UMAT subroutine usage
Yeshwanth_R_
I need to develop a UMAT subroutine for inputting a material model into ABAQUS.
I interfaced ABAQUS 10.1, Visual studio 2008 and Fortran 11.1 successfully(PFA image of abaqus cmd showing PASS)
I then read about UMAT subroutine and started coding it in Fortran 11.1.
But, I am totally confused as to where to use this code. When i debug the code in Fortran 11.1, I got 31 errors, most of which being syntax errors.
Can you please tell me the procedure of inputting an UMAT into ABAQUS.
PFA the code i am using for isotropic elasticity. Please get back to me if there are any errors in it and also any material i've to go through to understand fortran architecture.
It would be great if anyone who have already ran UMAT in abaqus guide me through this and briefly explain
How to use this subroutine if the code is correct?
Can it be successfully debugged in Fortran 11.1?
Suggestions from anybody will be of great use to me as i still am a beginner to this software.
Yeshwanth.
mecej4
Your source code should follow the required syntax and formatting rules of Fortran. The presence of continuation marks suggests that the code is intended to be in fixed format (scanned from a print out?).
In this format, Fortran statements should begin in column 7, continuation marks in column 6, the comment mark C in column 1, and statement numbers in columns 1 to 5. Change all instances of character 0x92 to 0x27.
I think that you should spend some time with Fortran tutorials and textbooks if you want to be able to write or modify Fortran code.
pbkenned1
We can help with Fortran questions, but as far as interfacing UMAT with Abaqus, you need to ask questions like that on some Abaqus User's Forum, for example, see this post.
Patrick
Yeshwanth_R_
Thank you Patrick and mecej4 for your time. Will look into abaqus users post for more information.
Nevertheless, Incase anyone has idea about UMAT, Please guide me through this.
