I am having difficulty in understanding the ownership of type bound procedure names. IdeaIly, I would like to use them like the member functions of c++.
Say, I have type apple:
MODULE apple_mod TYPE, PUBLIC :: apple CONTAINS PROCEDURE, PUBLIC :: get_num END TYPE apple CONTAINS INTEGER FUNCTION get_num(this ) IMPLICIT NONE CLASS ( apple ) :: this get_num=1 RETURN END FUNCTION get_num END MODULE apple_mod
and a similar data type, say orange, which has a type bound procedure of the same name, but returning different value :
MODULE orange_mod TYPE, PUBLIC :: orange CONTAINS PROCEDURE, PUBLIC :: get_num END TYPE orange CONTAINS INTEGER FUNCTION get_num(this ) IMPLICIT NONE CLASS ( orange ) :: this get_num=2 RETURN END FUNCTION get_num END MODULE orange_mod
If I were to use both modules in the main program below, or within a module that does not contain get_num there are no problems:
PROGRAM main USE apple_mod USE orange_mod IMPLICIT NONE TYPE(apple), POINTER :: apple_ptr TYPE(orange), POINTER :: orange_ptr WRITE (*,*) apple_ptr%get_num(), orange_ptr%get_num() END PROGRAM main
However, if I try to use apple in pear, which has its own get_num,
MODULE pear_mod USE apple_mod TYPE, PUBLIC :: pear TYPE(apple), POINTER :: apple_ptr CONTAINS PROCEDURE, PUBLIC :: get_num END TYPE pear CONTAINS INTEGER FUNCTION get_num(this ) IMPLICIT NONE CLASS ( pear ) :: this get_num=3 RETURN END FUNCTION get_num END MODULE pear_mod
I get the error: The name of the module procedure conflicts with a name in the encompassing scoping unit. [GET_NUM]
I know I can use aliases, say get_num => get_num_apple etc., but should this be necessary, ie who owns get_num?
apple_mod::get_num, apple::get_num or apple_mod::apple::get_num
Many thanks,
Deniz
This isn't really related to type-bound procedures. It's that you have a module procedure named get_num and then try to define "locally" another get_num. This violates Fortran's rules for name resolution.
One solution is to uniquely name the module procedures and then specify a "binding-name" in the type declaration. Like this:
MODULE apple_mod TYPE, PUBLIC :: apple CONTAINS PROCEDURE, PUBLIC :: get_num => apple_get_num END TYPE apple CONTAINS INTEGER FUNCTION apple_get_num(this ) IMPLICIT NONE CLASS ( apple ) :: this apple_get_num=1 RETURN END FUNCTION apple_get_num END MODULE apple_mod
Or, you could use access control to prevent the module procedure names from being visible by use association, like this:
MODULE apple_mod PRIVATE TYPE, PUBLIC :: apple CONTAINS PROCEDURE, PUBLIC :: get_num END TYPE apple CONTAINS INTEGER FUNCTION get_num(this ) IMPLICIT NONE CLASS ( apple ) :: this get_num=1 RETURN END FUNCTION get_num END MODULE apple_mod
I had already implemented the first solution, but was really looking for the second, which works nicely. Thank you very much for returning promptly.
