29424 Discussions
VB6 Progaram witn Intel Fortran DLL: "Member already exists"
Mark_Gracey
I am writing a program in which Visual Basic 6 modules call an Intel Fortran DLL.
In the prototype stages, I received the error discussed in this thread.
However, I was unable to find the solution, and, eventually, re-wrote the entire software from scratch.
The problem has returned, but development is now too advanced to take that approach again.
I am getting the error message:
Compile error:
Member already exists in a object module from which this object module derives.
I have attached a zip file containing the two VB modules which call the DLL and the two subroutines in the DLL.
The error appears when Calc_Airspeed is compiled within Calc_Airspeed_button_Click.
The same DLL is called, but the subroutine is different.
However, it is possible that I shall be calling the same routine from two different modules as the software expands.
Both declarations are Private.
Can anyone help?
Mark.
The problem you're having is with VB6. It isn't Fortran giving this error.
