Upgrade Fortran 2013 to 2019
YGod
How to upgrade from Intel(R) Visual Fortran Composer XE 2013 SP1 to Install Intel Parallel Studio XE 2019 Composer Edition
mecej4
See https://software.intel.com/content/www/us/en/develop/support/faq-purchasing-renewing-upgrading.html . You will probably find that, since your existing license was issued many years ago, upgrading will cost the same as a new purchase.
Vaughn
Please tell me the proper (usual) way to use/execute "compilervars.sh" and/or "ifortvars.sh."  Neither one is described in the install instructions.  My OS is Linux.  Thanks...
  -- Vaughn
mecej4
The Bash command is (i) A period, (ii) a space, and (iii) compilervars.sh, if that shell script is accessible through $PATH. If not, item (iii) should contain the path, either absolute or relative, as a prefix. You can also use the "source" command instead of item (i).
See https://software.intel.com/content/www/us/en/develop/documentation/fortran-compiler-developer-guide-and-reference/top/compiler-setup/using-the-command-line/specifying-the-location-of-compiler-components-with-compilervars.html .
