2   , Z_HTE2   ,
     &       Z_BSTE2  , Z_BATE2  ,
     &     Z_BHTE2  , Z_WTB    , Z_PTB    , Z_HTB    ,
     &       Z_BSTB   ,
     &     Z_BATB   , Z_BHTB   , Z_WTB2   , Z_PTB2   ,
     &     Z_HTB2   ,
     &     Z_BSTB2  , Z_BATB2  , Z_BHTB2  , Z_WTB3   ,
     &     Z_PTB3   , Z_HTB3   ,
     &      Z_BSTB3  , Z_BATB3  , Z_BHTB3  ,
     &     Z_WTB4   , Z_PTB4   , Z_HTB4   ,
     &      Z_BSTB4  , Z_BATB4  ,
     &     Z_BHTB4  , Z_WTB5   , Z_PTB5   , Z_HTB5   ,
     &        Z_BSTB5  ,
     &     Z_BATB5  , Z_BHTB5  , Z_WSI    , Z_HSI    ,
     &     Z_BSSI   ,
     &     Z_BASI    ,Z_BHSI   , Z_WDI1   , Z_WDI2   ,
     &     Z_HDI1   , Z_HDI2   ,
     &     Z_BSDI1  , Z_BADI1  ,
     &     Z_BHDI1  , Z_WWO1   , Z_WWO2   ,
     &     Z_WSO    , Z_WA1    , Z_WA2    , Z_WC1    ,
     &     Z_WC2    , Z_TCI1   , Z_TCI2   , Z_PEQL   ,
     &     Z_HEQL   , Z_XEQL   , Z_WAEQL  , Z_WSEQL  ,
     &     Z_PEQR   , Z_HEQR   , Z_XEQR   , Z_MEQR   ,
     &     TVZ_0001 , TAZ_F1   , TAZ_F2   , TAZ_VAC  ,
     &     Z_BA     , Z_BS     , Z_BH     , Z_BO1    ,
     &     Z_BO2    , Z_BS1    , Z_BS2    , Z_BA1    ,
     &     Z_BA2    , Z_BH1    , Z_BH2    , Z_DL1    ,
     &     Z_DL2    , Z_DSTM   , Z_HL1    , Z_HL2    ,
     &     Z_HFD    , Z_HGD    , Z_HGPT   , Z_CPGPT  ,
     &     Z_HSTM   , Z_L1     , Z_L2     , Z_MAIR   ,
     &     Z_ML1    , Z_ML2    , Z_MSTM   , Z_PAIR   ,
     &     Z_PTOT   , Z_PTOTB1 , Z_PTOTB2 , Z_PSTM   ,
     &     Z_Q1     , Z_Q2     , Z_QLS1   , Z_QLS2   ,
     &     Z_QW1    , Z_QW2    , Z_R1     , Z_R2     ,
     &     Z_TCO1   , Z_TCO2   , Z_TL1    ,
     &     Z_TL2    , Z_TM1    , Z_TM2    , Z_TSAT   ,
     &     Z_TSTM   , Z_TTOT   , Z_TWM1   , Z_TWM2   ,
     &     Z_VL1    , Z_VL2    , Z_VSTM   , Z_WAN    ,
     &     Z_WAI    , Z_WAO    , Z_WCN1   , Z_WCN2   ,
     &     Z_WEVP1  , Z_WEVP2  , Z_WRN    , Z_WAEQR  ,
     &     Z_WSEQR  , Z_X1     , Z_X2     , Z_XAIR   ,
     &     Z_XQ     , Z_CEQUAL , Z_CWRL   , Z_CWRM   ,
     &     Z_CWRC   , Z_CWBS   , Z_CWBH   , Z_CWBA   ,
     &     Z_C1     , Z_C2     , Z_CA     , Z_COX    ,
     &     Z_CCPM   , Z_CDEVP  , Z_CDRN   , Z_CERN   ,
     &     Z_CHOTW  , Z_CKLS   , Z_CKAL   , Z_CKAS   ,
     &     Z_CKS    , Z_CKW    , Z_CK2    , Z_CKAT   ,
     &     Z_CKL1   , Z_CKAIR  , Z_CKHOT  , Z_CLBB   ,
     &     Z_CLBT   , Z_CLDIV  , Z_CLKA   , Z_CLTU   ,
     &     Z_CI1    , Z_CM1    , Z_CM2    , Z_CMM    ,
     &     Z_CMW    , Z_CV     , X_CVINC11, Z_CLHW   ,
     &     Z_CVMIN  , Z_CX     , Z_CPLAG  , Z_CMMIN  ,
     &     Z_CMH    , Z_CSTMTL , Z_CDTDH  , Z_CWTMIN ,
     &     TAFLO    , TAFMD    , TATAMB   , TAPAMB   ,
     &     YITIM    , YIFRE    , Z_IH1    , Z_IH2    ,
     &     Z_IP     , Z_IHL1   , Z_IHL2   , Z_IPL1   ,
     &     Z_IPL2   , Z_IDG    , Z_CKLMAX , ZCCALD1  ,
     &     ZCCALD2  , ZCCPWTR  , ZCRAIR   , ZCTABS   ,
     &     ZCPHEL   , ZCCPAIR  , Z_XL1    , Z_XL2    ,
     &     Z_HA1    , Z_HA2    , X_CVINC21, ZCTSR    ,
     &     Z_CVSWT  , X_CVINC12, X_CVINC22, ZCWSMIN  ,
     &     ZCWLMIN  , Z_BHYDTE , Z_BHYDTE2, Z_BHYDTB ,
     &     Z_BHYDTB2, Z_BHYDTB3, Z_BHYDTB4, Z_BHYDTB5,
     &     Z_BHYD   , Z_BHYDSI , Z_BN2TE  , Z_BN2TE2 ,
     &     Z_BN2TB  , Z_BN2TB2 , Z_BN2TB3 , Z_BN2TB4 ,
     &     Z_BN2TB5 , Z_BN2    , Z_BN2SI  , Z_RLD    ,
     &     Z_RMD    , Z_RCD    , Z_BHYDL  , Z_BN2L   ,
     &     Z_CI1H2  , Z_CM1H2  , Z_CM2H2  , Z_CXH2   ,
     &  Z_CBUND  , Z_BOXYTE , Z_BOXYTE2, Z_BOXYTB ,
     &     Z_BOXYTB2, Z_BOXYTB3, Z_BOXYTB4, Z_BOXYTB5,
     &     Z_BOXYSI , Z_BOXY   , Z_BOXYL  , Z_CX_2   ,
     &  XC02WEQR , Z_CPAIR  , Z_CEQFL  , Z_XATE2  ,
     &     X_HLIN1  , X_HLIN2  ,
     &     Z_RG131IDI1,    Z_RG132IDI1,    Z_RG132TEDI1,   Z_RG133IDI1,
     &     Z_RG133XEDI1,   Z_RG134CSDI1,   Z_RG134IDI1,    Z_RG135IDI1,
     &     Z_RG135XEDI1,   Z_RG136CSDI1,   Z_RG137CSDI1,   Z_RG138CSDI1,
     &     Z_RG138XEDI1,   Z_RG140BADI1,   Z_RG140LADI1,   Z_RG144CEDI1,
     &     Z_RG144CSDI1,   Z_RG144PRDI1,   Z_RG16NDI1,     Z_RG41ARDI1,
     &     Z_RG60CODI1,    Z_RG85KRDI1,    Z_RG87KRDI1,    Z_RG88KRDI1,
     &     Z_RG88RBDI1,    Z_RG89SRDI1,    Z_RG90SRDI1,    Z_RG90YDI1,
     &     Z_RG91SRDI1,    Z_RG91YDI1,     Z_RG92SRDI1,    Z_RG92YDI1,
     &     Z_RGM133XEDI1,  Z_RGM135XEDI1,  Z_RGM144PRDI1,  Z_RGM85KRDI1,
     &     Z_RG131ISI,     Z_RG132ISI,     Z_RG132TESI,    Z_RG133ISI,
     &     Z_RG133XESI,    Z_RG134CSSI,    Z_RG134ISI,     Z_RG135ISI,
     &     Z_RG135XESI,    Z_RG136CSSI,    Z_RG137CSSI,    Z_RG138CSSI,
     &     Z_RG138XESI,    Z_RG140BASI,    Z_RG140LASI,    Z_RG144CESI,
     &     Z_RG144CSSI,    Z_RG144PRSI,    Z_RG16NSI,      Z_RG41ARSI,
     &     Z_RG60COSI,     Z_RG85KRSI,     Z_RG87KRSI,     Z_RG88KRSI,
     &     Z_RG88RBSI,     Z_RG89SRSI,     Z_RG90SRSI,     Z_RG90YSI,
     &     Z_RG91SRSI,     Z_RG91YSI,      Z_RG92SRSI,     Z_RG92YSI,
     &     Z_RGM133XESI,   Z_RGM135XESI,   Z_RGM144PRSI,   Z_RGM85KRSI,
     &     Z_RG131IHW1,    Z_RG132IHW1,    Z_RG132TEHW1,   Z_RG133IHW1,
     &     Z_RG133XEHW1,   Z_RG134CSHW1,   Z_RG134IHW1,    Z_RG135IHW1,
     &     Z_RG135XEHW1,   Z_RG136CSHW1,   Z_RG137CSHW1,   Z_RG138CSHW1,
     &     Z_RG138XEHW1,   Z_RG140BAHW1,   Z_RG140LAHW1,   Z_RG144CEHW1,
     &     Z_RG144CSHW1,   Z_RG144PRHW1,   Z_RG16NHW1,     Z_RG41ARHW1,
     &     Z_RG60COHW1,    Z_RG85KRHW1,    Z_RG87KRHW1,    Z_RG88KRHW1,
     &     Z_RG88RBHW1,    Z_RG89SRHW1,    Z_RG90SRHW1,    Z_RG90YHW1,
     &     Z_RG91SRHW1,    Z_RG91YHW1,     Z_RG92SRHW1,    Z_RG92YHW1,
     &     Z_RGM133XEHW1,  Z_RGM135XEHW1,  Z_RGM144PRHW1,  Z_RGM85KRHW1,
     &     Z_RG131ITB,     Z_RG132ITB,     Z_RG132TETB,    Z_RG133ITB,
     &     Z_RG133XETB,    Z_RG134CSTB,    Z_RG134ITB,     Z_RG135ITB,
     &     Z_RG135XETB,    Z_RG136CSTB,    Z_RG137CSTB,    Z_RG138CSTB,
     &     Z_RG138XETB,    Z_RG140BATB,    Z_RG140LATB,    Z_RG144CETB,
     &     Z_RG144CSTB,    Z_RG144PRTB,    Z_RG16NTB,      Z_RG41ARTB,
     &     Z_RG60COTB,     Z_RG85KRTB,     Z_RG87KRTB,     Z_RG88KRTB,
     &     Z_RG88RBTB,     Z_RG89SRTB,     Z_RG90SRTB,     Z_RG90YTB,
     &     Z_RG91SRTB,     Z_RG91YTB,      Z_RG92SRTB,     Z_RG92YTB,
     &     Z_RGM133XETB,   Z_RGM135XETB,   Z_RGM144PRTB,   Z_RGM85KRTB,
     &     Z_RG131ITB2,    Z_RG132ITB2,    Z_RG132TETB2,   Z_RG133ITB2,
     &     Z_RG133XETB2,   Z_RG134CSTB2,   Z_RG134ITB2,    Z_RG135ITB2,
     &     Z_RG135XETB2,   Z_RG136CSTB2,   Z_RG137CSTB2,   Z_RG138CSTB2,
     &     Z_RG138XETB2,   Z_RG140BATB2,   Z_RG140LATB2,   Z_RG144CETB2,
     &     Z_RG144CSTB2,   Z_RG144PRTB2,   Z_RG16NTB2,     Z_RG41ARTB2,
     &     Z_RG60COTB2,    Z_RG85KRTB2,    Z_RG87KRTB2,    Z_RG88KRTB2,
     &     Z_RG88RBTB2,    Z_RG89SRTB2,    Z_RG90SRTB2,    Z_RG90YTB2,
     &     Z_RG91SRTB2,    Z_RG91YTB2,     Z_RG92SRTB2,    Z_RG92YTB2,
     &     Z_RGM133XETB2,  Z_RGM135XETB2,  Z_RGM144PRTB2,  Z_RGM85KRTB2,
     &     Z_RG131ITB3,    Z_RG132ITB3,    Z_RG132TETB3,   Z_RG133ITB3,
     &     Z_RG133XETB3,   Z_RG134CSTB3,   Z_RG134ITB3,    Z_RG135ITB3,
     &     Z_RG135XETB3,   Z_RG136CSTB3,   Z_RG137CSTB3,   Z_RG138CSTB3,
     &     Z_RG138XETB3,   Z_RG140BATB3,   Z_RG140LATB3,   Z_RG144CETB3,
     &     Z_RG144CSTB3,   Z_RG144PRTB3,   Z_RG16NTB3,     Z_RG41ARTB3,
     &     Z_RG60COTB3,    Z_RG85KRTB3,    Z_RG87KRTB3,    Z_RG88KRTB3,
     &     Z_RG88RBTB3,    Z_RG89SRTB3,    Z_RG90SRTB3,    Z_RG90YTB3,
     &     Z_RG91SRTB3,    Z_RG91YTB3,     Z_RG92SRTB3,    Z_RG92YTB3,
     &     Z_RGM133XETB3,  Z_RGM135XETB3,  Z_RGM144PRTB3,  Z_RGM85KRTB3,
     &     Z_RG131ITB4,    Z_RG132ITB4,    Z_RG132TETB4,   Z_RG133ITB4,
     &     Z_RG133XETB4,   Z_RG134CSTB4,   Z_RG134ITB4,    Z_RG135ITB4,
     &     Z_RG135XETB4,   Z_RG136CSTB4,   Z_RG137CSTB4,   Z_RG138CSTB4,
     &     Z_RG138XETB4,   Z_RG140BATB4,   Z_RG140LATB4,   Z_RG144CETB4,
     &     Z_RG144CSTB4,   Z_RG144PRTB4,   Z_RG16NTB4,     Z_RG41ARTB4,
     &     Z_RG60COTB4,    Z_RG85KRTB4,    Z_RG87KRTB4,    Z_RG88KRTB4,
     &     Z_RG88RBTB4,    Z_RG89SRTB4,    Z_RG90SRTB4,    Z_RG90YTB4,
     &     Z_RG91SRTB4,    Z_RG91YTB4,     Z_RG92SRTB4,    Z_RG92YTB4,
     &     Z_RGM133XETB4,  Z_RGM135XETB4,  Z_RGM144PRTB4,  Z_RGM85KRTB4,
     &     Z_RG131ITB5,    Z_RG132ITB5,    Z_RG132TETB5,   Z_RG133ITB5,
     &     Z_RG133XETB5,   Z_RG134CSTB5,   Z_RG134ITB5,    Z_RG135ITB5,
     &     Z_RG135XETB5,   Z_RG136CSTB5,   Z_RG137CSTB5,   Z_RG138CSTB5,
     &     Z_RG138XETB5,   Z_RG140BATB5,   Z_RG140LATB5,   Z_RG144CETB5,
     &     Z_RG144CSTB5,   Z_RG144PRTB5,   Z_RG16NTB5,     Z_RG41ARTB5,
     &     Z_RG60COTB5,    Z_RG85KRTB5,    Z_RG87KRTB5,    Z_RG88KRTB5,
     &     Z_RG88RBTB5,    Z_RG89SRTB5,    Z_RG90SRTB5,    Z_RG90YTB5,
     &     Z_RG91SRTB5,    Z_RG91YTB5,     Z_RG92SRTB5,    Z_RG92YTB5,
     &     Z_RGM133XETB5,  Z_RGM135XETB5,  Z_RGM144PRTB5,  Z_RGM85KRTB5,
     &     Z_RG131ITE,     Z_RG132ITE,     Z_RG132TETE,    Z_RG133ITE,
     &     Z_RG133XETE,    Z_RG134CSTE,    Z_RG134ITE,     Z_RG135ITE,
     &     Z_RG135XETE,    Z_RG136CSTE,    Z_RG137CSTE,    Z_RG138CSTE,
     &     Z_RG138XETE,    Z_RG140BATE,    Z_RG140LATE,    Z_RG144CETE,
     &     Z_RG144CSTE,    Z_RG144PRTE,    Z_RG16NTE,      Z_RG41ARTE,
     &     Z_RG60COTE,     Z_RG85KRTE,     Z_RG87KRTE,     Z_RG88KRTE,
     &     Z_RG88RBTE,     Z_RG89SRTE,     Z_RG90SRTE,     Z_RG90YTE,
     &     Z_RG91SRTE,     Z_RG91YTE,      Z_RG92SRTE,     Z_RG92YTE,
     &     Z_RGM133XETE,   Z_RGM135XETE,   Z_RGM144PRTE,   Z_RGM85KRTE,
     &     Z_RG131ITE2,    Z_RG132ITE2,    Z_RG132TETE2,   Z_RG133ITE2,
     &     Z_RG133XETE2,   Z_RG134CSTE2,   Z_RG134ITE2,    Z_RG135ITE2,
     &     Z_RG135XETE2,   Z_RG136CSTE2,   Z_RG137CSTE2,   Z_RG138CSTE2,
     &     Z_RG138XETE2,   Z_RG140BATE2,   Z_RG140LATE2,   Z_RG144CETE2,
     &     Z_RG144CSTE2,   Z_RG144PRTE2,   Z_RG16NTE2,     Z_RG41ARTE2,
     &     Z_RG60COTE2,    Z_RG85KRTE2,    Z_RG87KRTE2,    Z_RG88KRTE2,
     &     Z_RG88RBTE2,    Z_RG89SRTE2,    Z_RG90SRTE2,    Z_RG90YTE2,
     &     Z_RG91SRTE2,    Z_RG91YTE2,     Z_RG92SRTE2,    Z_RG92YTE2,
     &     Z_RGM133XETE2,  Z_RGM135XETE2,  Z_RGM144PRTE2,  Z_RGM85KRTE2,
     &     Z_G131I,        Z_G132I,        Z_G132TE,       Z_G133I,
     &     Z_G133XE,       Z_G134CS,       Z_G134I,        Z_G135I,
     &     Z_G135XE,       Z_G136CS,       Z_G137CS,       Z_G138CS,
     &     Z_G138XE,       Z_G140BA,       Z_G140LA,       Z_G144CE,
     &     Z_G144CS,       Z_G144PR,       Z_G16N,         Z_G41AR,
     &     Z_G60CO,        Z_G85KR,        Z_G87KR,        Z_G88KR,
     &     Z_G88RB,        Z_G89SR,        Z_G90SR,        Z_G90Y,
     &     Z_G91SR,        Z_G91Y,         Z_G92SR,        Z_G92Y,
     &     Z_GM133XE,      Z_GM135XE,      Z_GM144PR,      Z_GM85KR,
     &     Z_CWG131I,      Z_CWG132I,      Z_CWG132TE,     Z_CWG133I,
     &     Z_CWG133XE,     Z_CWG134CS,     Z_CWG134I,      Z_CWG135I,
     &     Z_CWG135XE,     Z_CWG136CS,     Z_CWG137CS,     Z_CWG138CS,
     &     Z_CWG138XE,     Z_CWG140BA,     Z_CWG140LA,     Z_CWG144CE,
     &     Z_CWG144CS,     Z_CWG144PR,     Z_CWG16N,       Z_CWG41AR,
     &     Z_CWG60CO,      Z_CWG85KR,      Z_CWG87KR,      Z_CWG88KR,
     &     Z_CWG88RB,      Z_CWG89SR,      Z_CWG90SR,      Z_CWG90Y,
     &     Z_CWG91SR,      Z_CWG91Y,       Z_CWG92SR,      Z_CWG92Y,
     &     Z_CWGM133XE,    Z_CWGM135XE,    Z_CWGM144PR,    Z_CWGM85KR,
     &     Z_RG131ID,      Z_RG132ID,      Z_RG132TED,     Z_RG133ID,
     &     Z_RG133XED,     Z_RG134CSD,     Z_RG134ID,      Z_RG135ID,
     &     Z_RG135XED,     Z_RG136CSD,     Z_RG137CSD,     Z_RG138CSD,
     &     Z_RG138XED,     Z_RG140BAD,     Z_RG140LAD,     Z_RG144CED,
     &     Z_RG144CSD,     Z_RG144PRD,     Z_RG16ND,       Z_RG41ARD,
     &     Z_RG60COD,      Z_RG85KRD,      Z_RG87KRD,      Z_RG88KRD,
     &     Z_RG88RBD,      Z_RG89SRD,      Z_RG90SRD,      Z_RG90YD,
     &     Z_RG91SRD,      Z_RG91YD,       Z_RG92SRD,      Z_RG92YD,
     &     Z_RGM133XED,    Z_RGM135XED,    Z_RGM144PRD,    Z_RGM85KRD,
     &     ZNDFRAC131I,    ZNDFRAC132I,    ZNDFRAC132TE,   ZNDFRAC133I,
     &     ZNDFRAC133XE,   ZNDFRAC134CS,   ZNDFRAC134I,    ZNDFRAC135I,
     &     ZNDFRAC135XE,   ZNDFRAC136CS,   ZNDFRAC137CS,   ZNDFRAC138CS,
     &     ZNDFRAC138XE,   ZNDFRAC140BA,   ZNDFRAC140LA,   ZNDFRAC144CE,
     &     ZNDFRAC144CS,   ZNDFRAC144PR,   ZNDFRAC16N,     ZNDFRAC41AR,
     &     ZNDFRAC60CO,    ZNDFRAC85KR,    ZNDFRAC87KR,    ZNDFRAC88KR,
     &     ZNDFRAC88RB,    ZNDFRAC89SR,    ZNDFRAC90SR,    ZNDFRAC90Y,
     &     ZNDFRAC91SR,    ZNDFRAC91Y,     ZNDFRAC92SR,    ZNDFRAC92Y,
     &     ZNDFRACM133XE,  ZNDFRACM135XE,  ZNDFRACM144PR,  ZNDFRACM85KR,
     &     Z_RG131ITB6,    Z_RG132ITB6,    Z_RG132TETB6,   Z_RG133ITB6,
     &     Z_RG133XETB6,   Z_RG134CSTB6,   Z_RG134ITB6,    Z_RG135ITB6,
     &     Z_RG135XETB6,   Z_RG136CSTB6,   Z_RG137CSTB6,   Z_RG138CSTB6,
     &     Z_RG138XETB6,   Z_RG140BATB6,   Z_RG140LATB6,   Z_RG144CETB6,
     &     Z_RG144CSTB6,   Z_RG144PRTB6,   Z_RG16NTB6,     Z_RG41ARTB6,
     &     Z_RG60COTB6,    Z_RG85KRTB6,    Z_RG87KRTB6,    Z_RG88KRTB6,
     &     Z_RG88RBTB6,    Z_RG89SRTB6,    Z_RG90SRTB6,    Z_RG90YTB6,
     &     Z_RG91SRTB6,    Z_RG91YTB6,     Z_RG92SRTB6,    Z_RG92YTB6,
     &     Z_RGM133XETB6,  Z_RGM135XETB6,  Z_RGM144PRTB6,  Z_RGM85KRTB6,
     &     Z_HTB6,         Z_WTB6,         Z_PTB6,         Z_BN2TB6,
     &     Z_BHYDTB6,   Z_BOXYTB6,      Z_BSTB6,        Z_BATB6,
     &     Z_BHTB6  ,      Z_XATB2,        Z_XATB3,        Z_XATB4,
     &     Z_XATB5,        Z_XATB6,
     &     Z_BSHW1A, Z_BSHW1B,
     &     Z_BAHW1A, Z_BAHW1B,
     &     Z_BHHW1A, Z_BHHW1B,
     &     Z_WWO1A,  Z_WWO1B,  Z_WWO2A,  Z_WWO2B,
     &     Z_HLIN1A, Z_HLIN1B, Z_HLIN2A, Z_HLIN2B,
     &     Z_CKSUB,
     &     Z_WN2I,    Z_WN2O,    Z_WO2I,     Z_WO2O,
     &     Z_BOXYDI1, Z_BOXYDI2, Z_BN2DI1,   Z_BN2DI2,
     &     Z_MO2,     Z_MN2,
     &     Z_BN2LEFT, Z_BO2LEFT, Z_BN2RIGHT, Z_BO2RIGHT,
     &     Z_MGAS,   Z_XH2O, ZH2OGAS, Z_HGAS, Z_HGASL, Z_HAIR, Z_TTOTL,
     &     Z_CPMIX,
     &     Z_MG131I,   Z_MG132I,   Z_MG132TE,   Z_MG133I,    Z_MG133XE,
     &     Z_MG134CS,  Z_MG134I,   Z_MG135I,    Z_MG135XE,   Z_MG136CS,
     &    Z_MG137CS,  Z_MG138CS,  Z_MG138XE,   Z_MG140BA,   Z_MG140LA,
     &    Z_MG144CE,  Z_MG144CS,  Z_MG144PR,   Z_MG16N,     Z_MG41AR,
     &    Z_MG60CO,   Z_MG85KR,   Z_MG87KR,    Z_MG88KR,    Z_MG88RB,
     &    Z_MG89SR,   Z_MG90SR,   Z_MG90Y,     Z_MG91SR,    Z_MG91Y,
     &    Z_MG92SR,   Z_MG92Y,    Z_MGM133XE,  Z_MGM135XE,  Z_MGM144PR,  Z_MGM85KR,
     &    Z_MHW131I,  Z_MHW132I,  Z_MHW132TE,  Z_MHW133I,   Z_MHW133XE,
     &    Z_MHW134CS, Z_MHW134I,  Z_MHW135I,   Z_MHW135XE,  Z_MHW136CS,
     &    Z_MHW137CS, Z_MHW138CS, Z_MHW138XE,  Z_MHW140BA,  Z_MHW140LA,
     &    Z_MHW144CE, Z_MHW144CS, Z_MHW144PR,  Z_MHW16N,    Z_MHW41AR,
     &    Z_MHW60CO,  Z_MHW85KR,  Z_MHW87KR,   Z_MHW88KR,   Z_MHW88RB,
     &    Z_MHW89SR,  Z_MHW90SR,  Z_MHW90Y,    Z_MHW91SR,   Z_MHW91Y,
     &    Z_MHW92SR,  Z_MHW92Y,   Z_MHWM133XE, Z_MHWM135XE, Z_MHWM144PR, Z_MHWM85KR,
     &    Z_131IAR1,    Z_132IAR1,    Z_132TEAR1,   Z_133IAR1,  Z_133XEAR1,   Z_134CSAR1,   Z_134IAR1,    Z_135IAR1,
     &    Z_135XEAR1,   Z_136CSAR1,   Z_137CSAR1,   Z_138CSAR1, Z_138XEAR1,   Z_140BAAR1,   Z_140LAAR1,   Z_144CEAR1,
     &    Z_144CSAR1,   Z_144PRAR1,   Z_16NAR1,     Z_41ARAR1,  Z_60COAR1,    Z_85KRAR1,    Z_87KRAR1,    Z_88KRAR1,
     &    Z_88RBAR1,    Z_89SRAR1,    Z_90SRAR1,    Z_90YAR1,   Z_91SRAR1,    Z_91YAR1,     Z_92SRAR1,    Z_92YAR1,
     &    Z_M133XEAR1,  Z_M135XEAR1,  Z_M144PRAR1,  Z_M85KRAR1,
     &    Z_HAR1,       Z_WAR1,       Z_BGASAR1,   Z_BN2AR1,   Z_BHYDAR1, Z_BOXYAR1,    Z_XAAR1,     Z_XH2OAR1,
     &    Z_131IAR2,    Z_132IAR2,    Z_132TEAR2,   Z_133IAR2,  Z_133XEAR2,   Z_134CSAR2,   Z_134IAR2,    Z_135IAR2,
     &    Z_135XEAR2,   Z_136CSAR2,   Z_137CSAR2,   Z_138CSAR2, Z_138XEAR2,   Z_140BAAR2,   Z_140LAAR2,   Z_144CEAR2,
     &    Z_144CSAR2,   Z_144PRAR2,   Z_16NAR2,     Z_41ARAR2,  Z_60COAR2,    Z_85KRAR2,    Z_87KRAR2,    Z_88KRAR2,
     &    Z_88RBAR2,    Z_89SRAR2,    Z_90SRAR2,    Z_90YAR2,   Z_91SRAR2,    Z_91YAR2,     Z_92SRAR2,    Z_92YAR2,
     &    Z_M133XEAR2,  Z_M135XEAR2,  Z_M144PRAR2,  Z_M85KRAR2,
     &    Z_HAR2,       Z_WAR2,       Z_BGASAR2,   Z_BN2AR2,   Z_BHYDAR2, Z_BOXYAR2,    Z_XAAR2,     Z_XH2OAR2,
     &    Z_BOXYL2,     Z_BN2L2,      Z_BHYDL2,     Z_HGASL2,   Z_TTOTL2,     Z_XH2O2)
      IMPLICIT NONE
C     =================
C     Real Declarations
C     =================
C
C
      REAL*4     Z_PEQL     ! LEFT
      REAL*4     Z_HEQL     ! LEFT
      REAL*4     Z_XEQL     ! LEFT
      REAL*4     Z_WAEQL    ! AIR F
      REAL*4     Z_WSEQL    ! STM F
      REAL*4     Z_WAEQR    ! AIR F
      REAL*4     Z_WSEQR    ! STM F
      REAL*4     Z_BHSI     ! VARIO
      REAL*4     Z_BHYDSI   ! VARIO
      REAL*4     Z_BN2SI    ! VARIO
      REAL*4     Z_PEQR     ! RIGHT
      REAL*4     Z_HEQR     ! RIGHT
      REAL*4     Z_XEQR     ! RIGHT
      REAL*4     Z_MEQR     ! RIGHT
      REAL*4     Z_WTE      ! TURBI
      REAL*4     Z_PTE      ! TURB
      REAL*4     Z_HTE      ! TURB
      REAL*4     Z_BHTE     ! TURB
      REAL*4     Z_BHYDTE   ! TURB
      REAL*4     Z_BN2TE    ! TURB
      REAL*4     Z_BSTE     ! TURB
      REAL*4     Z_BATE     ! TURB
      REAL*4     Z_WTE2     ! LP ST
      REAL*4     Z_PTE2     ! LP ST
      REAL*4     Z_HTE2     ! LP ST
      REAL*4     Z_BHTE2    ! LP ST
      REAL*4     Z_BHYDTE2  ! LP ST
      REAL*4     Z_BN2TE2   ! LP ST
      REAL*4     Z_BSTE2    ! LP ST
      REAL*4     Z_BATE2    ! LP ST
      REAL*4     Z_WTB      ! TURBI
      REAL*4     Z_PTB      ! TURBI
      REAL*4     Z_HTB      ! TURB
      REAL*4     Z_BHTB     ! TURB
      REAL*4     Z_BHYDTB   ! TURB
      REAL*4     Z_BN2TB    ! TURB
      REAL*4     Z_BSTB     ! TURB
      REAL*4     Z_BATB     ! TURB
      REAL*4     Z_WTB2     ! TURBI
      REAL*4     Z_PTB2     ! TURBI
      REAL*4     Z_HTB2     ! TURB
      REAL*4     Z_BHTB2    ! TURB
      REAL*4     Z_BHYDTB2  ! TURB
      REAL*4     Z_BN2TB2   ! TURB
      REAL*4     Z_BSTB2    ! TURB
      REAL*4     Z_BATB2    ! TURB
      REAL*4     Z_WTB3     ! TURBI
      REAL*4     Z_PTB3     ! TURBI
      REAL*4     Z_HTB3     ! TURB
      REAL*4     Z_BHTB3    ! TURB
      REAL*4     Z_BHYDTB3  ! TURB
      REAL*4     Z_BN2TB3   ! TURB
      REAL*4     Z_BSTB3    ! TURB
      REAL*4     Z_BATB3    ! TURB
      REAL*4     Z_WTB4     ! TURBI
      REAL*4     Z_PTB4     ! TURBI
      REAL*4     Z_HTB4     ! TURB
      REAL*4     Z_BHTB4    ! TURB
      REAL*4     Z_BHYDTB4  ! TURB
      REAL*4     Z_BN2TB4   ! TURB
      REAL*4     Z_BSTB4    ! TURB
      REAL*4     Z_BATB4    ! TURB
      REAL*4     Z_WTB5     ! TURB
      REAL*4     Z_PTB5     ! TURB
      REAL*4     Z_HTB5     ! TURB
      REAL*4     Z_BHTB5    ! TURB
      REAL*4     Z_BHYDTB5  ! TURB
      REAL*4     Z_BN2TB5   ! TURB
      REAL*4     Z_BSTB5    ! TURB
      REAL*4     Z_BATB5    ! TURB
      REAL*4     Z_WSI      ! VARIO
      REAL*4     Z_WSO      ! VARIO
      REAL*4     Z_HSI      ! VARIO
      REAL*4     Z_BSSI     ! VARIO
      REAL*4     Z_BASI     ! VARIO
      REAL*4     Z_WDI1     ! INLET
      REAL*4     Z_WDI2     ! INLET
      REAL*4     Z_HDI1     ! INLET
      REAL*4     Z_HDI2     ! INLET
      REAL*4     Z_BSDI1    ! INLET
      REAL*4     Z_BADI1    ! INLET
      REAL*4     Z_BHDI1    ! INLET
      REAL*4     Z_WWO1     ! OUTLE
      REAL*4     Z_WWO2     ! OUTLE
      REAL*4     Z_WA1      ! A/R O
      REAL*4     Z_WA2      ! A/R O
      REAL*4     Z_WC1      ! CIRCU
      REAL*4     Z_WC2      ! CIRCU
      REAL*4     Z_TCI1     ! INLET
      REAL*4     Z_TCI2     ! INLET
      REAL*4     TVZ_0001   ! CONDE
      REAL*4     TAZ_F1     ! BUNDL
      REAL*4     TAZ_F2     ! BUNDL
      REAL*4     TAZ_VAC    ! CONDE
      REAL*4     Z_BA       ! CONDE
      REAL*4     Z_BS       ! CONDE
      REAL*4     Z_BH       ! CONDE
      REAL*4     Z_BHYD     ! CONDE
      REAL*4     Z_BN2      ! CONDE
      REAL*4     Z_BHYDL    ! LOCAL
      REAL*4     Z_BN2L     ! LOCAL
      REAL*4     Z_BO1      ! COND
      REAL*4     Z_BO2      ! COND
      REAL*4     Z_BS1      ! COND
      REAL*4     Z_BS2      ! COND
      REAL*4     Z_DL1      ! HOTWE
      REAL*4     Z_DL2      ! HOTWE
      REAL*4     Z_DSTM     ! COND.
      REAL*4     Z_HL1      ! HOTWE
      REAL*4     Z_HL2      ! HOTWE
      REAL*4     Z_HFD      ! SAT.
      REAL*4     Z_HGD      ! SAT.
      REAL*4     Z_HGPT     ! VAPOR
      REAL*4     Z_HA1      ! AIR R
      REAL*4     Z_HA2      ! AIR R
      REAL*4     Z_CPGPT    ! VAPOR
      REAL*4     Z_HSTM     ! SP EN
      REAL*4     Z_L1       ! HOTWE
      REAL*4     Z_L2       ! HOTWE
      REAL*4     Z_MAIR     ! MASS
      REAL*4     Z_ML1      ! HOTWE
      REAL*4     Z_ML2      ! HOTWE
      REAL*4     Z_MSTM     ! MASS
      REAL*4     Z_PAIR     ! CONDE
      REAL*4     Z_PTOT     ! TOTAL
      REAL*4     Z_PTOTB1   ! COND
      REAL*4     Z_PTOTB2   ! COND
      REAL*4     Z_PSTM     ! PARTI
      REAL*4     Z_Q1       ! CONDE
      REAL*4     Z_Q2       ! CONDE
      REAL*4     Z_QLS1     ! HT XS
      REAL*4     Z_QLS2     ! HT XS
      REAL*4     Z_QW1      ! HT XF
      REAL*4     Z_QW2      ! HT XF
      REAL*4     Z_R1       ! AIR E
      REAL*4     Z_R2       ! AIR E
      REAL*4     Z_BA1      ! HW1 A
      REAL*4     Z_BH1      ! HW1 H
      REAL*4     Z_BA2      ! HW2 A
      REAL*4     Z_BH2      ! HW2 H
      REAL*4     Z_TCO1     ! CIRC.
      REAL*4     Z_TCO2     ! CIRC.
      REAL*4     Z_TL1      ! HOTWE
      REAL*4     Z_TL2      ! HOTWE
      REAL*4     Z_TM1      ! BUNDL
      REAL*4     Z_TM2      ! BUNDL
      REAL*4     Z_TSAT     ! CONDE
      REAL*4     Z_TSTM     ! MAIN
      REAL*4     Z_TTOT     ! MAIN
      REAL*4     Z_TWM1     ! CIRC.
      REAL*4     Z_TWM2     ! CIRC.
      REAL*4     Z_VL1      ! COND.
      REAL*4     Z_VL2      ! COND.
      REAL*4     Z_VSTM     ! COND.
      REAL*4     Z_WAN      ! NORMA
      REAL*4     Z_WAO      ! VARIO
      REAL*4     Z_WAI      ! VARIO
      REAL*4     Z_WCN1     ! CONDE
      REAL*4     Z_WCN2     ! CONDE
      REAL*4     Z_WEVP1    ! HOTWE
      REAL*4     Z_WEVP2    ! HOTWE
      REAL*4     Z_WRN      ! RAIN-
      REAL*4     Z_X1       ! AIR/S
      REAL*4     Z_X2       ! AIR/S
      REAL*4     Z_XAIR     ! GLOBA
      REAL*4     Z_XQ       ! STEAM
      REAL*4     Z_CEQUAL   ! EQUAL
      REAL*4     Z_CWRL     ! EVAPO
      REAL*4     Z_CWRM     ! EVAPO
      REAL*4     Z_CWRC     ! EVAPO
      REAL*4     Z_CWBS     ! EVAPO
      REAL*4     Z_CWBA     ! EVAPO
      REAL*4     Z_CWBH     ! EVAPO
      REAL*4     Z_C1       ! INTER
      REAL*4     Z_C2       ! INT.
      REAL*4     Z_CA       ! TOTAL
      REAL*4     Z_COX      ! OXYGE
      REAL*4     Z_CCPM     ! METAL
      REAL*4     Z_CDEVP    ! DELAY
      REAL*4     Z_CDRN     ! DELAY
      REAL*4     Z_CERN     ! RAIN-
      REAL*4     Z_CHOTW    ! 1/(#H
      REAL*4     Z_CKLS     ! HT TR
      REAL*4     Z_CKAL     ! HT XS
      REAL*4     Z_CKAS     ! HT XS
      REAL*4     Z_CKS      ! HEAT
      REAL*4     Z_CKW      ! WATER
      REAL*4     Z_CK2      ! HT XS
      REAL*4     Z_CKAT     ! HT XS
      REAL*4     Z_CKAIR    ! NORMA
      REAL*4     Z_CKHOT    ! ABOVE
      REAL*4     Z_CLBB     ! LEVEL
      REAL*4     Z_CLBT     ! LEVEL
      REAL*4     Z_CLDIV    ! HOTWE
      REAL*4     Z_CLKA     ! AIR I
      REAL*4     Z_CLTU     ! LENGT
      REAL*4     Z_CI1      ! INTER
      REAL*4     Z_CM1      ! SLOPE
      REAL*4     Z_CM2      ! SLOPE
      REAL*4     Z_CI1H2    ! INTER
      REAL*4     Z_CM1H2    ! SLOPE
      REAL*4     Z_CM2H2    ! SLOPE
      REAL*4     Z_CMM      ! MASS
      REAL*4     Z_CMW      ! MASS
      REAL*4     Z_CV       ! TOTAL
      REAL*4     X_CVINC11  ! HOTWE
      REAL*4     X_CVINC12  ! HOTWE
      REAL*4     X_CVINC21  ! HOTWE
      REAL*4     X_CVINC22  ! HOTWE
      REAL*4     Z_CVSWT    ! SWITC
      REAL*4     Z_CLHW(*)  ! HOTWE
      REAL*4     Z_CVMIN    ! MIN.
      REAL*4     Z_CX       ! LOCAL
      REAL*4     Z_CXH2     ! LOCAL
      REAL*4     TAFLO      ! LONG
      REAL*4     TAFMD      ! MEDIU
      REAL*4     TATAMB     ! AMBIE
      REAL*4     TAPAMB     ! AMBIE
      REAL*4     YITIM      ! ITERA
      REAL*4     YIFRE      ! FREQU
      REAL*4     Z_CPLAG    ! PRESS
      REAL*4     ZCCALD1    ! CALEN
      REAL*4     ZCCALD2    ! CALEN
      REAL*4     Z_CMMIN    ! MIN.
      REAL*4     Z_CMH      ! MIN S
      REAL*4     Z_CSTMTL   ! STEAM
      REAL*4     Z_CDTDH    ! DT/DH
      REAL*4     Z_CWTMIN   ! MIN.
      REAL*4     ZCCPWTR    ! HEAT
      REAL*4     ZCRAIR     ! GAS C
      REAL*4     ZCTABS     ! CONVE
      REAL*4     ZCPHEL     ! LEVEL
      REAL*4     ZCCPAIR    ! AIR S
      REAL*4     Z_XL1      ! BOX C
      REAL*4     Z_XL2      ! BOX C
      REAL*4     ZCTSR      ! VAPOR
      REAL*4     Z_XATE     ! TURBI
      REAL*4     Z_XATB     ! TURBI
      REAL*4     Z_XATB2    ! TURBI
      REAL*4     Z_XATB3    ! TURBI
      REAL*4     Z_XATB4    ! TURBI
      REAL*4     Z_XATB5    ! TURBI
      REAL*4     Z_XATB6    ! TURBI
      REAL*4     ZCWSMIN    ! MINIM
      REAL*4     ZCWLMIN    ! MINIM
      REAL*4     Z_RLD      ! CONDE
      REAL*4     Z_RMD      ! CONDE
      REAL*4     Z_RCD      ! CONDE
      REAL*4     Z_BOXYTE   ! TURB
      REAL*4     Z_BOXYTE2  ! LP ST
      REAL*4     Z_BOXYTB   ! TURB
      REAL*4     Z_BOXYTB2  ! TURB
      REAL*4     Z_BOXYTB3  ! TURB
      REAL*4     Z_BOXYTB4  ! TURB
      REAL*4     Z_BOXYTB5  ! TURB
      REAL*4     Z_BOXYSI   ! VARIO
      REAL*4     Z_BOXY     ! GLOBA
      REAL*4     Z_BOXYL    ! LOCAL
      REAL*4     Z_CX_2     ! LOCAL
     REAL*4     XC02WBOXY  ! STM INLET
     REAL*4     X_STML     ! MIN. LOCA
     REAL*4     Z_CPAIR    ! SPECIFIC
     REAL*4    Z_CEQFL   ! EQ LINE F
      REAL*4     ZCCA1RM    ! MAX.
      REAL*4     Z_XATE2    ! TURBI
      REAL*4     X_HLIN1    ! SUM O
      REAL*4     X_HLIN2    ! SUM O
      REAL*4     Z_RG131IDI1  ! HW1
      REAL*4     Z_RG132IDI1  ! HW1
      REAL*4     Z_RG132TEDI1 ! HW1
      REAL*4     Z_RG133IDI1  ! HW1
      REAL*4     Z_RG133XEDI1 ! HW1
      REAL*4     Z_RG134CSDI1 ! HW1
      REAL*4     Z_RG134IDI1  ! HW1
      REAL*4     Z_RG135IDI1  ! HW1
      REAL*4     Z_RG135XEDI1 ! HW1
      REAL*4     Z_RG136CSDI1 ! HW1
      REAL*4     Z_RG137CSDI1 ! HW1
      REAL*4     Z_RG138CSDI1 ! HW1
      REAL*4     Z_RG138XEDI1 ! HW1
      REAL*4     Z_RG140BADI1 ! HW1
      REAL*4     Z_RG140LADI1 ! HW1
      REAL*4     Z_RG144CEDI1 ! HW1
      REAL*4     Z_RG144CSDI1 ! HW1
      REAL*4     Z_RG144PRDI1 ! HW1
      REAL*4     Z_RG16NDI1   ! HW1
      REAL*4     Z_RG41ARDI1  ! HW1
      REAL*4     Z_RG60CODI1  ! HW1
      REAL*4     Z_RG85KRDI1  ! HW1
      REAL*4     Z_RG87KRDI1  ! HW1
      REAL*4     Z_RG88KRDI1  ! HW1
      REAL*4     Z_RG88RBDI1  ! HW1
      REAL*4     Z_RG89SRDI1  ! HW1
      REAL*4     Z_RG90SRDI1  ! HW1
      REAL*4     Z_RG90YDI1   ! HW1
      REAL*4     Z_RG91SRDI1  ! HW1
      REAL*4     Z_RG91YDI1   ! HW1
      REAL*4     Z_RG92SRDI1  ! HW1
      REAL*4     Z_RG92YDI1   ! HW1
      REAL*4     Z_RGM133XEDI1 ! HW
      REAL*4     Z_RGM135XEDI1 ! HW
      REAL*4     Z_RGM144PRDI1 ! HW
      REAL*4     Z_RGM85KRDI1 ! HW1
      REAL*4     Z_RG131ISI   ! VAR
      REAL*4     Z_RG132ISI   ! VAR
      REAL*4     Z_RG132TESI  ! VAR
      REAL*4     Z_RG133ISI   ! VAR
      REAL*4     Z_RG133XESI  ! VAR
      REAL*4     Z_RG134CSSI  ! VAR
      REAL*4     Z_RG134ISI   ! VAR
      REAL*4     Z_RG135ISI   ! VAR
      REAL*4     Z_RG135XESI  ! VAR
      REAL*4     Z_RG136CSSI  ! VAR
      REAL*4     Z_RG137CSSI  ! VAR
      REAL*4     Z_RG138CSSI  ! VAR
      REAL*4     Z_RG138XESI  ! VAR
      REAL*4     Z_RG140BASI  ! VAR
      REAL*4     Z_RG140LASI  ! VAR
      REAL*4     Z_RG144CESI  ! VAR
      REAL*4     Z_RG144CSSI  ! VAR
      REAL*4     Z_RG144PRSI  ! VAR
      REAL*4     Z_RG16NSI    ! VAR
      REAL*4     Z_RG41ARSI   ! VAR
      REAL*4     Z_RG60COSI   ! VAR
      REAL*4     Z_RG85KRSI   ! VAR
      REAL*4     Z_RG87KRSI   ! VAR
      REAL*4     Z_RG88KRSI   ! VAR
      REAL*4     Z_RG88RBSI   ! VAR
      REAL*4     Z_RG89SRSI   ! VAR
      REAL*4     Z_RG90SRSI   ! VAR
      REAL*4     Z_RG90YSI    ! VAR
      REAL*4     Z_RG91SRSI   ! VAR
      REAL*4     Z_RG91YSI    ! VAR
      REAL*4     Z_RG92SRSI   ! VAR
      REAL*4     Z_RG92YSI    ! VAR
      REAL*4     Z_RGM133XESI ! VAR
      REAL*4     Z_RGM135XESI ! VAR
      REAL*4     Z_RGM144PRSI ! VAR
      REAL*4     Z_RGM85KRSI  ! VAR
      REAL*4     Z_RG131IHW1  ! HOT
      REAL*4     Z_RG132IHW1  ! HOT
      REAL*4     Z_RG132TEHW1 ! HOT
      REAL*4     Z_RG133IHW1  ! HOT
      REAL*4     Z_RG133XEHW1 ! HOT
      REAL*4     Z_RG134CSHW1 ! HOT
      REAL*4     Z_RG134IHW1  ! HOT
      REAL*4     Z_RG135IHW1  ! HOT
      REAL*4     Z_RG135XEHW1 ! HOT
      REAL*4     Z_RG136CSHW1 ! HOT
      REAL*4     Z_RG137CSHW1 ! HOT
      REAL*4     Z_RG138CSHW1 ! HOT
      REAL*4     Z_RG138XEHW1 ! HOT
      REAL*4     Z_RG140BAHW1 ! HOT
      REAL*4     Z_RG140LAHW1 ! HOT
      REAL*4     Z_RG144CEHW1 ! HOT
      REAL*4     Z_RG144CSHW1 ! HOT
      REAL*4     Z_RG144PRHW1 ! HOT
      REAL*4     Z_RG16NHW1   ! HOT
      REAL*4     Z_RG41ARHW1  ! HOT
      REAL*4     Z_RG60COHW1  ! HOT
      REAL*4     Z_RG85KRHW1  ! HOT
      REAL*4     Z_RG87KRHW1  ! HOT
      REAL*4     Z_RG88KRHW1  ! HOT
      REAL*4     Z_RG88RBHW1  ! HOT
      REAL*4     Z_RG89SRHW1  ! HOT
      REAL*4     Z_RG90SRHW1  ! HOT
      REAL*4     Z_RG90YHW1   ! HOT
      REAL*4     Z_RG91SRHW1  ! HOT
      REAL*4     Z_RG91YHW1   ! HOT
      REAL*4     Z_RG92SRHW1  ! HOT
      REAL*4     Z_RG92YHW1   ! HOT
      REAL*4     Z_RGM133XEHW1 ! HO
      REAL*4     Z_RGM135XEHW1 ! HO
      REAL*4     Z_RGM144PRHW1 ! HO
      REAL*4     Z_RGM85KRHW1 ! HOT
      REAL*4     Z_RG131ITB   ! TUR
      REAL*4     Z_RG132ITB   ! TUR
      REAL*4     Z_RG132TETB  ! TUR
      REAL*4     Z_RG133ITB   ! TUR
      REAL*4     Z_RG133XETB  ! TUR
      REAL*4     Z_RG134CSTB  ! TUR
      REAL*4     Z_RG134ITB   ! TUR
      REAL*4     Z_RG135ITB   ! TUR
      REAL*4     Z_RG135XETB  ! TUR
      REAL*4     Z_RG136CSTB  ! TUR
      REAL*4     Z_RG137CSTB  ! TUR
      REAL*4     Z_RG138CSTB  ! TUR
      REAL*4     Z_RG138XETB  ! TUR
      REAL*4     Z_RG140BATB  ! TUR
      REAL*4     Z_RG140LATB  ! TUR
      REAL*4     Z_RG144CETB  ! TUR
      REAL*4     Z_RG144CSTB  ! TUR
      REAL*4     Z_RG144PRTB  ! TUR
      REAL*4     Z_RG16NTB    ! TUR
      REAL*4     Z_RG41ARTB   ! TUR
      REAL*4     Z_RG60COTB   ! TUR
      REAL*4     Z_RG85KRTB   ! TUR
      REAL*4     Z_RG87KRTB   ! TUR
      REAL*4     Z_RG88KRTB   ! TUR
      REAL*4     Z_RG88RBTB   ! TUR
      REAL*4     Z_RG89SRTB   ! TUR
      REAL*4     Z_RG90SRTB   ! TUR
      REAL*4     Z_RG90YTB    ! TUR
      REAL*4     Z_RG91SRTB   ! TUR
      REAL*4     Z_RG91YTB    ! TUR
      REAL*4     Z_RG92SRTB   ! TUR
      REAL*4     Z_RG92YTB    ! TUR
      REAL*4     Z_RGM133XETB ! TUR
      REAL*4     Z_RGM135XETB ! TUR
      REAL*4     Z_RGM144PRTB ! TUR
      REAL*4     Z_RGM85KRTB  ! TUR
      REAL*4     Z_RG131ITB2  ! TUR
      REAL*4     Z_RG132ITB2  ! TUR
      REAL*4     Z_RG132TETB2 ! TUR
      REAL*4     Z_RG133ITB2  ! TUR
      REAL*4     Z_RG133XETB2 ! TUR
      REAL*4     Z_RG134CSTB2 ! TUR
      REAL*4     Z_RG134ITB2  ! TUR
      REAL*4     Z_RG135ITB2  ! TUR
      REAL*4     Z_RG135XETB2 ! TUR
      REAL*4     Z_RG136CSTB2 ! TUR
      REAL*4     Z_RG137CSTB2 ! TUR
      REAL*4     Z_RG138CSTB2 ! TUR
      REAL*4     Z_RG138XETB2 ! TUR
      REAL*4     Z_RG140BATB2 ! TUR
      REAL*4     Z_RG140LATB2 ! TUR
      REAL*4     Z_RG144CETB2 ! TUR
      REAL*4     Z_RG144CSTB2 ! TUR
      REAL*4     Z_RG144PRTB2 ! TUR
      REAL*4     Z_RG16NTB2   ! TUR
      REAL*4     Z_RG41ARTB2  ! TUR
      REAL*4     Z_RG60COTB2  ! TUR
      REAL*4     Z_RG85KRTB2  ! TUR
      REAL*4     Z_RG87KRTB2  ! TUR
      REAL*4     Z_RG88KRTB2  ! TUR
      REAL*4     Z_RG88RBTB2  ! TUR
      REAL*4     Z_RG89SRTB2  ! TUR
      REAL*4     Z_RG90SRTB2  ! TUR
      REAL*4     Z_RG90YTB2   ! TUR
      REAL*4     Z_RG91SRTB2  ! TUR
      REAL*4     Z_RG91YTB2   ! TUR
      REAL*4     Z_RG92SRTB2  ! TUR
      REAL*4     Z_RG92YTB2   ! TUR
      REAL*4     Z_RGM133XETB2 ! TU
      REAL*4     Z_RGM135XETB2 ! TU
      REAL*4     Z_RGM144PRTB2 ! TU
      REAL*4     Z_RGM85KRTB2 ! TUR
      REAL*4     Z_RG131ITB3  ! TUR
      REAL*4     Z_RG132ITB3  ! TUR
      REAL*4     Z_RG132TETB3 ! TUR
      REAL*4     Z_RG133ITB3  ! TUR
      REAL*4     Z_RG133XETB3 ! TUR
      REAL*4     Z_RG134CSTB3 ! TUR
      REAL*4     Z_RG134ITB3  ! TUR
      REAL*4     Z_RG135ITB3  ! TUR
      REAL*4     Z_RG135XETB3 ! TUR
      REAL*4     Z_RG136CSTB3 ! TUR
      REAL*4     Z_RG137CSTB3 ! TUR
      REAL*4     Z_RG138CSTB3 ! TUR
      REAL*4     Z_RG138XETB3 ! TUR
      REAL*4     Z_RG140BATB3 ! TUR
      REAL*4     Z_RG140LATB3 ! TUR
      REAL*4     Z_RG144CETB3 ! TUR
      REAL*4     Z_RG144CSTB3 ! TUR
      REAL*4     Z_RG144PRTB3 ! TUR
      REAL*4     Z_RG16NTB3   ! TUR
      REAL*4     Z_RG41ARTB3  ! TUR
      REAL*4     Z_RG60COTB3  ! TUR
      REAL*4     Z_RG85KRTB3  ! TUR
      REAL*4     Z_RG87KRTB3  ! TUR
      REAL*4     Z_RG88KRTB3  ! TUR
      REAL*4     Z_RG88RBTB3  ! TUR
      REAL*4     Z_RG89SRTB3  ! TUR
      REAL*4     Z_RG90SRTB3  ! TUR
      REAL*4     Z_RG90YTB3   ! TUR
      REAL*4     Z_RG91SRTB3  ! TUR
      REAL*4     Z_RG91YTB3   ! TUR
      REAL*4     Z_RG92SRTB3  ! TUR
      REAL*4     Z_RG92YTB3   ! TUR
      REAL*4     Z_RGM133XETB3 ! TU
      REAL*4     Z_RGM135XETB3 ! TU
      REAL*4     Z_RGM144PRTB3 ! TU
      REAL*4     Z_RGM85KRTB3 ! TUR
      REAL*4     Z_RG131ITB4  ! TUR
      REAL*4     Z_RG132ITB4  ! TUR
      REAL*4     Z_RG132TETB4 ! TUR
      REAL*4     Z_RG133ITB4  ! TUR
      REAL*4     Z_RG133XETB4 ! TUR
      REAL*4     Z_RG134CSTB4 ! TUR
      REAL*4     Z_RG134ITB4  ! TUR
      REAL*4     Z_RG135ITB4  ! TUR
      REAL*4     Z_RG135XETB4 ! TUR
      REAL*4     Z_RG136CSTB4 ! TUR
      REAL*4     Z_RG137CSTB4 ! TUR
      REAL*4     Z_RG138CSTB4 ! TUR
      REAL*4     Z_RG138XETB4 ! TUR
      REAL*4     Z_RG140BATB4 ! TUR
      REAL*4     Z_RG140LATB4 ! TUR
      REAL*4     Z_RG144CETB4 ! TUR
      REAL*4     Z_RG144CSTB4 ! TUR
      REAL*4     Z_RG144PRTB4 ! TUR
      REAL*4     Z_RG16NTB4   ! TUR
      REAL*4     Z_RG41ARTB4  ! TUR
      REAL*4     Z_RG60COTB4  ! TUR
      REAL*4     Z_RG85KRTB4  ! TUR
      REAL*4     Z_RG87KRTB4  ! TUR
      REAL*4     Z_RG88KRTB4  ! TUR
      REAL*4     Z_RG88RBTB4  ! TUR
      REAL*4     Z_RG89SRTB4  ! TUR
      REAL*4     Z_RG90SRTB4  ! TUR
      REAL*4     Z_RG90YTB4   ! TUR
      REAL*4     Z_RG91SRTB4  ! TUR
      REAL*4     Z_RG91YTB4   ! TUR
      REAL*4     Z_RG92SRTB4  ! TUR
      REAL*4     Z_RG92YTB4   ! TUR
      REAL*4     Z_RGM133XETB4 ! TU
      REAL*4     Z_RGM135XETB4 ! TU
      REAL*4     Z_RGM144PRTB4 ! TU
      REAL*4     Z_RGM85KRTB4 ! TUR
      REAL*4     Z_RG131ITB5  ! TUR
      REAL*4     Z_RG132ITB5  ! TUR
      REAL*4     Z_RG132TETB5 ! TUR
      REAL*4     Z_RG133ITB5  ! TUR
      REAL*4     Z_RG133XETB5 ! TUR
      REAL*4     Z_RG134CSTB5 ! TUR
      REAL*4     Z_RG134ITB5  ! TUR
      REAL*4     Z_RG135ITB5  ! TUR
      REAL*4     Z_RG135XETB5 ! TUR
      REAL*4     Z_RG136CSTB5 ! TUR
      REAL*4     Z_RG137CSTB5 ! TUR
      REAL*4     Z_RG138CSTB5 ! TUR
      REAL*4     Z_RG138XETB5 ! TUR
      REAL*4     Z_RG140BATB5 ! TUR
      REAL*4     Z_RG140LATB5 ! TUR
      REAL*4     Z_RG144CETB5 ! TUR
      REAL*4     Z_RG144CSTB5 ! TUR
      REAL*4     Z_RG144PRTB5 ! TUR
      REAL*4     Z_RG16NTB5   ! TUR
      REAL*4     Z_RG41ARTB5  ! TUR
      REAL*4     Z_RG60COTB5  ! TUR
      REAL*4     Z_RG85KRTB5  ! TUR
      REAL*4     Z_RG87KRTB5  ! TUR
      REAL*4     Z_RG88KRTB5  ! TUR
      REAL*4     Z_RG88RBTB5  ! TUR
      REAL*4     Z_RG89SRTB5  ! TUR
      REAL*4     Z_RG90SRTB5  ! TUR
      REAL*4     Z_RG90YTB5   ! TUR
      REAL*4     Z_RG91SRTB5  ! TUR
      REAL*4     Z_RG91YTB5   ! TUR
      REAL*4     Z_RG92SRTB5  ! TUR
      REAL*4     Z_RG92YTB5   ! TUR
      REAL*4     Z_RGM133XETB5 ! TU
      REAL*4     Z_RGM135XETB5 ! TU
      REAL*4     Z_RGM144PRTB5 ! TU
      REAL*4     Z_RGM85KRTB5 ! TUR
      REAL*4     Z_RG131ITE   ! TUR
      REAL*4     Z_RG132ITE   ! TUR
      REAL*4     Z_RG132TETE  ! TUR
      REAL*4     Z_RG133ITE   ! TUR
      REAL*4     Z_RG133XETE  ! TUR
      REAL*4     Z_RG134CSTE  ! TUR
      REAL*4     Z_RG134ITE   ! TUR
      REAL*4     Z_RG135ITE   ! TUR
      REAL*4     Z_RG135XETE  ! TUR
      REAL*4     Z_RG136CSTE  ! TUR
      REAL*4     Z_RG137CSTE  ! TUR
      REAL*4     Z_RG138CSTE  ! TUR
      REAL*4     Z_RG138XETE  ! TUR
      REAL*4     Z_RG140BATE  ! TUR
      REAL*4     Z_RG140LATE  ! TUR
      REAL*4     Z_RG144CETE  ! TUR
      REAL*4     Z_RG144CSTE  ! TUR
      REAL*4     Z_RG144PRTE  ! TUR
      REAL*4     Z_RG16NTE    ! TUR
      REAL*4     Z_RG41ARTE   ! TUR
      REAL*4     Z_RG60COTE   ! TUR
      REAL*4     Z_RG85KRTE   ! TUR
      REAL*4     Z_RG87KRTE   ! TUR
      REAL*4     Z_RG88KRTE   ! TUR
      REAL*4     Z_RG88RBTE   ! TUR
      REAL*4     Z_RG89SRTE   ! TUR
      REAL*4     Z_RG90SRTE   ! TUR
      REAL*4     Z_RG90YTE    ! TUR
      REAL*4     Z_RG91SRTE   ! TUR
      REAL*4     Z_RG91YTE    ! TUR
      REAL*4     Z_RG92SRTE   ! TUR
      REAL*4     Z_RG92YTE    ! TUR
      REAL*4     Z_RGM133XETE ! TUR
      REAL*4     Z_RGM135XETE ! TUR
      REAL*4     Z_RGM144PRTE ! TUR
      REAL*4     Z_RGM85KRTE  ! TUR
      REAL*4     Z_RG131ITE2  ! TUR
      REAL*4     Z_RG132ITE2  ! TUR
      REAL*4     Z_RG132TETE2 ! TUR
      REAL*4     Z_RG133ITE2  ! TUR
      REAL*4     Z_RG133XETE2 ! TUR
      REAL*4     Z_RG134CSTE2 ! TUR
      REAL*4     Z_RG134ITE2  ! TUR
      REAL*4     Z_RG135ITE2  ! TUR
      REAL*4     Z_RG135XETE2 ! TUR
      REAL*4     Z_RG136CSTE2 ! TUR
      REAL*4     Z_RG137CSTE2 ! TUR
      REAL*4     Z_RG138CSTE2 ! TUR
      REAL*4     Z_RG138XETE2 ! TUR
      REAL*4     Z_RG140BATE2 ! TUR
      REAL*4     Z_RG140LATE2 ! TUR
      REAL*4     Z_RG144CETE2 ! TUR
      REAL*4     Z_RG144CSTE2 ! TUR
      REAL*4     Z_RG144PRTE2 ! TUR
      REAL*4     Z_RG16NTE2   ! TUR
      REAL*4     Z_RG41ARTE2  ! TUR
      REAL*4     Z_RG60COTE2  ! TUR
      REAL*4     Z_RG85KRTE2  ! TUR
      REAL*4     Z_RG87KRTE2  ! TUR
      REAL*4     Z_RG88KRTE2  ! TUR
      REAL*4     Z_RG88RBTE2  ! TUR
      REAL*4     Z_RG89SRTE2  ! TUR
      REAL*4     Z_RG90SRTE2  ! TUR
      REAL*4     Z_RG90YTE2   ! TUR
      REAL*4     Z_RG91SRTE2  ! TUR
      REAL*4     Z_RG91YTE2   ! URB
      REAL*4     Z_RG92SRTE2  ! TUR
      REAL*4     Z_RG92YTE2   ! TUR
      REAL*4     Z_RGM133XETE2 ! TU
      REAL*4     Z_RGM135XETE2 ! TU
      REAL*4     Z_RGM144PRTE2 ! TU
      REAL*4     Z_RGM85KRTE2 ! TUR
      REAL*4     Z_G131I      ! CON
      REAL*4     Z_G132I      ! CON
      REAL*4     Z_G132TE     ! CON
      REAL*4     Z_G133I      ! CON
      REAL*4     Z_G133XE     ! CON
      REAL*4     Z_G134CS     ! CON
      REAL*4     Z_G134I      ! CON
      REAL*4     Z_G135I      ! CON
      REAL*4     Z_G135XE     ! CON
      REAL*4     Z_G136CS     ! CON
      REAL*4     Z_G137CS     ! CON
      REAL*4     Z_G138CS     ! CON
      REAL*4     Z_G138XE     ! CON
      REAL*4     Z_G140BA     ! CON
      REAL*4     Z_G140LA     ! CON
      REAL*4     Z_G144CE     ! CON
      REAL*4     Z_G144CS     ! CON
      REAL*4     Z_G144PR     ! CON
      REAL*4     Z_G16N       ! CON
      REAL*4     Z_G41AR      ! CON
      REAL*4     Z_G60CO      ! CON
      REAL*4     Z_G85KR      ! CON
      REAL*4     Z_G87KR      ! CON
      REAL*4     Z_G88KR      ! CON
      REAL*4     Z_G88RB      ! CON
      REAL*4     Z_G89SR      ! CON
      REAL*4     Z_G90SR      ! CON
      REAL*4     Z_G90Y       ! CON
      REAL*4     Z_G91SR      ! CON
      REAL*4     Z_G91Y       ! CON
      REAL*4     Z_G92SR      ! CON
      REAL*4     Z_G92Y       ! CON
      REAL*4     Z_GM133XE    ! CON
      REAL*4     Z_GM135XE    ! CON
      REAL*4     Z_GM144PR    ! CON
      REAL*4     Z_GM85KR     ! CON
      REAL*4     Z_CWG131I    ! EVA
      REAL*4     Z_CWG132I    ! EVA
      REAL*4     Z_CWG132TE   ! EVA
      REAL*4     Z_CWG133I    ! EVA
      REAL*4     Z_CWG133XE   ! EVA
      REAL*4     Z_CWG134CS   ! EVA
      REAL*4     Z_CWG134I    ! EVA
      REAL*4     Z_CWG135I    ! EVA
      REAL*4     Z_CWG135XE   ! EVA
      REAL*4     Z_CWG136CS   ! EVA
      REAL*4     Z_CWG137CS   ! EVA
      REAL*4     Z_CWG138CS   ! EVA
      REAL*4     Z_CWG138XE   ! EVA
      REAL*4     Z_CWG140BA   ! EVA
      REAL*4     Z_CWG140LA   ! EVA
      REAL*4     Z_CWG144CE   ! EVA
      REAL*4     Z_CWG144CS   ! EVA
      REAL*4     Z_CWG144PR   ! EVA
      REAL*4     Z_CWG16N     ! EVA
      REAL*4     Z_CWG41AR    ! EVA
      REAL*4     Z_CWG60CO    ! EVA
      REAL*4     Z_CWG85KR    ! EVA
      REAL*4     Z_CWG87KR    ! EVA
      REAL*4     Z_CWG88KR    ! EVA
      REAL*4     Z_CWG88RB    ! EVA
      REAL*4     Z_CWG89SR    ! EVA
      REAL*4     Z_CWG90SR    ! EVA
      REAL*4     Z_CWG90Y     ! EVA
      REAL*4     Z_CWG91SR    ! EVA
      REAL*4     Z_CWG91Y     ! EVA
      REAL*4     Z_CWG92SR    ! EVA
      REAL*4     Z_CWG92Y     ! EVA
      REAL*4     Z_CWGM133XE  ! EVA
      REAL*4     Z_CWGM135XE  ! EVA
      REAL*4     Z_CWGM144PR  ! EVA
      REAL*4     Z_CWGM85KR   ! EVA
      REAL*4     Z_RG131ID    ! CON
      REAL*4     Z_RG132ID    ! CON
      REAL*4     Z_RG132TED   ! CON
      REAL*4     Z_RG133ID    ! CON
      REAL*4     Z_RG133XED   ! CON
      REAL*4     Z_RG134CSD   ! CON
      REAL*4     Z_RG134ID    ! CON
      REAL*4     Z_RG135ID    ! CON
      REAL*4     Z_RG135XED   ! CON
      REAL*4     Z_RG136CSD   ! CON
      REAL*4     Z_RG137CSD   ! CON
      REAL*4     Z_RG138CSD   ! CON
      REAL*4     Z_RG138XED   ! CON
      REAL*4     Z_RG140BAD   ! CON
      REAL*4     Z_RG140LAD   ! CON
      REAL*4     Z_RG144CED   ! CON
      REAL*4     Z_RG144CSD   ! CON
      REAL*4     Z_RG144PRD   ! CON
      REAL*4     Z_RG16ND     ! CON
      REAL*4     Z_RG41ARD    ! CON
      REAL*4     Z_RG60COD    ! CON
      REAL*4     Z_RG85KRD    ! CON
      REAL*4     Z_RG87KRD    ! CON
      REAL*4     Z_RG88KRD    ! CON
      REAL*4     Z_RG88RBD    ! CON
      REAL*4     Z_RG89SRD    ! CON
      REAL*4     Z_RG90SRD    ! CON
      REAL*4     Z_RG90YD     ! CON
      REAL*4     Z_RG91SRD    ! CON
      REAL*4     Z_RG91YD     ! CON
      REAL*4     Z_RG92SRD    ! CON
      REAL*4     Z_RG92YD     ! CON
      REAL*4     Z_RGM133XED  ! CON
      REAL*4     Z_RGM135XED  ! CON
      REAL*4     Z_RGM144PRD  ! CON
      REAL*4     Z_RGM85KRD   ! CON
      REAL*4     ZNDFRAC131I(36)  !
      REAL*4     ZNDFRAC132I(36)  !
      REAL*4     ZNDFRAC132TE(36) !
      REAL*4     ZNDFRAC133I(36)  !
      REAL*4     ZNDFRAC133XE(36) !
      REAL*4     ZNDFRAC134CS(36) !
      REAL*4     ZNDFRAC134I(36)  !
      REAL*4     ZNDFRAC135I(36)  !
      REAL*4     ZNDFRAC135XE(36) !
      REAL*4     ZNDFRAC136CS(36) !
      REAL*4     ZNDFRAC137CS(36) !
      REAL*4     ZNDFRAC138CS(36) !
      REAL*4     ZNDFRAC138XE(36) !
      REAL*4     ZNDFRAC140BA(36) !
      REAL*4     ZNDFRAC140LA(36) !
      REAL*4     ZNDFRAC144CE(36) !
      REAL*4     ZNDFRAC144CS(36) !
      REAL*4     ZNDFRAC144PR(36) !
      REAL*4     ZNDFRAC16N(36)   !
      REAL*4     ZNDFRAC41AR(36)  !
      REAL*4     ZNDFRAC60CO(36)  !
      REAL*4     ZNDFRAC85KR(36)  !
      REAL*4     ZNDFRAC87KR(36)  !
      REAL*4     ZNDFRAC88KR(36)  !
      REAL*4     ZNDFRAC88RB(36)  !
      REAL*4     ZNDFRAC89SR(36)  !
      REAL*4     ZNDFRAC90SR(36)  !
      REAL*4     ZNDFRAC90Y(36)   !
      REAL*4     ZNDFRAC91SR(36)  !
      REAL*4     ZNDFRAC91Y(36)   !
      REAL*4     ZNDFRAC92SR(36)  !
      REAL*4     ZNDFRAC92Y(36)   !
      REAL*4     ZNDFRACM133XE(36)
      REAL*4     ZNDFRACM135XE(36)
      REAL*4     ZNDFRACM144PR(36)
      REAL*4     ZNDFRACM85KR(36) !
      REAL*4     Z_RG131ITB6  ! TUR
      REAL*4     Z_RG132ITB6  ! TUR
      REAL*4     Z_RG132TETB6 ! TUR
      REAL*4     Z_RG133ITB6  ! TUR
      REAL*4     Z_RG133XETB6 ! TUR
      REAL*4     Z_RG134CSTB6 ! TUR
      REAL*4     Z_RG134ITB6  ! TUR
      REAL*4     Z_RG135ITB6  ! TUR
      REAL*4     Z_RG135XETB6 ! TUR
      REAL*4     Z_RG136CSTB6 ! TUR
      REAL*4     Z_RG137CSTB6 ! TUR
      REAL*4     Z_RG138CSTB6 ! TUR
      REAL*4     Z_RG138XETB6 ! TUR
      REAL*4     Z_RG140BATB6 ! TUR
      REAL*4     Z_RG140LATB6 ! TUR
      REAL*4     Z_RG144CETB6 ! TUR
      REAL*4     Z_RG144CSTB6 ! TUR
      REAL*4     Z_RG144PRTB6 ! TUR
      REAL*4     Z_RG16NTB6   ! TUR
      REAL*4     Z_RG41ARTB6  ! TUR
      REAL*4     Z_RG60COTB6  ! TUR
      REAL*4     Z_RG85KRTB6  ! TUR
      REAL*4     Z_RG87KRTB6  ! TUR
      REAL*4     Z_RG88KRTB6  ! TUR
      REAL*4     Z_RG88RBTB6  ! TUR
      REAL*4     Z_RG89SRTB6  ! TUR
      REAL*4     Z_RG90SRTB6  ! TUR
      REAL*4     Z_RG90YTB6   ! TUR
      REAL*4     Z_RG91SRTB6  ! TUR
      REAL*4     Z_RG91YTB6   ! TUR
      REAL*4     Z_RG92SRTB6  ! TUR
      REAL*4     Z_RG92YTB6   ! TUR
      REAL*4     Z_RGM133XETB6 ! TU
      REAL*4     Z_RGM135XETB6 ! TU
      REAL*4     Z_RGM144PRTB6 ! TU
      REAL*4     Z_RGM85KRTB6 ! TUR
      REAL*4     Z_HTB6     ! TURB
      REAL*4     Z_WTB6     ! TURB
      REAL*4     Z_PTB6     ! TURB
      REAL*4     Z_BN2TB6   ! TURB
      REAL*4     Z_BHYDTB6  ! TURB
      REAL*4     Z_BOXYTB6  ! TURB
      REAL*4     Z_BSTB6    ! TURB
      REAL*4     Z_BATB6    ! TURB
      REAL*4     Z_BHTB6    ! TURB
      REAL*4     Z_BAHW1A   ! HOTWE
      REAL*4     Z_BAHW1B   ! HOTWE
      REAL*4     Z_BSHW1A   ! HOTWE
      REAL*4     Z_BSHW1B   ! HOTWE
      REAL*4     Z_BHHW1A   ! HOTWE
      REAL*4     Z_BHHW1B   ! HOTWE
      REAL*4     Z_WWO1A    ! HOTWE
      REAL*4     Z_WWO1B    ! HOTWE
      REAL*4     Z_WWO2A    ! HOTWE
      REAL*4     Z_WWO2B    ! HOTWE
      REAL*4     Z_HLIN1A   ! HOTWE
      REAL*4     Z_HLIN1B   ! HOTWE
      REAL*4     Z_HLIN2A   ! HOTWE
      REAL*4     Z_HLIN2B   ! HOTWE
      REAL*4     Z_CKSUB    ! HT XF
      REAL*4     Z_WN2I     !CONDEN
      REAL*4     Z_WN2O     !CONDEN
      REAL*4     Z_WO2I     !CONDEN
      REAL*4     Z_WO2O     !CONDEN
      REAL*4     Z_BOXYDI1  !VARIOU
      REAL*4     Z_BOXYDI2  !VARIOU
      REAL*4     Z_BN2DI1   !VARIOU
      REAL*4     Z_BN2DI2   !VARIOU
      REAL*4     Z_MO2      ! MASS
      REAL*4     Z_MN2      ! MASS
      REAL*4     Z_MGAS     ! CONDE
      REAL*4     Z_XH2O     ! A/R H
      REAL*4     ZH2OGAS    ! GLOBA
      REAL*4     Z_HGAS     ! CONDE
      REAL*4     Z_HGASL    ! LOCAL
      REAL*4     Z_HAIR     ! ENTHA
      REAL*4     Z_TTOTL    ! TEMPE
      REAL*4     Z_CPMIX    ! SPECI
      REAL*4     Z_MG131I      ! ST
      REAL*4     Z_MG132I      ! ST
      REAL*4     Z_MG132TE     ! ST
      REAL*4     Z_MG133I      ! ST
      REAL*4     Z_MG133XE     ! ST
      REAL*4     Z_MG134CS     ! ST
      REAL*4     Z_MG134I      ! ST
      REAL*4     Z_MG135I      ! ST
      REAL*4     Z_MG135XE     ! ST
      REAL*4     Z_MG136CS     ! ST
      REAL*4     Z_MG137CS     ! ST
      REAL*4     Z_MG138CS     ! ST
      REAL*4     Z_MG138XE     ! ST
      REAL*4     Z_MG140BA     ! ST
      REAL*4     Z_MG140LA     ! ST
      REAL*4     Z_MG144CE     ! ST
      REAL*4     Z_MG144CS     ! ST
      REAL*4     Z_MG144PR     ! ST
      REAL*4     Z_MG16N       ! ST
      REAL*4     Z_MG41AR      ! ST
      REAL*4     Z_MG60CO      ! ST
      REAL*4     Z_MG85KR      ! ST
      REAL*4     Z_MG87KR      ! ST
      REAL*4     Z_MG88KR      ! ST
      REAL*4     Z_MG88RB      ! ST
      REAL*4     Z_MG89SR      ! ST
      REAL*4     Z_MG90SR      ! ST
      REAL*4     Z_MG90Y       ! ST
      REAL*4     Z_MG91SR      ! ST
      REAL*4     Z_MG91Y       ! ST
      REAL*4     Z_MG92SR      ! ST
      REAL*4     Z_MG92Y       ! ST
      REAL*4     Z_MGM133XE    ! ST
      REAL*4     Z_MGM135XE    ! ST
      REAL*4     Z_MGM144PR    ! ST
      REAL*4     Z_MGM85KR     ! ST
      REAL*4     Z_MHW131I     ! HO
      REAL*4     Z_MHW132I     ! HO
      REAL*4     Z_MHW132TE    ! HO
      REAL*4     Z_MHW133I     ! HO
      REAL*4     Z_MHW133XE    ! HO
      REAL*4     Z_MHW134CS    ! HO
      REAL*4     Z_MHW134I     ! HO
      REAL*4     Z_MHW135I     ! HO
      REAL*4     Z_MHW135XE    ! HO
      REAL*4     Z_MHW136CS    ! HO
      REAL*4     Z_MHW137CS    ! HO
      REAL*4     Z_MHW138CS    ! HO
      REAL*4     Z_MHW138XE    ! HO
      REAL*4     Z_MHW140BA    ! HO
      REAL*4     Z_MHW140LA    ! HO
      REAL*4     Z_MHW144CE    ! HO
      REAL*4     Z_MHW144CS    ! HO
      REAL*4     Z_MHW144PR    ! HO
      REAL*4     Z_MHW16N      ! HO
      REAL*4     Z_MHW41AR     ! HO
      REAL*4     Z_MHW60CO     ! HO
      REAL*4     Z_MHW85KR     ! HO
      REAL*4     Z_MHW87KR     ! HO
      REAL*4     Z_MHW88KR     ! HO
      REAL*4     Z_MHW88RB     ! HO
      REAL*4     Z_MHW89SR     ! HO
      REAL*4     Z_MHW90SR     ! HO
      REAL*4     Z_MHW90Y      ! HO
      REAL*4     Z_MHW91SR     ! HO
      REAL*4     Z_MHW91Y      ! HO
      REAL*4     Z_MHW92SR     ! HO
      REAL*4     Z_MHW92Y      ! HO
      REAL*4     Z_MHWM133XE   ! HO
      REAL*4     Z_MHWM135XE   ! HO
      REAL*4     Z_MHWM144PR   ! HO
      REAL*4     Z_MHWM85KR    ! HO
C
      REAL*4 Z_131IAR1         ! A/
      REAL*4 Z_132IAR1         ! A/
      REAL*4 Z_132TEAR1        ! A/
      REAL*4 Z_133IAR1         ! A/
      REAL*4 Z_133XEAR1        ! A/
      REAL*4 Z_134CSAR1        ! A/
      REAL*4 Z_134IAR1         ! A/
      REAL*4 Z_135IAR1         ! A/
      REAL*4 Z_135XEAR1        ! A/
      REAL*4 Z_136CSAR1        ! A/
      REAL*4 Z_137CSAR1        ! A/
      REAL*4 Z_138CSAR1        ! A/
      REAL*4 Z_138XEAR1        ! A/
      REAL*4 Z_140BAAR1        ! A/
      REAL*4 Z_140LAAR1        ! A/
      REAL*4 Z_144CEAR1        ! A/
      REAL*4 Z_144CSAR1        ! A/
      REAL*4 Z_144PRAR1        ! A/
      REAL*4 Z_16NAR1          ! A/
      REAL*4 Z_41ARAR1         ! A/
      REAL*4 Z_60COAR1         ! A/
      REAL*4 Z_85KRAR1         ! A/
      REAL*4 Z_87KRAR1         ! A/
      REAL*4 Z_88KRAR1         ! A/
      REAL*4 Z_88RBAR1         ! A/
      REAL*4 Z_89SRAR1         ! A/
      REAL*4 Z_90SRAR1         ! A/
      REAL*4 Z_90YAR1          ! A/
      REAL*4 Z_91SRAR1         ! A/
      REAL*4 Z_91YAR1          ! A/
      REAL*4 Z_92SRAR1         ! A/
      REAL*4 Z_92YAR1          ! A/
      REAL*4 Z_M133XEAR1       ! A/
      REAL*4 Z_M135XEAR1       ! A/
      REAL*4 Z_M144PRAR1       ! A/
      REAL*4 Z_M85KRAR1        ! A/
      REAL*4 Z_HAR1            ! A/
      REAL*4 Z_WAR1            ! A/
      REAL*4 Z_BGASAR1         ! A/
      REAL*4 Z_BN2AR1          ! A/
      REAL*4 Z_BHYDAR1         ! A/
      REAL*4 Z_BOXYAR1         ! A/
      REAL*4 Z_XAAR1           ! A/
      REAL*4 Z_XH2OAR1         ! A/
      REAL*4 Z_131IAR2         ! A/
      REAL*4 Z_132IAR2         ! A/
      REAL*4 Z_132TEAR2        ! A/
      REAL*4 Z_133IAR2         ! A/
      REAL*4 Z_133XEAR2        ! A/
      REAL*4 Z_134CSAR2        ! A/
      REAL*4 Z_134IAR2         ! A/
      REAL*4 Z_135IAR2         ! A/
      REAL*4 Z_135XEAR2        ! A/
      REAL*4 Z_136CSAR2        ! A/
      REAL*4 Z_137CSAR2        ! A/
      REAL*4 Z_138CSAR2        ! A/
      REAL*4 Z_138XEAR2        ! A/
      REAL*4 Z_140BAAR2        ! A/
      REAL*4 Z_140LAAR2        ! A/
      REAL*4 Z_144CEAR2        ! A/
      REAL*4 Z_144CSAR2        ! A/
      REAL*4 Z_144PRAR2        ! A/
      REAL*4 Z_16NAR2          ! A/
      REAL*4 Z_41ARAR2         ! A/
      REAL*4 Z_60COAR2         ! A/
      REAL*4 Z_85KRAR2         ! A/
      REAL*4 Z_87KRAR2         ! A/
      REAL*4 Z_88KRAR2         ! A/
      REAL*4 Z_88RBAR2         ! A/
      REAL*4 Z_89SRAR2         ! A/
      REAL*4 Z_90SRAR2         ! A/
      REAL*4 Z_90YAR2          ! A/
      REAL*4 Z_91SRAR2         ! A/
      REAL*4 Z_91YAR2          ! A/
      REAL*4 Z_92SRAR2         ! A/
      REAL*4 Z_92YAR2          ! A/
      REAL*4 Z_M133XEAR2       ! A/
      REAL*4 Z_M135XEAR2       ! A/
      REAL*4 Z_M144PRAR2       ! A/
      REAL*4 Z_M85KRAR2       ! A/R
      REAL*4 Z_HAR2            ! A/
      REAL*4 Z_WAR2            ! A/
      REAL*4 Z_BGASAR2         ! A/
      REAL*4 Z_BN2AR2          ! A/
      REAL*4 Z_BHYDAR2         ! A/
      REAL*4 Z_BOXYAR2         ! A/
      REAL*4 Z_XAAR2           ! A/
      REAL*4 Z_XH2OAR2         ! A/
      REAL*4 Z_BOXYL2
      REAL*4 Z_BN2L2
      REAL*4 Z_BHYDL2
      REAL*4 Z_HGASL2
      REAL*4 Z_TTOTL2
      REAL*4 Z_XH2O2           ! A/
C     ====================
C     Integer Declarations
C
C
      INTEGER*4  Z_IH1      ! INDEX
      INTEGER*4  Z_IH2      ! INDEX
      INTEGER*4  Z_IP       ! INDEX
      INTEGER*4  Z_IHL1     ! 2-D E
      INTEGER*4  Z_IHL2     ! 2-D E
      INTEGER*4  Z_IPL1     ! 2-D P
      INTEGER*4  Z_IPL2     ! 2-D P
      INTEGER*4  Z_IDG      ! INDEX
      INTEGER*4  Z_CKL1     ! NUMBE
      INTEGER*4  Z_CKLMAX   ! NUMBE
C
C
C
C     Logical Declarations
C
 LOGICAL*4  Z_CBUND
C
jimdempseyatthecove
The above program section is fixed format and has four issues:
a) The CALL statement has lines longer than 72 characters (can be overridden with command line option)
b) The CALL statement has an open line where a continuation marker should be present (missing * in column 6)
c) The SUBROUTINE statement has lines longer than 72 characters (can be overridden with command line option)
d) The SUBROUTINE statement has an open line where a continuation marker should be present (missing * in column 6)
Jim Dempsey
mecej4
The subroutine has 1028 arguments. The subroutine heading has over 256 continuation lines, many of which are over 72 characters long, as Jim pointed out. Just calling this subroutine once in 64-bit code would eat up 8K of stack space. I have never come across code with such long argument lists, and I should dread having to debug such programs.
andrew_4619
Coding Madness!
It would be the work of less than 2 minutes to cut paste all those variables into a module and then adding a USE statement in the caller and callee. One would have to be mindful of any side effects of module vars having SAVE status.
JVanB
Valued Contributor II
ifort 16.0.2 doesn't like it if you have more than 255 dummy arguments or 511 continuation lines. I tried restructuring a little so that all the arguments were keyword arguments so that it might be possible to read the CALL statement. gfortran could deal with the result but as I said it's beyond two of ifort's limits.
Steve_Lionel
Interesting. The documentation says that there is no fixed limit for the number of procedure arguments outside of specification expressions.
