29649 Discussions
Undefined pointer/array *not crashing*
Renaud_Egal
Hello everyone,
I'm having issues with this sample of code
subroutine tri_2D(vect)
	real(kind=DP), dimension(:,:),pointer :: vect
	integer :: n, n1, n2
	real(kind=DP), dimension(:), allocatable :: STOCK1, STOCK2
	real(kind=DP) :: temp1,temp2
	integer :: j, jj, jcompt, flag, jk
	integer :: nn,nntemp
	integer :: k,w
	integer :: markeur
	real(kind=DP),dimension(:), pointer :: ptr_temp
	! recuperation des dimensions de vect
	n1=size(vect,1)
	n2=size(vect,2)
!	write(unit=*,fmt=*) "n1=",n1,"n2=",n2
!	pause
	if (n2/=2) then
		write(unit=*,fmt=*) "erreur de dimension de vect, tri 2D : dim non égale a 2"
		return
	endif
	nn=n1
	allocate(stock1(nn),stock2(nn))
	do k=1,nn
		STOCK1(k)=vect(k,1)
		STOCK2(k)=vect(k,2)
	enddo
Oddly, I declare these variables as "allocatable", so they should be allocated after the statement allocate, right ?
Except I get that "Undefined pointer/aray" (see attached picture). So I guess that it should crash when I affect a value in the "do loop" that follows ? But it doesn't. The debugger still goes through the code
Please advise. I can't figure out what's going on in my statements.
Renaud Egal
mecej4
Not necessarily. You can guard against failed allocation requests by including a STAT= clause in the ALLOCATE statement. If the ALLOCATE did fail, which could happen if nn is large, that would explain why the debugger shows the array as undefined.
You can also use the intrinsic function ALLOCATED to test whether an array has been properly allocated before using the array -- for example, to store information into it.
Renaud_Egal
Ok, I'll try that as soon as I can.
But in this case nn value was 12, not so much large. And if it failed to allocate, wouln't it crash when work is done on it ?
mecej4
That's what I'd expect.
It would help if you could post a complete program source with instructions build and run, and provide information on the compiler version and options used.
andrew_4619
I think you need to show the declaration of vect in the calling routine also.
IanH
If an allocate statement without a STAT specifier encounters an error, then the program should terminate (see F2008 6.7.1.2p9).
This just looks like the debugger getting confused about where the variable being watched is actually kept in memory, or similar.  This is not unusual.  On its own it may not indicate a problem with the program (or may not be relevant to any other observed problems with the program).
Renaud_Egal
Guys,
from what you said I figured that it was an abnormal functionning of VS, not fortran itself.
Then I reinstalled VS and the problem disappeared. Strange.
