I'm getting an unresolved external symbol from an abstract interface in a static library.
In a module I have the following abstract type and interface, which is compiled into a static library with many other modules.
My version of ifort is
I realise this isn't a compilable example, but I don't know how to get the Windows compiler/linker to give me info about which procedure in the library the unresolved is coming from.
Any ideas?
Cheers,
Ben
[fortran]type, abstract, public :: FermActType
contains
procedure(txt_io), deferred :: Get
procedure(txt_io), deferred :: Put
procedure :: Read => ReadFermActType
procedure :: Write => WriteFermActType
end type FermActType
abstract interface
subroutine txt_io(this,file_unit)
import :: FermActType
class(FermActType) :: this
integer :: file_unit
end subroutine txt_io
end interface[/fortran] I then have my main program which links against the library (against procedures that use the abstract type and its children), but when I attempt to link I get this:[plain]Linking... cola.lib(fermacttypes.obj) : error LNK2001: unresolved external symbol TXT_IO x64\\Debug\\dibaryon.exe : fatal error LNK1120: 1 unresolved externals[/plain]I found this thread (http://software.intel.com/en-us/forums/showthread.php?t=85691) for the Linux compiler, which seems perhaps similar?
[plain]Intel Visual Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.0.233 Build 20110811 Copyright (C) 1985-2011 Intel Corporation. All rights reserved.[/plain]
Any ideas?
Cheers,
Ben
The full context is there for the taking:
cola.lib(fermacttypes.obj):errorLNK2001:unresolvedexternalsymbolTXT_IO
Look for an external symbol (subprogram or common block name) called TXT_IO in the object fermacttypes.obj in the library cola.lib.
Thanks mecej4,
Sorry, I probably should have said in my original post - I used dumpbin to check the object file, and the external symbol TXT_IO is indeed there. The problem is that the only references to TXT_IO in the source for that object file is what I posted before - the abstract interface. Since it isn't acutally a procedure, why is there a corresponding symbol in the object file?
The question about getting the linker to produce more info was regarding why it linked previously, which I figured out afterwards was because previously it wasn't linking against that object in the library (but rather, other contained objects) until I added a call to one of its routines.
Ben
Ben
We know of two compiler bugs that can produce this symptom. One of them, DPD200169377, is fixed in Update 6. The other, which you have probably encountered, is DPD200173134 and is not yet fixed - that's the one you linked to.
If you can provide a compilable example we can be sure that we fix yours.
I've narrowed it down to using a typebound function from a type which extends another type which extends the base abstract type. The attached files are compilable and exhibit the error.
Also, running dumpbin on the object file from the module gives this:
Cheers,
Ben
[plain]>> ifort /o module.obj /c module.f90 >> ifort /o program.exe program.f90 module.obj Intel Visual Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.0.233 Build 20110811 Copyright (C) 1985-2011 Intel Corporation. All rights reserved. Microsoft Incremental Linker Version 10.00.30319.01 Copyright (C) Microsoft Corporation. All rights reserved. -out:program.exe -subsystem:console program.obj module.obj module.obj : error LNK2001: unresolved external symbol TXT_IO program.exe : fatal error LNK1120: 1 unresolved externals[/plain]
[plain]Microsoft COFF/PE Dumper Version 10.00.30319.01
Dump of file module.obj
File Type: COFF OBJECT
COFF SYMBOL TABLE
000 00000000 DEBUG notype Filename | .file
module.f90
002 00000000 SECT1 notype Static | .text
Section length F0, #relocs D, #linenums 0, checksum 0
004 00000000 SECT1 notype () External | TESTMODULE.
005 00000010 SECT1 notype () External | TESTMODULE_mp_READFERMACTTYPE
006 00000030 SECT1 notype () External | TESTMODULE_mp_GET_WILSON
007 00000040 SECT1 notype () External | TESTMODULE_mp_PUT_WILSON
008 00000050 SECT1 notype () External | TESTMODULE_mp_GET_CLOVER
009 00000060 SECT1 notype () External | TESTMODULE_mp_PUT_CLOVER
00A 00000070 SECT1 notype () External | TESTMODULE_mp_PRINT_CLOVER
00B 000000E0 SECT1 notype () External | TESTMODULE_mp_PRINT_WILSON
00C 00000000 SECT2 notype Static | .xdata
Section length 8, #relocs 0, #linenums 0, checksum 0
00E 00000000 SECT3 notype Static | .pdata
Section length C, #relocs 3, #linenums 0, checksum 0
010 00000000 SECT4 notype Static | .rdata
Section length 40, #relocs 4, #linenums 0, checksum 0
012 00000000 SECT5 notype Static | .bss
Section length 80, #relocs 0, #linenums 0, checksum 0
014 00000000 SECT5 notype Static | .T136_
015 00000000 SECT4 notype Static | DYNTYPE_PACK_1.0.8
016 00000010 SECT4 notype Static | TBPLIST_PACK_1.0.8
017 00000000 UNDEF notype External | TXT_IO
018 00000028 SECT4 notype Static | __STRLITPACK_1.0.8
019 00000008 UNDEF notype External | TESTMODULE_mp_I_AM_ROOT
01A 00000000 UNDEF notype () External | __ImageBase
01B 00000000 SECT6 notype Static | .drectve
Section length B9, #relocs 0, #linenums 0, checksum 0
String Table Size = 0x125 bytes
Summary
80 .bss
B9 .drectve
C .pdata
40 .rdata
F0 .text
8 .xdata
[/plain] The external symbol for the abstract interface is there.Cheers,
Ben
I've experimented with different versions of the compiler on Linux. I can reproduce the error with the 12.1.0 20110811 version, but not the 12.0.4 20110427 build. As such, I don't think it's the same issue as the one I linked to (DPD200173134), since that was reported for 12.0.3. Perhaps the issue started at the same time in the Windows version as well.
Interestingly, the object files produced by the two versions of ifort are different. For version 12.0.4 20110427, I get this:
Cheers,
Ben
[plain]bjm566@vayu3 ~/Code/testing>nm module.o 0000000000000000 T testmodule._ 0000000000000040 T testmodule_mp_get_clover_ 0000000000000020 T testmodule_mp_get_wilson_ 0000000000000004 C testmodule_mp_i_am_root_ 0000000000000060 T testmodule_mp_print_clover_ 0000000000000070 T testmodule_mp_print_wilson_ 0000000000000050 T testmodule_mp_put_clover_ 0000000000000030 T testmodule_mp_put_wilson_ 0000000000000010 T testmodule_mp_readfermacttype_[/plain]while for 12.1.0 20110811, this:
[plain]bmenadue@weyl ~/bmenadue/Code/testing>nm module.o
0000000000000000 r DYNTYPE_PACK_1.0.8
0000000000000010 r TBPLIST_PACK_1.0.8
0000000000000000 r __STRLITPACK_1.0.8
00000000000000c0 T testmodule_mp_print_wilson_
U txt_io_
0000000000000000 b var$136[/plain]Cheers,
Ben
Thanks - we are working on the fix for this now.
This has been fixed for a release later this year.
Topic Options
