Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
26856 Discussions
Using GDB to debug an MPI program in Fortran (on MAC)
Diego_S_
Hello, I am trying to debug an MPI fortran program using the advice from this post: (Using GDB to debug an MPI program in Fortran). The idea is to place an MPI_BARRIER inside a DO WHILE loop and then attach gdb to the right process with something like
gdb -pid 12345
However, I keep getting the following message:
warning: unhandled dyld version (15)
0x00007fffb6f2ef46 in ?? ()
 When I try:
(gdb) info locals
I get "No symbol table info available". As a result, I can not attach gdb to the running process. I am working with MacOS 10.12 (Sierra), gdb 8.0, and compiling with mpif90 configured for ifort (version: 17.0.4). Any ideas about what could be the cause for this problem?
