29649 Discussions
VC++&Fortran mixed-language string problem
owenkid
I posted an early thread this morning, using the C#&Fortran.
But no one give me even a single answer, so I switch to VC++&Fortran(DLL).
But I encounter the same problem:Unhandled exception at 0x10001082 in MFCMainTest.exe: 0xC0000005: Access violation reading location 0x00000007.
Then I switch to so I switch to VC++&Fortran(Static library),then I got another problem:Error1error LNK2019: unresolved external symbol _TEST@12 referenced in function _dynamicLIBSTRING_Cbridge.obj
I put the whole code in the attachment, I hope some guys can get me out of here.
sumi714
That certainly did the trick! I actually tried dummy character string earlier and that didn't work. I suppose, "reference" attribute to the function made the difference. I did find this attribute in the help and applied before. Obviously, that attempt was not proper and hence didn't work.
As all attempt failed, I thought of accepting the character string as pointer in FORTRAN routine.
Thank you very much, Steve.
There's a handy table in the mixed-language programming chapter of the on-disk documentation that spells out how arguments of various types are passed when the different attributes are used. When you say C without REFERENCE, character arguments are passed/accepted as a single character. Why? Because this is the way MS did it in Fortran PowerStation. It is a rather useless choice.
