This is described in section 2.3 of the Installation Guide and Release Notes.
2.3 Removal/Uninstall
It is not possible to remove the compiler while leaving any of the performance library components installed.
1. Open Terminal and set default (cd) to any folder outside <install-dir>
2. Type the command: <install-dir>/uninstall_cprof.sh
3. Follow the prompts
If you are not currently logged in as root you will be asked for the root password. If you also have the same-numbered version of Intel C++ Compiler installed, it may also be removed.
Where <install-dir> is under /opt/intel/Compiler/11.1/080
Well, I figured that out, but I do not know the root password. I just got this mac two weeks ago. I am the only user on the mac. What is the default root password?
