I have installed the microsoft visual studio, and was installing the file,
w_cprof_p_11.0.072_ia32.exe, (tried both full installation and custom), and got the following...
"Error 1324. The path My Documents contains an invalid character."
"Error while installing package "D:/......................." Fatal error during installation"
The installation error log shows this
MSI (c) (40:0C) [11:10:18:677]: TRANSFORMS property is now:
MSI (c) (40:0C) [11:10:18:677]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\Application Data
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\Favorites
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\Recent\NetHood
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\My Documents
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\PrintHood
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\SendTo
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\Templates
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Application Data
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\Local Settings\Application Data
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: F:\My Documents\My Documents\My Pictures
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Startup
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Desktop
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\Start Menu\Programs\Administrative Tools
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\Start Menu\Programs\Startup
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Tan Long Bin\Desktop
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Templates
MSI (c) (40:0C) [11:10:18:677]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (c) (40:0C) [11:10:18:677]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
As you can see, one of the "My Documents" is from F drive, how do I manually change this or how do the setup file be able to "rescreen" the location/path of the files again so that installation can progress.
Thanks a lot for the help.
I have tried to reinstall a couple of times with different destination folders and also rereading the license file,but still unable to, having stop at the same point with the same error message.
Quoting - nightzip
try this
Make sure you create a restore point before you do the following
http://support.microsoft.com/kb/325069
Hope it helps!!
