Any ideas on how to fix this? I've attempted a repair of the visual studio integration and rebooting my machine to no avail. I recently installed the 9.1.037 update and the debugger was working after that.
> "I recently installed the 9.1.037 update and the debugger was working after that." Can I assume you meant to say the debugger was working *BEFORE* that?
Try this: uninstall the Fortran Visual Studio IDE integration which you installed from the 9.1.037 kit. Then install the Fortran Visual Studio IDE integration from the 9.1.036 kit. Does that fix the problem?
A debugging problem with the symptoms you describe was introduced in 9.1.037, and a work-around is to go back to the previous IDE integration. The problem is fixed in the next 9.1 update.
