Type bound procedure names
Deniz_S_
I am having difficulty in understanding the ownership of type bound procedure names. IdeaIly, I would like to use them like the member functions of c++.
Say, I have type apple:
      MODULE apple_mod
        TYPE, PUBLIC :: apple
        CONTAINS
          PROCEDURE, PUBLIC :: get_num
        END TYPE apple
      CONTAINS
        INTEGER FUNCTION get_num(this )
          IMPLICIT NONE
          CLASS ( apple ) :: this
          get_num=1
          RETURN
        END FUNCTION get_num
      END MODULE apple_mod
and a similar data type, say orange, which has a type bound procedure of the same name, but returning different value :
      MODULE orange_mod
        TYPE, PUBLIC :: orange
        CONTAINS
        END TYPE orange
      CONTAINS
          IMPLICIT NONE
          CLASS ( orange ) :: this
          get_num=2
          RETURN
      END MODULE orange_mod
If I were to use both modules in the main program below, or  within a module that does not contain get_num there are no problems:
      PROGRAM main
        USE apple_mod
        USE orange_mod
        IMPLICIT NONE
        TYPE(apple), POINTER :: apple_ptr
        TYPE(orange), POINTER :: orange_ptr
        WRITE (*,*) apple_ptr%get_num(), orange_ptr%get_num()
      END PROGRAM main
However, if I try to use apple in pear, which has its own get_num,
      MODULE pear_mod
        USE apple_mod
        TYPE, PUBLIC :: pear
        CONTAINS
        END TYPE pear
      CONTAINS
          IMPLICIT NONE
          CLASS ( pear ) :: this
          get_num=3
          RETURN
      END MODULE pear_mod
I get the error: The name of the module procedure conflicts with a name in the encompassing scoping unit.   [GET_NUM]
I know I can use aliases, say get_num => get_num_apple etc., but should this be necessary, ie who owns get_num?
apple_mod::get_num, apple::get_num or apple_mod::apple::get_num
Many thanks,
Deniz
This isn't really related to type-bound procedures. It's that you have a module procedure named get_num and then try to define "locally" another get_num. This violates Fortran's rules for name resolution.
One solution is to uniquely name the module procedures and then specify a "binding-name" in the type declaration. Like this:
MODULE apple_mod
  CONTAINS
    PROCEDURE, PUBLIC :: get_num => apple_get_num
  END TYPE apple
CONTAINS
  INTEGER FUNCTION apple_get_num(this )
    IMPLICIT NONE
    apple_get_num=1
    RETURN
  END FUNCTION apple_get_num
Or, you could use access control to prevent the module procedure names from being visible by use association, like this:
MODULE apple_mod
  PRIVATE
  CONTAINS
  END TYPE apple
CONTAINS
    IMPLICIT NONE
    get_num=1
    RETURN
Deniz_S_
I had already implemented the first solution, but was really looking for the second, which works nicely. Thank you very much for returning promptly.
