Type casting regression in ifort2018 beta
Juergen_R_R
Valued Contributor I
The following code segfaults because the explicit allocation in the type casting does not work any more with ifort2018 beta. I filed a bug report already. A workaround is given.
module event_base
  implicit none
  private
  public :: event_callback_t
  public :: event_callback_nop_t
  public :: eio_callback_t
  public :: dispatch
  type, abstract :: event_callback_t
     private
  end type event_callback_t
  type, extends (event_callback_t) :: event_callback_nop_t
     private
  end type event_callback_nop_t
  type, abstract :: generic_event_t
     real, dimension(:), allocatable :: sqme
  end type generic_event_t
  type :: eio_callback_t
     class(event_callback_t), allocatable :: callback
   contains
     procedure :: set_parameters => eio_callback_set_parameters
  end type eio_callback_t
contains
  subroutine eio_callback_set_parameters (eio, callback, i)
    class(eio_callback_t), intent(inout) :: eio
    class(event_callback_t), intent(in) :: callback
    integer, intent(in) :: i
    allocate (eio%callback, source = callback)
  end subroutine eio_callback_set_parameters
  subroutine dispatch (eio, event_callback)
    type(eio_callback_t), intent(inout) :: eio
    class(event_callback_t), allocatable, intent(in) :: event_callback
    !!! Workaround:
    ! type(event_callback_nop_t) :: tmp
    if (allocated (event_callback)) then
       call eio%set_parameters (event_callback, 1)
    else
       call eio%set_parameters (event_callback_nop_t (), 0)
       ! call eio%set_parameters (tmp, 0)
    end if
  end subroutine dispatch
end module event_base
program main
  use event_base
  type(eio_callback_t) :: eio
  class(event_callback_t), allocatable :: foo
  call dispatch (eio, foo)
end program main
Juergen_R_R
Internal report number is #02767138
Kevin_D_Intel
Thank you Juergen. I took ownership of the internal report too. I will triage this one next.
FortranFan
Another workaround can be:
         asc: associate( nop => event_callback_nop_t() )
            call eio%set_parameters(nop, 0)
         end associate asc
around line 44 of the code from the original post.
Juergen_R_R
Thanks for this nice workaround as well. For the auto(de)allocation, yes, this might be related. Before ifort17 came out (where there are even more problems in our code), we had ifort16 in our test suite without flags and with the -standard-semantics flag (which includes the -assume realloc_lhs) and made workarounds for all issues using explicit auto-allocation.
Kevin,
My hunch is this incident is somehow connected to this thread:
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-fo...
Is it possible to check if the fix for above has made to compiler 18.0 beta?  If not, will the fix be included in the official 18.0 release later this year?
By the way, another workaround can be:
         end associate asc
FortranFan
Cool.
Re: the first part of the quoted text, I had posted it too hastily; I checked it out myself and concluded things were ok in 18.0 beta and therefore, I edited my comments but OP was too quick for me! :-)
Kevin_D_Intel
You mentioned the test case seg-faults but I’m seeing the same runtime error with 18.0 and earlier compilers as shown below. What am I missing?
$ ifort -g -traceback -standard-semantics u733019.f90
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0 Beta Build 20170425
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
 Intel(R) Fortran 18.0-1505
GNU ld version 2.23.52.0.1-16.el7 20130226
$ ./a.out
forrtl: severe (190): for allocate(source=), source needs to be allocated
Image              PC                Routine            Line        Source
a.out              0000000000404A24  Unknown               Unknown  Unknown
a.out              0000000000402BB1  event_base_mp_eio          33  u733019_orig.f90
a.out              0000000000402F1B  event_base_mp_dis          45  u733019_orig.f90
a.out              0000000000402F43  MAIN__                     57  u733019_orig.f90
a.out              0000000000402AB2  Unknown               Unknown  Unknown
libc-2.17.so       00007F406B706AF5  __libc_start_main     Unknown  Unknown
a.out              00000000004029A9  Unknown               Unknown  Unknown
Juergen_R_R
Sorry, Kevin, the runtime error is what I saw.
Kevin_D_Intel
Ok, great. Thank you for confirming. I routed this to Development. This does not appear to be a regression with only 18.0. Thank you for your added time/effort to help isolate this one.
(Internal tracking id: CMPLRS-42659)
