Fortran 2008 standard (WD 1539-1 J3 10-007r1 24th November 2010) document says in section 9.6.4.8.3 Defined input/output procedures:
Consider the following simple code:
module t_m
use, intrinsic :: iso_fortran_env, only : iostat_end, iostat_eor, output_unit
implicit none
private
type, public :: t
private
character(len=:), allocatable :: m_s
contains
!private
procedure, pass(this), private :: read_t
generic :: read(formatted) => read_t
end type t
contains
subroutine read_t(this, lun, iotype, vlist, istat, imsg)
! argument definitions
class(t), intent(inout) :: this
integer, intent(in) :: lun
character(len=*), intent(in) :: iotype
integer, intent(in) :: vlist(:)
integer, intent(out) :: istat
character(len=*), intent(inout) :: imsg
!.. Local variables
character(len=*), parameter :: sfmt = "(*(g0))"
character(len=1) :: c
integer :: i
i = 0
loop_read: do
i = i + 1
read( unit=lun, fmt="(a)", iostat=istat, iomsg=imsg ) c
select case ( istat )
case ( 0 )
write( output_unit, fmt=sfmt) "i = ", i, ", c = ", c
case ( iostat_end )
write( output_unit, fmt=sfmt) "i = ", i, ", istat = iostat_end"
exit loop_read
case ( iostat_eor )
write( output_unit, fmt=sfmt) "i = ", i, ", istat = iostat_eor"
exit loop_read
case default
write( output_unit, fmt=sfmt) "i = ", i, ", istat = ", istat
exit loop_read
end select
end do loop_read
return
end subroutine read_t
end module t_m
program p
use t_m, only : t
implicit none
character(len=:), allocatable :: s
type(t) :: foo
character(len=256) :: imsg
integer :: istat
s = "Hello"
read( unit=s, fmt=*, iostat=istat, iomsg=imsg ) foo
if ( istat /= 0 ) then
print *, "istat = ", istat
print *, imsg
end if
stop
end program p
Upon compilation and executing using Intel Fortran compiler 17 update 1, the output is
i = 1, c = H i = 2, c = e i = 3, c = l i = 4, c = l i = 5, c = o i = 6, istat = 67 istat = 67 User Defined I/O procedure returned error 67, message: input statement requires too much data, unit -5, file Internal List-Directed Read
Is this conformant with the standard?
Note for the same, gfortran issues the error code of iostat_end which appears more meaningful in this context.
Can Intel Fortran development team please review this and follow up as needed?
This looks familiar - I think it's one we're already working on. I have asked the developers to look at it.
Yes, it's very similar to https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/618870#comment-1864365 The tracking ID for this issue is DPD200416704.
I think gfortran is incorrect, though - it should be returning an EOR condition, not EOF. Quoting from F2008:
"A formatted child input/output statement is a nonadvancing input/output statement, and any ADVANCE= specifier is ignored." (9.6.2.4)
"An end-of-record condition occurs when a nonadvancing input statement attempts to transfer data from a position beyond the end of the current record, unless the file is a stream file and the current record is at the end of the file (an end-of-file condition occurs instead)." (9.11.1)
Steve Lionel (Intel) wrote:
Yes, it's very similar to https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-fo... The tracking ID for this issue is DPD200416704.
I think gfortran is incorrect, though - it should be returning an EOR condition, not EOF. ..
Steve,
Thanks. So this issue is similar to those others but still a new one, right? Meaning the tracking ID is a fresh incident? In the link you provide above, your last comment dated 07/29/2016 says, "All of the issues raised in this thread have now been fixed" except for one that was going to be fixed in Update 1. I'm now using compiler 17, update 1.
Re: gfortran, I agree completely - I was also expecting an EOR condition; I only brought it up to indicate the difference in responses. I didn't want to comment any further but rather let the Intel Fortran development team determine the best response.
Yes, it's a different problem in that the fix made for the other thread needed to be made in an additional place that was missed.
Also, I passed along the gfortran issue to those developers - they entered Bugzilla https://gcc.gnu.org/bugzilla/show_bug.cgi?id=78881 for it, and they noticed that the characters were read wrong as well.
Also, I passed along the gfortran issue to those developers .. and they noticed that the characters were read wrong as well.
Thanks, Steve. I had noticed the same with gfortran and was contemplating how best to forward the issue, you saved me time.
