29386 Discussions
Undefined symbols for architecture x86_64 error
eleonora_m_
Hi
I'am trying to compile abinit 7.10 or other versions of the code on mac 10.10.2 macbook air with ifort 16.0.1
the command which ifort give me:
/opt/intel//compilers_and_libraries_2016.1.111/mac/bin/intel64/ifort
i try to compile with
./configure FC=ifort CC=icc CXX=icpc F77=ifort
but always i found with intel compiler this error
Undefined symbols for architecture x86_64:
  "_m_profiling_abi_mp_abi_alloc_stat_abi_", referenced from:
      _MAIN__ in abinit-abinit.o
      _chkinp_ in lib57_iovars.a(chkinp.o)
      _driver_ in lib95_drive.a(driver.o)
      _m_ab7_invars_mp_ab7_invars_set_flags_ in lib57_iovars.a(m_ab7_invars_f90.o)
      _m_ab7_invars_mp_new_token_ in lib57_iovars.a(m_ab7_invars_f90.o)
      _m_ab7_invars_mp_ab7_invars_load_ in lib57_iovars.a(m_ab7_invars_f90.o)
      _m_ab7_invars_mp_free_token_ in lib57_iovars.a(m_ab7_invars_f90.o)
  "_pseudo_pwscf_mp_betar_", referenced from:
      _read_pseudo_nl_ in lib11_qespresso_ext.a(read_upf_pwscf.o)
      _upf2abinit_ in lib65_psp.a(upf2abinit.o)
  "_pseudo_pwscf_mp_chi_", referenced from:
      _read_pseudo_ in lib11_qespresso_ext.a(read_upf_pwscf.o)
      _read_pseudo_pswfc_ in lib11_qespresso_ext.a(read_upf_pwscf.o)
  "_pseudo_pwscf_mp_dft_", referenced from:
      _upfheader2abi_ in lib57_iopsp_parser.a(upfheader2abi.o)
      _read_pseudo_header_ in lib11_qespresso_ext.a(read_upf_pwscf.o)
  "_pseudo_pwscf_mp_dion_", referenced from:
  "_pseudo_pwscf_mp_ecutrho_", referenced from:
  "_pseudo_pwscf_mp_ecutwfc_", referenced from:
  "_pseudo_pwscf_mp_els_", referenced from:
  "_pseudo_pwscf_mp_etotps_", referenced from:
  "_pseudo_pwscf_mp_ikk2_", referenced from:
  "_pseudo_pwscf_mp_isus_", referenced from:
  "_pseudo_pwscf_mp_lchi_", referenced from:
  "_pseudo_pwscf_mp_lll_", referenced from:
  "_pseudo_pwscf_mp_lmax_", referenced from:
  "_pseudo_pwscf_mp_mesh_", referenced from:
      _read_pseudo_mesh_ in lib11_qespresso_ext.a(read_upf_pwscf.o)
      _read_pseudo_rhoatom_ in lib11_qespresso_ext.a(read_upf_pwscf.o)
      _read_pseudo_local_ in lib11_qespresso_ext.a(read_upf_pwscf.o)
  "_pseudo_pwscf_mp_nbeta_", referenced from:
  "_pseudo_pwscf_mp_nlcc_", referenced from:
  "_pseudo_pwscf_mp_nqf_", referenced from:
  "_pseudo_pwscf_mp_nqlc_", referenced from:
  "_pseudo_pwscf_mp_ntwfc_", referenced from:
  "_pseudo_pwscf_mp_oc_", referenced from:
  "_pseudo_pwscf_mp_psd_", referenced from:
  "_pseudo_pwscf_mp_pseudotype_", referenced from:
  "_pseudo_pwscf_mp_qfcoef_", referenced from:
  "_pseudo_pwscf_mp_qfunc_", referenced from:
  "_pseudo_pwscf_mp_qqq_", referenced from:
  "_pseudo_pwscf_mp_r_", referenced from:
  "_pseudo_pwscf_mp_rab_", referenced from:
  "_pseudo_pwscf_mp_rho_at_", referenced from:
  "_pseudo_pwscf_mp_rho_atc_", referenced from:
      _read_pseudo_nlcc_ in lib11_qespresso_ext.a(read_upf_pwscf.o)
  "_pseudo_pwscf_mp_rinner_", referenced from:
  "_pseudo_pwscf_mp_vloc0_", referenced from:
  "_pseudo_pwscf_mp_zp_", referenced from:
ld: symbol(s) not found for architecture x86_64
make[3]: *** [abinit] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
with gnu compiler i found no error
Please can you help me to solve this problem
thanks
eleonora
You did not show the actual build commands. The errors suggest you're not linking in the object file created by compiling module pseudo_pwscf.
eleonora_m_
I configure abinit with ./configure FC=ifort CC=icc CXX=icpc F77=ifort
Sorry can you tell how to link the object file created during the compilation
Thans a lot for your patience
eleonora
That configure is something in your own environment, it is not using any part of the Intel product. You're apparently using a makefile - the makefile should include all of the .o files from compiling all the Fortran sources, including that of modules. You haven't shown the actual ifort commands run, so I don't know how to advise you.
mecej4
I have never dealt with ABINIT and I do not know anything about whether it comes with pre-built libraries, etc., so the following is speculative.
The error messages given by the linker suggest that some of the libraries (files with the ".a" suffix) were built for 32-bit targets, whereas you are using the IFort and Icc compilers to build 64-bit targets. Typically, running the configure script for a package generates one or more makefiles, and at least some of these makefiles will contain a "clean" target. Running the command "make clean" on each of these should remove those incompatible library files and object files, following which you can attempt to build from scratch.
