Unresolved Externals
waterresourcesengine
Up front, I am a 'newbie' to the Intel Visual Fortran Compiler and am facing the 'learning curve...'
I am trying to compile a simple test code; and get the following errors as a partial example.
I have the file IFORT.CFG in the same subdirectory as IFORT.EXE and my test code.
I am setting the PATH, LIB, INCLUDE in the .CFG using the SET command.
Thanks for advice on resolving this.
Microsoft Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation. All rights reserved.
-out:TESTCODE.exe
-subsystem:console
TESTCODE.obj
TESTCODE.obj : error LNK2019: unresolved external symbol ___intel_new_proc_init referenced in function _MAIN__
TESTCODE.obj : error LNK2019: unresolved external symbol _for_set_reentrancy referenced in function _MAIN__
TESTCODE.obj : error LNK2019: unresolved external symbol _for_write_seq_fmt referenced in function _MAIN__
TESTCODE.obj : error LNK2019: unresolved external symbol _for_read_seq_fmt referenced in function _MAIN__
TESTCODE.obj : error LNK2019: unresolved external symbol _for_stop_core referenced in function _MAIN__
LIBCMT.lib(crt0.obj) : error LNK2019: unresolved external symbol _main referenced in function ___tmainCRTStartup
LIBCMT.lib(crt0.obj) : error LNK2019: unresolved external symbol __imp__GetCommandLineA@0 referenced in function ___tmainCRTStartup
LIBCMT.lib(crt0.obj) : error LNK2019: unresolved external symbol __imp__HeapSetInformation@16 referenced in function ___tmainCRTStartup
LIBCMT.lib(unhandld.obj) : error LNK2019: unresolved external symbol __imp__SetUnhandledExceptionFilter@4 referenced in function ___CxxSetUnhandledExceptionFilter
LIBCMT.lib(invarg.obj) : error LNK2001: unresolved external symbol __imp__SetUnhandledExceptionFilter@4
LIBCMT.lib(gs_report.obj) : error LNK2001: unresolved external symbol __imp__SetUnhandledExceptionFilter@4
LIBCMT.lib(crt0dat.obj) : error LNK2019: unresolved external symbol __imp__GetProcAddress@8 referenced in function ___crtCorExitProcess
LIBCMT.lib(tidtable.obj) : error LNK2001: unresolved external symbol __imp__GetProcAddress@8
continues on with additional LIBCMT 'unresolved externals....'
Steve- attached is the BUILDLOG and .VFPROJ file set; developed as per your suggestions.
Feedback appreciated.
Ok - heclib is built with /MT (static libraries), so choosing /libs:dll is wrong. Please set the Use Runtime Library setting to "Multi-threaded" (not Multithreaded DLL and not a Debug version) and see what you get. Attach the buildlog again if it still has errors.
Steve- finally got an EXE !!!!
MANY thanks !!!!
I've still got to do this same process with a 32 bit library but hopefully this will go easier now that I've got the 64 bit version to link with the Library....
Thanks again and Happy Easter.....
Glad to hear it.
By the way, I like to build Fortran libraries with the Libraries > Disable OBJCOMMENT Library Names set to Yes, so that they can be linked with any executable library type, as long as I know the library will be called from Fortran. If it is called from C, then you need to pick the same library setting as C will use.
